Re: EVGA Hybrid Kit Fan replacement
2017/05/23 11:44:10
Iluv2raceit
"Virtually Silent Operation, Variable controlled fans allow dynamic fan speed based on gpu temperature, and the water cooling efficiency means very low fan noise." Source: https://www.evga.com/prod...aspx?pn=400-HY-5388-B1
Unfortunately, the reality is that the fan does not run silent, nor anywhere near it. The 2-pin solution to split off the PWM fan header on the card's PCB doesn't work as well as one might hope. I used my own solution for my SC2 Hybrid: 1) Removed EVGA's 2-pin fan and replaced it with a Noctua SSO2 120mm 4-pin PWM high static pressure radiator fan: https://www.amazon.com/gp/product/B00KFCR5BA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 2) Plugged the Noctua fan into a PWM fan header on the motherboard 3) Installed an Uxcell TC 2-pin Temp sensor onto the motherboard and the probe was placed onto the exterior of the radiator to measure the air exhaust temperature: https://www.amazon.com/gp/product/B01DDH68CK/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1 4) Using the Asus software suite, I created a custom fan curve for the fan header on the motherboard controlling the Noctua fan and selected the Uxcell TC as the source for the temperature monitoring; I used several high load GPU benchmarks to determine the range of the radiator exhaust air temperatures and adjusted the custom fan curve accordingly Temps and fan noise are lower now vs. the stock configuration
- Ribbons : 135
2017/05/23 13:24:23
nycalex80 i thought the radiator fan was 100% power 100% of the time?
It's dynamic based on coolant temp.
Pretty sure the radiator fan is static fixed 12v. It's a two wire fan no PWM.
It certainly does say that. However, the fan is a two wire fan. Thus there cannot be any PWM control of the fan. The voltage is fixed at 12v just like it is for the pump. So, EVGA needs to correct their information. From EVGA Tech Erin: The radiator and pump operate at a fixed speed. The four pins on the fan header are tach, PWM control, +12V, and ground. The pump and radiator tap power from the +12V fan power feed from the card. Only the fan on the card itself is variable, as it has the connections to the PWM control signal. The +12V is constant, and doesn't change. If your radiator fan is changing speed, it's not doing so in response to the temperature.
post edited by HeavyHemi - 2017/05/23 13:28:31
nycalex80
2017/05/23 13:51:22
then what could it be? what could be slowing down my noctua fan?
Main Gaming Rig: Be Quiet! Dark Base Pro 900 orange edition Asus ROG maximus viii hero I7 6700k @ 4.5 1.26v NZXT Kraken X62 cpu cooler 32gb Gskill trident Z Evga supernova P2 1000w Evga GTX 1080 TI + evga hybrid kit. 2025 OC. 500 gb samsung 960 Pro nvme ssd 500gb samsung 850evo x 2 in raid 0 Hitachi X300 6tb HDD WD black 2tb absolutelly ZERO cable management (i'm too lazy)
- Ribbons : 135
2017/05/23 14:10:07
nycalex80
Hard to say. All I can tell you is the stock fan, is two wire, thus fixed. You might be getting something weird if you're plugging a PWM fan into it versus the stock fan. Just for giggles when I plugged in a PWM fan into the two wire plug that went to the stock fan, it ran slow and changing the fan speed had zero effect on it. And just to confirm, I plugged in the stock fan and changed the speed from default, all the way to 100% and zero change in fan speed.
2017/05/23 14:28:25
Guess the techs don't know what they are talking about. https://forums.evga.com/FindPost/2672386
- Ribbons : 135
2017/05/23 14:30:37
I agree over the years we've seen the techs make mistakes. In that same thread you just posted a few posts down, is the Tech, Erin, I just quoted. They are human. However there is no disputing there is no PWM control on a 2 wire fan. So, they really should get their ducks in row.
post edited by HeavyHemi - 2017/05/23 14:33:45
2017/05/23 14:33:39
HeavyHemi I agree over the years we've seen the techs make mistakes. They are human. However there is no disputing there is no PWM control on a 2 wire fan. So, they really should get their ducks in row.
