AnsweredEVGA graphics card GTX 1060 fan not spinning help
Kpuff
2018/10/01 08:15:55 (permalink)
hello, recently i noticed my graphics card fan no longer spins. It will spin for a few seconds at start up and then slowly stop. Occasionally ill see it move a little while using my computer but it never fully spins for good. Any ideas? I gently cleaned it to see if that would help, on startup it spun a lot but then stopped. My tower is from Cyberpower and i have had it since january 2017.
  • Ribbons : 282
Re: EVGA graphics card GTX 1060 fan not spinning help 2018/10/01 08:44:50 (permalink) ☼ Best Answerby Kpuff 2018/10/01 08:45:43
Fans Starts Up Around 60C+
You can also use PXOC to set a Fan Profile or Static if you do not want to keep PXOC running in the background.
What are the Temps on your Card?
Kpuff
Re: EVGA graphics card GTX 1060 fan not spinning help 2018/10/01 08:45:07 (permalink)
This has been resolved!
  • Ribbons : 282
Re: EVGA graphics card GTX 1060 fan not spinning help 2018/10/01 08:46:31 (permalink)
Kpuff
Re: EVGA graphics card GTX 1060 fan not spinning help 2018/10/01 08:47:26 (permalink)
I just called and they said thats probably what it is. i didnt realize it only spins when its gets to a specific tempurature. im not actually sure how to tell what the temp is in there. However the rep said it would be i think 60 ish degrees i cannot recall exactly what he said. however my graphics have no issues and he said the spinning it does on start up is it doing a check on its own. so i think we are good, thanks!
  • Ribbons : 282
Re: EVGA graphics card GTX 1060 fan not spinning help 2018/10/01 08:53:29 (permalink)
I set mine with PXOC at 40% Static then Exit out of PXOC.
You can also use NvidiaInspector to set the Fan
post edited by bcavnaugh - 2018/10/01 09:00:08
