EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge!
shadowboricua
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, February 09, 2014 8:06 PM (permalink)
Scarlet-Tech
shadowboricua
Q5Grafxin GeForce Experience I get the bridge to light up and stay lit but no effects. I am assuming that since my 780 sc ACX cards have no leds that this is why the bridge only lights up but no effects.
Is this true? Do the effects work with the ACX cards or not?
ACX cards do not have controllable leds. Only the reference Cards with NVidia on the side.
I know ACX cards have no LEDs; I have two of them. My question refers to the SLI bridge effects.
#31
Scotty Mac
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, February 09, 2014 11:43 PM (permalink)
So basically no love for my 760's? :(   I may not be a "high roller" in the PC community, but I would think after spending $640 on GPU's, the bridge would illuminate. Not exactly a cheap bridge either.
Cooler Master HAF 922 (Black Interior, USB 3.0)
MSI Z87-G45 Gaming Military Class IV
Intel i5 4670K 4.2ghz ("super safe OC")
SLI w/ 2x EVGA GTX 760 Dual FTW 4Gb w/ACX
EVGA NEX-G 750W PSU
GSkill Ripjaws-X 16GB (4x4gb) DDR3 2133mhz
CM Hyper 212 Evo - Push/Pull w/SickleFlow 120mm
Samsung 840 Evo SATA III 120GB SSD
WD Caviar Blue 1TB 64MB Cache
Asus VG248QE 24" 144hz
Asus VE248 24" 60hz
Asus 24x OD
Logitech G510 Gaming KB
Microsoft Intellimouse 3.0
Windows 7 HP SP1 64 bit
#32
shadowboricua
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, February 10, 2014 1:06 AM (permalink)
I have two 780 SC ACX cards; will the effects SLI bridge lighting effects work on them?
#33
the_Scarlet_one
formerly Scarlet-tech
  • Ribbons : 79
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, February 10, 2014 2:17 AM (permalink)
Scotty Mac, it says that it doesn't work unfortunately.
I have not seen a post saying that the effects work on the bridge, that the bridge either lights up or it doesn't. Past that, look through the SLI bridge forum post and as far as I remember, you see the exact same thing.
P. S. That topic is 32 pages long. If you don't want to read through, then you may not get the answers. If you do, I can almost bet that every answer is in there.
post edited by Scarlet-Tech - Monday, February 10, 2014 2:19 AM
#34
dpoverlord
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Tuesday, February 11, 2014 7:36 PM (permalink)
How do you guys find your lights compared to the mobo bridge?
Battlestation:http://imgur.com/a/j4rt4
MOBO: Asus Rampage V Extreme - 5930k
RAM: Crucial Ballistix 32GB
GPU: Tri-SLI EVGA Titan X SC
Monitor: Samsung JS9500 65"
PSU: G2 1300
HD: Samsung 850Pro 1TB / 3 WD Red 4tb, Seagate 3TB
Case/Cooling: Lian Li PC-70 modded 10+fans
RET:X58-UD5/Xeon [link=mailto:X5660@4.67/G.skill]5660@4.67/G.skill[/link] 12GB/Ultra 120 Extreme
#35
Sm0ker
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, March 17, 2014 12:08 AM (permalink)
Awesome!!!
Cooler Master HAF - X // EVGA GTX 780 Ti SC // Gigabyte GA-990FXA-UD3 // OCZ-AGILITY3 60GB FOR SO // WDC WD10EZRX-00L4HB0 1TB // AMD Phenom II X6 1100T 4.0 GHz OC // H100i Extreme Performance CPU Cooler // Corsair CMZ8GX3M2A1600C9 1600 4GB X 2 // OCZ Fatal1ty 750W Modular // Asus MX279H
#36
Doomer D. Great
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, April 20, 2014 4:28 PM (permalink)
I have an EVGA GeForce GTX770 SuperClocked 02G-P4-2771-KR. I see that the card has an area that can me lit up but it doesn't. I followed the guide properly and rab everything as Administrator as well. Driver are 335.23 from nVidia's site. Latest Precision X. The LED controller does nothing.
Don't tell me I don't have the LED!
#37
the_Scarlet_one
  • Ribbons : 79
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, April 21, 2014 8:24 AM (permalink)
Doomer D. Great
Question...  Do you have the SLI Bridge?  The LED that the LED Controller is meant for, says GEFORCE GTX on a stock cooler.. You do not have a stock cooler, meaning you do not have the Built in GEFORCE GTX LED.