I've seen people say the radiator fan adjusts. I've also seen people say it doesn't.
- Ribbons : 135
2017/05/23 14:34:41
I'm sure you have. It's a two wire fan. Thus no PWM control. Do you accept that as true?
2017/05/23 14:46:11
Yes, I agree there is no pwm control on a two wire fan. Fan speed can still be adjusted on a two wire fan.
- Ribbons : 135
2017/05/23 14:51:06
Indeed. However, there is no DC fan controller on the board. So, that leaves us with static fan speed.
talkischeap
2017/05/23 16:29:39
They will never admit it. The funniest description I've seen so far was something like - it does change speed but it's so slight you might not be able to notice it. I have no idea why they won't say it's static. I'm guessing at some point they said it was variable in marketing material and won't change their stance because of possible legalities. I'm happy either way knowing it's a static speed. I just hate it when people ask and are sent on a wild goose chase. The way it's wired it shouldn't be changing speeds period. A PWM fan of course can run into speed issues because they require a signal wire to tell it what to do... without that signal it seems It's putting nycalex80 fan into a constant Min/Max cycle awaiting a command from the controller, but lacks a signal.
post edited by talkischeap - 2017/05/23 16:54:12
Mother Board: EVGA Z97 FTWCPU: i7 4790k 4.8ghz - EVGA CLC 280mm Closed loopGPU: EVGA 1080 Ti Founders Edition HybridRAM: Kingston HyperX Savage 16GB 2400MHz DDR3PSU: EVGA SuperNOVA 1300 G2SSD: Samsung EVO 500gb X2 / Crucial M4 128gb (OS) / PNY 480gb. HDD: WD Black 2TBSoundcard: Soundblaster Z / Beyerdynamics DT990 Pro 250ohmCase: Phanteks Eclipse P400s Tempered GlassDisplays: Acer x34 Predator w/Gsync Dell 27" WQHD 1440p Ultrasharp / Vizio M series 70" 4k TV
Syed117
2017/05/23 16:53:46
I consider my ears to be pretty good, but I don't know what people are hearing when they say the hybrid fan is loud. Non gaming noise is pretty much silent. My case is on desk and my ears about are less than 2 feet away from it. Obviously the entire case is not silent, there is always a slight hum, but loud? Absolutely not. Mine is mounted at the front of my case as an intake. It definitely gets louder while gaming, but even with any audio source at a minimal volume, it can't be heard. The standard FE fan by comparison sounded like someone was vacuuming in my room.
NZXT S340 Elite - White | GIGABYTE Aorus GA-Z270X-Gaming K7 | Intel i7 7700k | G.SKILL TridentZ - 32GB DDR4 3200 | EVGA GeForce GTX 1080 Ti FE Hybrid | SAMSUNG 960 EVO M.2 500GB | Seagate FireCuda Gaming SSHD 2TB | WD Blue 1TB | EVGA SuperNOVA 750 G2 Gold | Corsair H75 CPU Cooler | LG 34UM67-P | Corsair K95 Platinum Brown | Corsair M65 Pro | Corsair MM800 RGB | Logitech G533 Firestrike - 22,904 - http://www.3dmark.com/fs/12497060 Firestrike Extreme - 14,051 - http://www.3dmark.com/fs/12318664Firestrike Ultra - 7525 - http://www.3dmark.com/3dm/19641581?Timespy - 9706 - [link=http://www.3dmark.com/spy/166
Iluv2raceit
2017/05/24 02:56:07
Listen folks, just use my solution (on page 1 of this thread) and no more worries ;-)
frantic101
2017/05/24 04:12:39
I can't really hear the fan either. In fact my corsair case fans, under light load, are louder, although they are all nearly silent. Any fan noise is hidden out by my TV anyways, even when I set my TV to whisper volume 5 levels.
I also flipped my radiator fan to pull and as above, I, too, had the the 1080 FE and that sounded like a vacuum cleaner.
I guess it's subjective, but I'm very pleased. I'm not going to bother changing fans on something I can't really hear.
