EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idle
bertmern
Monday, December 04, 2023 7:28 PM (permalink)
My 3080 is having implausible and inconsistent voltage readouts and hitting power limit at idle, all while having perfectly normal temperatures. I don't think it's actually reaching the power limit, rather incorrectly reading it's own input voltages. This card had this issue when I got it, but after Precision X1 firmware flashing and new thermal pads because I could see air above the inductors and MOSFETS it was fine for around 2 months. Now the issue is back and not going away, I'd love some help if possible. Obviously warranty is void and I got this used. I have a full electrical lab and test facility available, thermal camera, microscope, and like three electrical engineers happy to help but none of them have worked on GPUs and I'd like to respect their time if someone has an idea what is causing this issue.
While running correctly, this card is fantastic and autoclocks typically somewhere at or above 1965MHz. I do not overclock, nor have I altered any voltage settings from stock since receiving the card.
Under any load, however, after about 30 seconds it clocks down to 225MHz and typically stays there, sometimes clocking back up for a minute and running fine but then clocking down again. Whenever it clocks down, it consistently has implausible voltages in GPU-Z. Normally it reads out 12V-12.1V with normal performance, but when it clocks down it will either read between 4V and 10V on the power connectors or it will read 12V on power connectors and 3000V+ on "PWR_SRC Voltage". Whenever it downclocks, Precision X1 reads out at max power, GPU-Z reads out at power threshold and throttle, and temperatures go down from functioning fine at ~65C under load but not max power to 30C when it says full power threshold. This tracks consistently between Precision X1 and GPU-Z.
Things I know about this board:
-It's used, and the previous owner said this was an issue. I get it, buying this was probably dumb.
-I replaced all thermals and did a firmware update immediately when I got it, the card cooled and ran very well after that
-This card ran Starfield very well for 12 hours at a time on release. It also ran a bunch of other games as well as expected for months until last week
-There are no visible cracks on the board.
-There is no warp on the board
-This board has likely been quite hot before for extended periods. The GPU die was still well cooled, but on receipt there was a visible airgap above the MOSFETS and inductors for the VRMs. All of them. Pictures below if it lets me link them.
-The tape below the wire connector for the LED plate was melted. No components look damaged. Pics also included.
-The firmware updated successfully literally this morning, the issue persists
-The issue persists with different power connectors and in different PCI-e slots, I tested it in two of the four I have available and the issue persists
Things I've tested already:
-There is no short through VRMs that I can detect through the coils. Weren't when I got the card, aren't as of ten minutes ago.
-There are no blown fuses that I can find, at least none of the ones big enough to have the amperage rating on them
Things I can't really test today:
-I don't have a power supply to apply small voltage and look for heat today
-I don't have a thermal camera to detect heat
-I don't have a multimeter that can test capacitors today, I can test resistance or continuity though
Things I can test tomorrow
-I'll have a power supply that can apply discrete voltage
-I'll have a thermal camera to see heat
-I'll have a microscope
-I'll have solder setup and ESD equipment for replacing components
Pictures of physical card and GPU-Z readouts"
Thanks in advance for anything anyone can suggest testing today or tomorrow in the lab to save time. I'm looking to rule out or isolate issues today to save time tomorrow.
8 Replies Related Threads
    bertmern
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Monday, December 04, 2023 7:49 PM (permalink)
    Apparently I don't know how to post album links, so here are the pictures individually.
    • Ribbons : 123
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Monday, December 04, 2023 8:42 PM (permalink)
    Welcome to the EVGA Forums & Congrats on your first Thread & Post
    --> First thing I would test/ do is try a different PSU in your PC .... PerfCap = Pwr does seem to align with a 12V bus issue
    Which Nvidia drivers have you tested?
    Your PC specs & OS?
    Multilayer PCB on the GPU, so damage could be anywhere.
    The circuit near the melted tape looks kind of toasty
    EVGA does allow a secondhand warranty. So it is not clear in your post why you believe there is no warranty on this card.
    check the serial number (if your card is not damaged from things not covered by warranty)
    EVGA Warranty terms
    RE: Limits on New member posts ---> Learn your way around the EVGA Forums, Rules & limits on new accounts Ultimate Self-Starter Thread For New Members
    bertmern
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Monday, December 04, 2023 8:57 PM (permalink)
    Thanks!
