EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU
enrique145
Wednesday, November 30, 2016 3:18 AM (permalink)
I am not here to complain or pretend that I deserve everything in the world. I am just humbly asking to hear your honest opinions.  I have (had) an EVGA GQ 850 Gold and for some reason, it started melting the VGA port and cable. A bunch of bubbles appeared in the 8 pin cable that connects to the GPU 8 pin port. The damage extended partially to small part of my carpet; the damage could have been my whole house if it was not for my sense of smell. I called EVGA, they complied with the warranty by sending me another unit (for which I am grateful),  but I think that should at least discuss replacing my GPU. I was simply told that they are not liable for the GPU, that I should go thru the GPU warranty.....and obviously not liable for the carpet. I am wondering what would happened if the house actually would have burned down ( which was very possible and I am not exaggerating on this)? Anyway, pics attached..... Thanks!
post edited by enrique145 - Wednesday, November 30, 2016 3:26 AM
16 Replies Related Threads
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 4:07 AM (permalink)
    What gpu is it? That is vsry strange that the cable start to melt like that, and great catch on your part. Have you tested the gpu at all? Was there visible damage on the gpu?
    Use two separate cabled if your card requires two 8 pin connectors or an 8 and a 6 pin.. especially if you are overclocking or using a high tier card. I wouldn't trust a wingle canle with dual 8 pin or 6+2+6, because the gpu is going to want more power than the single cable can technically provide.
    enrique145
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 4:46 AM (permalink)
    Yes, I agree, but its not a particularly power hungry GPU and at that moment was not overclocking. The GPU, I used is a HD7990. According the AMD website, the recommended PSU is a 750W unit. That is the reason why I picked a 850W unit, to be extra safe.
    • Ribbons : 282
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 5:00 AM (permalink)
    Bummer to see this.
    Myself I always use two separate 8-Pin Cables, mostly for my own safety for what I use my cards for.
    Some times I will use a single cable with One 8-Pin and One 6-Pin though but only for a short time and for testing.
    What is the Make and Model of your AMD HD7990 Graphics Card?
    Can you post a Photo of the Power Connectors on the Graphics Card?
    post edited by bcavnaugh - Wednesday, November 30, 2016 5:04 AM
    • Ribbons : 123
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 5:12 AM (permalink)
    Welcome to the forums enrique145
    This HD7990, can draw quite a lot of power: up to 569 Watts at Full load according to the first link
    http://www.tomshardware.com/reviews/radeon-hd-7990-devil13-7970-x2,3329-12.html
    http://www.guru3d.com/art...-hd-7990-review,8.html
    http://www.techspot.com/review/663-amd-radeon-hd-7990/page8.html
    So, this GPU pulling up to 569 Watts at 12 Volts = 47.42 Amps on the +12 Volts
    even a more modest load of 389 Watts at 12 volts = 32.42 Amps on the + 12 volt
    Your HD7990 (dual GPU) would Need a PSU with the ability to cary that large +12V Amp load
    Wires like in your picture (burnt insulation) would indicate to me a short circuit had cause excess current to flow through the wires.
     http://www.amd.com/en-us/products/graphics/desktop/7000/7990#
    post edited by Cool GTX - Wednesday, November 30, 2016 5:20 AM
    MSim
    • Ribbons : 38
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 5:15 AM (permalink)
    If the faulty power supply caused physical damage to GPU, they could use that as grounds to void your GPU warranty.
    2016 seems to be the year of electronics burning/melting/blowing up.
    bob16314
    • Ribbons : 761
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 5:38 AM (permalink)
    It's the video card BIOS programming and it's voltage regulation components that dictate how much power the card is allowed to draw from both the PCIe slot and any 6-pin/8-pin supplemental power connectors.
    Specifically, PCI-SIG (industry standard) specs dictate that up to 75W (6.25A) can be drawn through a PCIe slot, up to 75W (6.25A) can be drawn through a 6-pin supplemental power connector, and up to 150W (12.5A) can be drawn through an 8-pin supplemental power connector, at 12V..Your video card likely failed for some reason and caused that by allowing too much current (Amps) to be drawn through the connectors and the PSU happily obliged, because it could.
    A single-rail PSU like an 850 GQ has no per-rail Over Current Protection which is great for stability, but it's a double-edged sword..A multi-rail PSU would have probably tripped the Over Current Protection before that damage occurred, that's what OCP is supposed to do..Intel writes PSU rules in their Power Supply Design Guides that should be adhered to and had done away with the multi-rail requirement some years ago due to more modern hardware demanding more power and hardware manufacturer outcry.
    Long story short = A PSU will supply only what it's asked to supply, up to a point, by the hardware, even faulty hardware..Almost certainly not the fault of the PSU.