Unless you abolutely have the SLI Bridge, then you ABSOLUTELY do NOT have the LED that the controller is referring to.  Please Verify that your card is the one on the left (Black cooler), and not the one with the one of the right (Silver cooler).
#38
grimmace
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, April 27, 2014 1:19 PM (permalink)
So, Nvidia experience will make the bridge lights come on, but on the EVGA software you can get more effects? That sum it up?
#39
Ntrain96
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Friday, May 02, 2014 0:28 PM (permalink)
Q5Grafx
Geforce experience allows both the LED's on the cards to light up and be customized......same with the EVGA Pro bridge too.
#40
The Last Phoenix
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, May 04, 2014 6:31 PM (permalink)
I look forward to playing around with this in the near future once I get my gear
Thanks for keeping this updated everyone.
#41
rauf00
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Tuesday, May 20, 2014 9:35 AM (permalink)
Lately i switched from Precison X to MSI, then install EVGA LED Controller 1.2.1 - noticed strange behavior causing lower GPU performance. Unistalling LED solve the problem. It's interfering with MSI or sth?
[Cooling] Custom full loop EK [GPU]  EVGA GTX Titan X 2way SLI [CPU]  i7-5960X Extreme Edition [MB] Asus Rampage V Extreme [RAM] Kingston HyperX Predator 3000MHz DDR4 32GB [PU] Super Flower 1600W Titanium [CASE] InWin 909 [OS] WinX x64 na SSD
my worklog
#42
DarthBeavis
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Thursday, June 26, 2014 11:22 PM (permalink)
Will be building my PDXLAN rig next week with 4-way SLI Titans with EVGA's 4-way bridge . . . can't wait to see it lit up!
Jacob, you all going to be there?
#43
Pramienjager
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, June 30, 2014 1:43 AM (permalink)
I see this is an old thread, but I just grabbed an EVGA GTX 770 4GB Classified and am quite annoyed by this bright white light on the side which serves no real purpose and I cannot control it (or so it seems). Why would anyone want such a light on the side of their GPU? Also, a follow up noob question, what is the plug directly next to the lights? Not the SLI attachments, but some other little plug with 10-12 pins. If anyone can help me out here that would be great, I hate to have spent nearly 500$ on a card that is so great but completely detracts from my overall system theme.
#44
trabe3
  • Ribbons : 8
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, July 07, 2014 7:45 PM (permalink)
Pramienjager
Welcome to the forum....those lights are not able to be turned off or dimmed.  Some people who don't like them either cover them up with some tape or take a marker and color them to dim them.  Keep in mind, anything you do needs to be reversible as it would void your warranty if you would ever need to RMA card.  These LEDs have been around since the 680 Classified and has become a Classified signature just like on MSI's Lightning cards.  Technically the lights are not pointless, they do serve a purpose.  Each one of the 5 LEDs is a tied to a voltage point on the PCB.  If one of the LEDs was not lit, it possibly would mean there is an issue with some component on the card.  If all are lit, everything is functioning properly.
Regarding the additional plug, that is for a Probe-It connector.  It is a small harness that can be used to directly monitor voltages for various items on the card with a digital multimeter (DMM).  The link below will take you to the product page.
http://www.evga.com/Products/Product.aspx?pn=W002-00-000010
Hope this helps.  Good luck!
System #1
ASUS RIV BE
4930K 4.5GHz - Kraken X60 push/pull
16Gb Corsair Dominator Platinum 2133MHz
EVGA 780 Classified SLI - Pro SLI Bridge
Corsair AX1200i
Windows 7 Pro
NZXT Switch 810
ASUS PB287Q 4K
System #2
3930K @ 4.4GHz
8Gb 1600Mhz
XFX R9 270X (for now)
#45
Pramienjager
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, July 07, 2014 11:46 PM (permalink)
Hey Trabe3,
Thanks for the response. I figured out about the probe it, that is pretty cool. As far as the LEDs go, I am going to commission a custom back-plate with a lip over the edge I guess, I cannot bear to put tape on this card :P . Maybe EVGA should think about moving the LEDs and changing their colors, they could perform the same task with out being an eyesore. Oh well. Again, thank you.
