compguru910
I'm having flashbacks to my early FTW3 3090, where the GPU wont get near its maximum power limit. Overclocked to 2175mhz, memory at +850 (not doing the math right now), GPU utilization peaked, and this thing only sips about 440w peak. It normally sits around just 400w.
I do feel this is different than the 3090 as I was constantly being power limited, but here I am not. HWInfo is only reporting utilization capped, not power. Anyone else experiencing this? I was expecting greater power consumption than my 3090 (which would do 500w after a bios fix), but at the same time, I'm getting more performance out of the 3090ti with less power.
compguru910
Re: FTW3 3090 Ti power issues?
2022/04/07 05:45:51
I have to correct myself, looking at HWInfo I am getting power limited. But my peak power is only 441w.
- Ribbons : 86
2022/04/07 06:18:28
Doesn't that video card have a triple BIOs switch? What is it set to? If there a power difference between the setting?
CraptacularOne
- Ribbons : 222
2022/04/07 08:01:34
The BIOS switch just adjusts fan profiles, there is no difference in peak power between them. As for the OP, this sounds normal. It doesn't "need" to be drawing 500w all the time. It will draw what it needs for the given rendering task. Just because your card peak at 500+w doesn't mean it has to all the time. It's just that a "peak". Do your drive your car around at it's redline RPM all day just because it can?
compguru910
2022/04/07 08:05:03
CraptacularOne The BIOS switch just adjusts fan profiles, there is no difference in peak power between them. As for the OP, this sounds normal. It doesn't "need" to be drawing 500w all the time. It will draw what it needs for the given rendering task. Just because your card peak at 500+w doesn't mean it has to all the time. It's just that a "peak". Do your drive your car around at it's redline RPM all day just because it can?
This isn't normal. Both my 3090 and 3080ti would consume more power. The 3090 had this problem, and the fix for it was swapping the bios with the XC model and making it think there was only 2 8pins. The power consumption then went up. If the GPU didn't need the power, the card wouldn't be power perf capping.
CraptacularOne
- Ribbons : 222
2022/04/07 08:17:18
compguru910
This is normal and it sounds to me like you don't know what you're looking at in GPUZ. If the rendering task doesn't require peak power, the card won't draw peak power. I too have both a RTX 3090 and a RTX 3080 Ti and neither one constantly runs at it's max power draw. They are working as intended and only running at "peak" when required.
compguru910
2022/04/07 08:24:40
My god man, the GPU is throwing Power perf cap... So the GPU is limiting itself because it doesn't have enough power. If the GPU was at 480w and throwing that, it would be 'normal'. The GPU peaked at 441w, well below the peak power limit of the GPU. So no, not normal. This again, is the same behavior that was exhibited with my 3090 which was flawed (and EVGA was willing to replace). I know exactly what I'm looking at.
tresnugget
- Ribbons : 5
2022/04/07 08:28:45
In gpuz are you staying at a power limit or is it just here and there. What's your pcie slot power max and average?
compguru910
2022/04/07 08:37:08
tresnugget In gpuz are you staying at a power limit or is it just here and there. What's your pcie slot power max and average?
I don't use GPU-Z, I'm using HWInfo, and in the picture above its peaking at 11w. Its pretty regularly hitting it. It comes off a bit, but anytime its around 440w its perf capping.
Resident Guru
2022/04/07 08:41:05
Mine peaks around 455w when gaming. This is the 3090 Ti Black edition. It will self boost to 2025 mhz. Haven’t really done much overclocking yet.
tresnugget
- Ribbons : 5
2022/04/07 08:41:35
compguru910
I like gpuz because it graphs so you can see when it's hitting what perfcap. But yeah, I see the pcie slot power now. It's almost like the opposite of the 3090 issue. You're pulling almost 150w on the 3 virtual 8 pins, probably where you're hitting the power limit, but you still have plenty of pcie headroom.
tresnugget
- Ribbons : 5
2022/04/07 08:41:36
Edit: for some reason it double posted
post edited by tresnugget - 2022/04/07 08:42:44
compguru910
2022/04/07 08:45:23
tresnugget
compguru910
I don't think its doing it at the same time though (the 3x PCI-E power) as that would put me to 450w, which I'm not hitting. Most of the time while gaming I'm sitting at just over 400w. Just ran Port Royal which is the highest GPU load I can think of (and was used to verify 3090 problems) and I peaked at 450w. Resident Guru Mine peaks around 455w when gaming. This is the 3090 Ti Black edition. It will self boost to 2025 mhz. Haven’t really done much overclocking yet.
