GTX 1050Ti Very Low Benchmark 4081 vs. 5900 on Passmark - NEED HELP!
jerelv
2018/12/30 19:31:45 (permalink)
I bought this card new. It's only getting 40-50 fps on the DirectX 9 test which my previous card HD6970 did better.
I7-3770 processor
16GB ram
Corsair SSD
Win10 Pro
Nvidia 417.58 driver
Most current BIOS
1050Ti selected in BIOS and control panel
Please help because I can't think of anything else. Thanks!
post edited by jerelv - 2018/12/30 19:55:49
Asus TUF B550M-PLUS Wifi
Ryzen 5600X
EVGA 3070Ti XC3 Ultra
Crucial Ballistix 3200Mhz
WD Black SN750 1TB
4 Replies Related Threads
    Re: GTX 1050Ti Very Low Benchmark 4081 vs. 5900 on Passmark - NEED HELP! 2018/12/30 19:59:38 (permalink)
    Is the card running at advertised clocks when running the benchmark?
    jerelv
    Re: GTX 1050Ti Very Low Benchmark 4081 vs. 5900 on Passmark - NEED HELP! 2018/12/30 20:11:10 (permalink)
    It's running at 100% during the tests.
    I did the render test and just noticed it won't run more than PCIe x4 2.0.
    Ryzen 5600X
    WD Black SN750 1TB
    Re: GTX 1050Ti Very Low Benchmark 4081 vs. 5900 on Passmark - NEED HELP! 2018/12/30 20:12:24 (permalink)
    Looks like you found the problem.
    • Ribbons : 282
    Re: GTX 1050Ti Very Low Benchmark 4081 vs. 5900 on Passmark - NEED HELP! 2018/12/30 21:46:27 (permalink)
    jerelv
    You should check in Full Screen as well and see what it shows on the Lower Left of the screen.