    Power Supply Design Guides (and other stuff, bottom of page)
    Power Supply 101: A Reference Of Specifications (PCI Express Auxiliary Graphics Power Connectors)
    Debunking Power Supply Myths (Connectors and the 12V Rail Issue)
    • Ribbons : 123
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 5:46 AM (permalink)
    bob16314
    Well said Bob
    • Ribbons : 282
    Great Write Up bob16314
    enrique145
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 9:20 PM (permalink)
    I guess one has to become a computer and electrical engineer to not be afraid to use a GPU and a PSU. I read 750W PSU on the box of the GPU and assumed the 850w PSU would suffice, but wrong I was. The 7990 is out of warranty, so to the garbage/recycling bin it goes. I would post pics, but there was no physical damage to it. I stopped the burning madness on time, before the 8 pin connected to the GPU melted too.  All I know is, the GPU does not work anymore since this event. Well, as soon as that replacement arrives, on sale it goes, and so the other parts of the computer. I will buy a  prebuilt computer, probably a Mac and forget about building my own computer again. It is definitely not for me.  Thanks a lot for your opinions, I really appreciate them. Good Luck!
    Vlada011
    • Ribbons : 11
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 9:21 PM (permalink)
    I'm sorry to hear for your HD7990.
    The worse thing is when no more warranty and hardware still work and than something like this happen and GPU die.
    Bad luck.
    http://www.evga.com
    http://www.intel.com
    http://www.nvidia.com
    https://watercool.de
    http://www.lian-li.com
    MSim
    • Ribbons : 38
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Wednesday, November 30, 2016 10:00 PM (permalink)
    enrique145
    I wouldn't blame yourself for faulty hardware acting up. The circuit board on our brand new Trane XV95 central Heat/Air furnace fried itself two different times within the first year.
    p2andrew
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Friday, January 06, 2017 3:45 PM (permalink)
    I just had similar event and noticed that my VGA port and cable melted at the PSU. Its a P2 1000w PSU about 3 months old. So I'm digging through info now about RMA. So it looks like I will have to pay for postage, right? Anything else I should be aware of? I wonder if I should just get a new cable and clean out the melted port? Also, does anyone know why they use only 18 AWG cable for their pcie connectors?
    note PSU appears to be functioning, but one of the VGA ports is a little melt warped. Haven't done too many tests to confirm extent of damage.
    ok thanks for help below...
    post edited by p2andrew - Friday, January 06, 2017 4:57 PM
    • Ribbons : 282
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Friday, January 06, 2017 4:24 PM (permalink)
    Great First Post p2andrew for 2017.
    Did you read Post #7 above?
    "Long story short = A PSU will supply only what it's asked to supply, up to a point, by the hardware, even faulty hardware..Almost certainly not the fault of the PSU."
    Maybe you should have created your own Thread as you do have a different PSU an unknown Graphics Cards an unknown Motherboard.
    The EVGA GQ 850 Gold PSU and the P2 1000w PSU are not the Same Power Supplies.
    Any Photos to show the damage you are writing about?
    post edited by bcavnaugh - Friday, January 06, 2017 5:17 PM
    _ParkerM
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Friday, January 06, 2017 4:47 PM (permalink)
    Hello p2andrew,
    We are sorry to hear about your issue. I will follow up with you personally.
    Adam2184
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Tuesday, January 10, 2017 0:35 PM (permalink)
    Bob's answer was great but I just want to add one thing. As Bob said that is a single rail psu and I find it odd that an EVGA moderator would suggest using 2 separate cables since that wouldn't make any difference. The only way that would matter is if the resistance of the psu cable was high enough, which its not, you could safely send like 30 amps through those cords. Like Bob said though, the fault was the GPU and it caused the psu to send too much power which caused a surge back down the line melting the connectors. EVGA's awesome customer service is still replacing your psu despite it not really being their products fault. If you want more help post detailed pictures of the graphics card after you remove the fan and casing. You most likely blew a capacitor and that's can be a cheap easy fix. Just need a capacitor which you can get from AMD and $10 soldering iron. GPU chip could also be fried then it would be done. Also its a good reason to always by EVGA they would have most likely replaced the Graphics card too had it been one of theirs even if outside the 3 yr warranty.
    Also friends don't let friends buy Apple Computers don't do it!!
    wartimekillers
    Re: EVGA POWER SUPPLY - MELTED CABLE BURNED RUINED GPU Monday, July 03, 2017 8:35 AM (permalink)
    I have similar situation as you, but distributor on my country (Indonesia) refuse to replace my PSU
    short story is, i buy a brand new two EVGA power supply 750G3 and 550GQ in June 2017, and then the 550GQ burned when i attach it into my motherboard and one cable is melted, i'm really sure that i receive defected product, so I return it to EVGA distributor in my country, but they refuse to replace my PSU, and tell me to post in this forum for warranty, what the??