Thats interesting. I might try flashing that bios to see if it fixes my problem. I'm hovering at around 400w while the GPU is at 2160mhz (thats normalized, peak is 2190)
post edited by compguru910 - 2022/04/07 08:46:41
tresnugget
- Ribbons : 5
2022/04/07 08:48:59
compguru910
tresnugget
compguru910
Right, but I'd imagine if it hits 150w on even one it's going to perfcap. I really don't like how that's done. Wish it was seen as one power source.
compguru910
2022/04/07 08:52:21
tresnugget
compguru910
tresnugget
compguru910
Yeah, I'm not a fan either so far. Got around this with the 3090 by flashing a 2x8Pin cards bios. Now I don't have that option.
Jomama22
- Ribbons : 19
2022/04/07 13:30:59
Isn't the bios limited to 450w unless you manual increase the power slider in afterburner/x1? Would try adjusting this first and check again. Also, use hwinfo and decrease the polling rate to something 200ms-500ms.
post edited by Jomama22 - 2022/04/07 13:56:00
03whitegsr
2022/04/07 13:49:54
Odd that pcie slot power is so low. RMA I guess? That doesn't seem like it would be normal, but somebody else with the 3090Ti would have to compare.
It makes sense the way it's reporting on three cables, you have three cables connected after all and it has to be fused in a meaningful way. Fussing for 60A on one connector and then having 3 separate power supply connections is asking for trouble.
tresnugget
- Ribbons : 5
2022/04/07 14:03:22
03whitegsr Odd that pcie slot power is so low. RMA I guess? That doesn't seem like it would be normal, but somebody else with the 3090Ti would have to compare.
People won't necessarily have 3 cables. The new gigabyte UD1000GM PCIE 5 already has a 16 pin cable with 600w/50A capability. Even with 3 cables, the card can only pull 480w and 40A split between 3 cables shouldn't be an issue.
compguru910
2022/04/07 14:15:09
Jomama22 Isn't the bios limited to 450w unless you manual increase the power slider in afterburner/x1? Would try adjusting this first and check again.
I did manually increase the power limit. It should be 480w.
03whitegsr
2022/04/07 14:16:39
You have to fuse the cables separately. What happens if you fuse it for 50A at the 12 pin, then only hook up one cable at the PS? It pulls the full 480W through one cable... (Provided the PSU doesn't step in). Point is, it makes sense the way they have done it from an engineering perspective. I mean, using gigabyte as a benchmark for power supplies feels... Explosively controversial to me?
post edited by 03whitegsr - 2022/04/07 14:17:43
03whitegsr
2022/04/07 14:19:48
compguru910 I did manually increase the power limit. It should be 480w.
In PX1 or Afterburner? There was a point in time where Afterburner didn't seem to adjust the power limiter correctly in my 3080Ti and I had to use PX1 to set it. Wonder if the same is happening here.
2022/04/17 23:17:26
ramsito82
2022/04/17 23:53:35
2022/04/18 00:13:13
ramsito82 can you pass port royal to see the consumption?
a greeting.
No, as my oc isn't optimized for PR.
andi0139
2022/04/18 05:32:00
Mine also doesnt reach the 480 watts, i see the 450 in god of war, and max 470 in Timespy but never seen 480, Games are most of the Time between 400 and 450
2022/04/18 23:29:49
ramsito82
2022/04/19 02:16:16
3090ti ftw3 ultra ,after passing timespy. the maximum I have seen in another test has been 472w, I have not yet seen it reach 480w, is there any xoc bios planned?
post edited by ramsito82 - 2022/04/19 02:17:59
2022/04/19 02:26:29
May be able to use the vbios for the KPE on the FTW3 cards. Just gotta wait and see.
ramsito82
2022/04/19 02:29:27
Sajin May be able to use the vbios for the KPE on the FTW3 cards. Just gotta wait and see.
thanks, I'm very happy with performance and temperatures, not so much with price xD
2022/04/19 02:32:00
No problem. Yeah, prices are getting dumb for sure.
