Evga LED Sync does not sync
Spirit_Rises
2019/03/19 09:11:19 (permalink)
Hi guys
i have clc 280 on my cpu and Rtx 2080 ti xc hybrid
when i enable the led sync on precision X1 it does not sync with the clc280
i also installed the evga flow control.When i click on the LED sync buttpn on flow control,small window called EVGA LED SYNC pops up and gives me the option to choose my devices(i assume the ones i want them to be synced) but it also does not make any difference.
what should i do?
2 Replies Related Threads
    • Ribbons : 123
    Re: Evga LED Sync does not sync 2019/03/20 18:52:10 (permalink)
    Moving to EVGA Software section of Forums
    Home » All Forums » [Other EVGA Products] » EVGA Software
    Hoggle
    Re: Evga LED Sync does not sync 2019/03/20 22:29:46 (permalink)
    Do you have the latest windows updates as well EVGA flow control? When you go into Flow control can you change the color on the CLC-280? Can you change the color for the card in Percision X1 software?
