EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise
jason_ato19
2019/03/19 17:32:09 (permalink)
So does anyone have a EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING where the pump isn't noisy? Returning this to newegg tomorrow for a refund as this is borderline scamming customers. Seriously, I have gone through 4 of these now, and all 4 of them have had pump noises that make you go nuts. Why isn't EVGA doing anything about this? Recall your GFX cards and fix them, you lazy bums.
And yes, I have tried shaking the card, putting the raidator above/below/sideways/every single way. This is flawed for $1600.
post edited by Sajin - 2019/03/19 21:06:58
5 Replies Related Threads
    • Ribbons : 282
    Re: EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise 2019/03/19 17:52:58 (permalink)
    jason_ato19
    Re: EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise 2019/03/19 18:34:22 (permalink)
    yes i have tried shaking the damn thing, as well as hold it above, install it above, this is broken.
    post edited by Sajin - 2019/03/19 21:07:11
    cbradleyiii
    Re: EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise 2019/03/19 19:09:22 (permalink)
    Sorry you are having bad luck.  Mine is working perfectly.  I have the rad in the case rear fan as an exhaust with the hoses at the bottom.  Had no issued with my 1070 ti hybrid either. Best of luck.
    jason_ato19
    Re: EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise 2019/03/20 10:25:38 (permalink)
    cbradleyiii
    Hey man, can you link a picture of your setup if possible please? I have gone through 4 of these now, 5th one is on its way, and there is no improvement.
    ikeike
    Re: EVGA RTX 2080 TI FTW3 ULTRA HYBRID GAMING pump noise 2019/03/24 00:59:51 (permalink)
    same problem
    post edited by ikeike - 2019/03/25 01:40:07
