Hot!Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED
EVGA_Lee
  • Ribbons : 14
2022/12/30 01:50:16 (permalink)
Adds Smart Fan control support for EVGA Z790 motherboards*
     *Note - E799 motherboard must be on BIOS 1.07 or newer to support fan control function.
     *Note - E798 motherboard must be on BIOS 1.05 or newer to support fan control function.
Release Notes:
  • Adds Smart Fan function to X570 motherboards.
  • Supports Z790/Z690/X570 Smart Fan function with profile.
As always, please leave your feedback and let us know if you run into any issues.
8 Replies Related Threads
    wheise
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/01/03 14:33:26 (permalink)
    I posed a question but answered it.
    post edited by wheise - 2023/01/04 20:29:39
    fergusonll
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/02/18 21:17:53 (permalink)
    Does this software control lighting that's connected to Z790 KP argb headers.
    EVGA_Lee
    • Ribbons : 14
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/02/21 09:23:09 (permalink)
    fergusonll
    Yes.
    nyxagamemnon
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/02/21 21:11:08 (permalink)
    Anyway to control the ram or do you plan on adding support to control ram with it as well?
    EVGA_Lee
    • Ribbons : 14
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/02/23 11:44:50 (permalink)
    Do you mean controlling the RAM for OC, or RAM RGB?
    newls1
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/02/28 06:43:33 (permalink)
    can this software DISABLE the rgb lights on my gskill ram?
    FTW3 Gaming 3090 Ti / 12900KS @ 5.5GHz / MSI Z690 Unify X
    nyxagamemnon
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/03/01 04:02:09 (permalink)
    EVGA_Lee
    Ram for RGB in the RGB section where the headers are that's the only thing that's missing.
    Volumetrik
    Re: Eleet X1 v1.0.16 - Adds Smart Fan control for Z790 CLASSIFIED 2023/03/24 09:27:22 (permalink)
    EVGA_Lee
    Release Notes:
    Fantastic update, is there any way to get this update on the z590 dark as well? The z590 motherboards have the same problem.
    i7-920 D0 | 4-Way Classy| 12GB ST 2000 | GTX 580 3GB | 60GB Mushkin SSD | HAF X | HX850