    I'll do some recommended power supply tests on that and report back, thanks! It runs fine with my old GTX 1080 but that's a lot less power so who knows.
    If you or anyone else has other tests or things to rule out please keep them coming, I'd much rather find something else wrong tonight than take up my coworker's time tomorrow.
    • Ribbons : 271
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Tuesday, December 05, 2023 11:58 AM (permalink)
    Why do you think the warranty is void?
    If it is just because it is bought used second-hand, that's no problem.  I would try getting a warranty replacement.
    If you verify correct voltage into the card and good power connections (probe each pad on the card), there is clearly a component which is damaged and causing incorrect readings, but good luck finding it.
    post edited by ty_ger07 - Tuesday, December 05, 2023 12:01 AM
    bertmern
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Tuesday, December 05, 2023 1:31 PM (permalink)
    Not sure how to do markdown here so I'll answer in order
    Drivers tested-> most up to date and two prior
    PC Specs-> i7-6850k, 32gb 3000MHz RAM, ASUS Rampage V edition 10, Corsair RM850i, running Windows 10 on a fresh install on a fresh M2 Samsung 970 EVO Plus
    I still haven't had a chance to test the PSU, will do today. Kid came home sick so that was my night.
    Warranty Void:
    Thanks for the links though, I had been looking at the warranty terms page before and assumed since the card came with the tape over the screw nearest the GPU die perforated that it was void. That and I've replaced all the thermals, which wasn't exactly a factory modification even if it ran cooler than I've seen a lot of peoples' readouts.
    • Ribbons : 123
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Tuesday, December 05, 2023 3:32 PM (permalink)
    bertmern
    Warranty Void:
    1) Hope your little one gets better soon & the whole family does not end up getting said "bug"
    2) RE: Tape over screws - just a telltale that RMA product needs a closer look mostly as cooler may have been removed.  EVGA does allow you to change TIM, Pads or cooler type - without automatically voiding warranty - as long as you cause no physical damage to the card
    bertmern
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Tuesday, December 05, 2023 8:42 PM (permalink)
    Update: PSU is fine. We tested, under load without the backplate every connector was right at 12.1V. Also laying flat on it's back with better visibility I'm able to see that the physical card is hitting one of the SATA ports on my motherboard which is possibly causing connection issues if I'm not fully seated in the pcie slot. This could be exacerbated by the motherboard and bus heating up, potentially causing misreads of voltage.
    We also cleaned quite a bit of junk off the board with electronic flux cleaner. Not sure if it helped but it sure was gross in places. Under a microscope all he could find was that the board was somewhat dirty. The FLIR camera showed that under load without the backplate nothing went over 60C on the back, and no hotspots suggesting anything on the die side was hotter.
    Cleaning the board allowed it to run fine for about 20 minutes which is all we had time to test. Voltage readouts were still fluctuating somewhat but the clock speeds were MORE normal. Not actually normal though, I have boost lock turned on and the clock still swings between 1500-1980MHz.
    Now I'm quite curious though. The guy helping me suggested that some of the capacitors look as though they've been replaced, specifically the row of blue ones below. He said the rest look like they were installed in factory, the blue ones look like a fourth grader did it. Any thoughts? Does anyone else with this board have blue capacitors? The rest are black or red like the stock photos.
    Next steps:
    Since the warranty is definitely out, I'll look to see if I can figure out what actual vbios are on the card and if I can flash it with more up to date bios instead of hoping firmware updates through Precision X1 fix stuff.
    Also potentially looking into shunt mods to see if I can circumvent whatever is reading power wrong. I have some headroom on this psu and if the card stops working again when I get it home, there's no reason to not make it not work worse? I think that's how I'd phrase it? Still open to ideas.
    • Ribbons : 123
    Re: EVGA RTX 3080 FTW3 implausible voltage readouts, supposedly drawing power limit at idl Wednesday, December 06, 2023 8:06 PM (permalink)
    Thanks for the update
    Any signs of arcing on the back of backplate?  Just trying to think of what could have happened to that black tape in your OP as it looks burnt