#46
Jfedorczyk
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Thursday, July 17, 2014 2:48 AM (permalink)
For the next software update can we get it to not show as an open program?  Would like it to just reside in the taskbar
#47
the_Scarlet_one
  • Ribbons : 79
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Thursday, July 17, 2014 2:54 AM (permalink)
Changing the color and location wouldn't be optimal, as these cards are meant for extreme overclocking, and the lights are meant to be easily seen through the LN2 gas steam and such. The placement has been in the same place for multiple generations now, and the only people that have a complaint are the ones that don't have an interest in extreme overclocking. Others just accept the lights or cover them.
The backplate sounds like a cool idea. Please share photos when complete.
#48
DAVE2HOT4U
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Thursday, July 17, 2014 4:16 AM (permalink)
xboxexpert
I've used this software to create ground fx lighting on my case.   I soldered directly to the 12v lines for LED's and wired them to two 12v light strips and have control over the led's via the software.   It works wonderful.   I would like for you to add a option if its not too much to ask.    Strobe effect.  I'd like to cycle between 0 and 100% and enable the slider to control the strobe speed.   If this is possible it would look amazing.  Attached are pictures of the software working.   Strobe effect would just put it over the top for me.
Now that what I call thinking outside the box !         People like you makes coming here enjoyable.   Hope they heed your request, very good IDEA !
#49
EarlZ
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Saturday, September 06, 2014 8:04 AM (permalink)
So updated to this version to control the SLI PRO, after rebooting only the top card's LED settings gets applied.
#50
feniks
  • Ribbons : 38
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Friday, October 03, 2014 3:45 PM (permalink)
is there anyways I can make the EVGA SLI Bridge light up if I use 670 cards?
#51
DocSun
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Wednesday, December 10, 2014 2:52 AM (permalink)
Am I missing something? I have an EVA GTX 780 6gb Card and I can not seem to get it to illuminate at all either through this program or Geforce Experience. Any help would be appreciated as I am quite new to the whole line of cards.
post edited by DocSun - Wednesday, December 10, 2014 3:07 AM
#52
Babyzone2
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Friday, January 23, 2015 4:49 PM (permalink)
wondering will it work with SLI Bridge on my two GTX 770s
I7-3770K OC 4.7G @1.265V |Custom Watercooling Loop | 4x4G G-skill DDR3 2133 |Asus Maximus v Formula | 2xGTX 770 SLI With EK waterBlock | Creative Sound Blaster ZxR | 2 x Kingston Hyper X 3K 120G Raid 0 | Cool Master Cosmos II With Customized  Full Clear side Panel | 2x360, 2x 240 Radiators | Total 20 of Fans installed.
#53
tonosity
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, February 09, 2015 3:10 AM (permalink)
Is it possible to use an SLI bridge on a EVGA 980 Hydro Copper, and a EVGA 980 SC? (I've heard it said that the Hydro and the SC are the same card, just cooled differently. In other words, are the EVGA line of 980s, able to be mixed in an SLI configuration?
#54
malick
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Friday, February 13, 2015 3:45 AM (permalink)
This is awesome to hear, just to have the option to adjust along with my cards is cool.  Now the next option is an RGB option lol
Semper Fidelis to all those before me, all those that were with me and all those still fighting the fight.
#55
tonosity
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Friday, February 13, 2015 4:26 AM (permalink)
Is it possible to use an SLI bridge on a EVGA 980 Hydro Copper, and a EVGA 980 SC? I've heard it said that the Hydro and the SC are the same card, just cooled differently. In other words, the question is: Are the EVGA line of 980s able to be mixed in an SLI configuration?
#56
neel7
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Saturday, January 09, 2016 6:32 PM (permalink)
Nice!
#57
mmc227
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, January 22, 2018 5:35 PM (permalink)
#58
  • Ribbons : 282
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Monday, January 22, 2018 6:07 PM (permalink)
mmc227
Works Fine on the EVGA HB Bridge.
#59
dmoheban
Re: EVGA LED Controller 1.2.1 - Now Supports EVGA Pro SLI Bridge! Sunday, July 29, 2018 9:13 PM (permalink)
Good news it works with non EVGA bridges. Was able to illuminate my MSI dragon SLI bridge with my Evga 980 Ti's in SLI!
Thank you Evga!
Associate Code: K8XL098LGS5O4WZ
#60
