EVGA RTX 2080TI XC Fan 1 will not spin
Raelsmar
Monday, March 25, 2019 1:59 PM (permalink)
  • NZXT H500 Case
  • i9 9900K CPU
  • NZXT Kraken X62 AIO Cooler
  • ASUS Prime Z390A Mobo
  • Samsung 970 Evo Plus NVMe M.2 SSD
  • G.Skill 32Gb DDR4 3200 RAM
  • EVGA RTX 2080Ti XC GPU
  • EVGA 750 G3 PSU
  • OS: Windows 10 Pro x64
Hi all, I am having a fan-related issue with a brand new GPU. One of the fans will spin at system startup and the other remains stationary. I have installed the Precision X1 software and attempted to test both fans. Fan 2 responds according to manual power input. Fan 1 is recognized and is supposedly given power by the utility but does not read as spinning and is not spinning upon inspection. I have attempted to lightly tap the fan in question in case there was any blockage. I have also removed the card and the EVGA G3 750 PSU VGA cables and reinstalled the card; the issue remains. Any troubleshooting tips would be greatly appreciated!
10 Replies Related Threads
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 5:44 PM (permalink)
    Inspect the card, and make sure all the fan cables are fully seated to the pcb fan headers.
    Raelsmar
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 6:09 PM (permalink)
    This is what it looks like:
    There doesn't seem to be a disconnect that's visible. Should I be looking elsewhere on the card? These are all near the front of the card.
    post edited by Raelsmar - Monday, March 25, 2019 6:18 PM
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 6:25 PM (permalink)
    Your picture isn't showing up. Put spaces in your link to make the link show up on the forums.
    Raelsmar
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 6:31 PM (permalink)
    https ://imgur.com/dr1pkzq
    https ://imgur.com/2sRUaB0
    https ://imgur.com/uPu2FDx
    Hope this shows up, it appears for me in the preview.
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 6:37 PM (permalink)
    Make sure the following connector is fully seated...
    Raelsmar
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 6:42 PM (permalink)
    https ://imgur.com/5np1shA
    It looks seated; I gave it a pressdown just to be sure, but it did not move from the pictured position.
    Edit: I should also note that I attempted to install the card into the lower PCI-E slot, with the same result.
    post edited by Raelsmar - Monday, March 25, 2019 6:49 PM
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 7:13 PM (permalink)
    Download msi afterburner, and see if setting the fans to 50% speed will cause both to spin.
    Raelsmar
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 7:41 PM (permalink)
    Only one fan spins after setting it to 50% in MSI Afterburner
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Monday, March 25, 2019 8:50 PM (permalink)
    Time to rma the card.
    peterx86ng
    Re: EVGA RTX 2080TI XC Fan 1 will not spin Saturday, December 14, 2019 6:40 AM (permalink)
    having same issue too, i dont want to do RMA :(
