Infidelity
Golden Nugget Introduction:Hi, welcome to my build log. I have been wanting to build a small form factor system for a while and when I saw the new EVGA Hadron my heart skipped a beat. My original plan was to build a red and black themed RoG inspired case and then I saw the MDPC #044. The MDPC #044 was the cleanest and classiest build I've ever seen in my life. The release of ASUS gold themed mother board, and EK gold cpu blocks definitely helped my decision. I took the plunge to build a mini MDPC #044 and bought all the parts needed. Parts List: - i7- 4770k
- Asus z87i-deluxe
- 16GB Corsair Vengeance LP
- Mushking 250gb SSD
- Zotac GTX 670 2gb
Water Cooling Parts List: - EK Supremacy Gold CPU Block
- EK GTX 670 Nickel Plexi
- EK X3 150mm Tube Reservoir
- Black Ice Pro II 240mm radiator
- Scythe Slipstream 120mm x 12mm 2000rpm case fan
- Swiftech MCP35x pump
- Gold Monsoon Fittings
- Primochill Black Tubing
Pictures:
post edited by Infidelity - 2014/01/13 23:52:31
Trocadero1981
Re: EVGA Hadron Golden Nugget (Water Cooled Hadron Air)
2014/01/14 01:27:47
Looks fantastic, even better than the popular black/red builds.
TelFiRE
2014/01/14 02:29:32
That's beautiful! Gorgeous! Very, very well done :) What are your temps/ocs?
Infidelity
2014/01/14 10:07:33
TelFiRE That's beautiful! Gorgeous! Very, very well done :) What are your temps/ocs?
Temps is good at least for a single 240mm radiator and really slim fans. IMHO it is very passable. Clocked at 4.4ghz core/4.2ghz uncore with HT on at 1.25v (Around 33 Idle and 75-77 on full load) GPU is clocked +136/+600 from stock on EVGA Precision and temps never go above 55. I unno if it matters but I live in South Florida which is very hot and humid(I tested the system when the weather was 90's highs and 70's low)..
post edited by Infidelity - 2014/01/14 10:09:47
TelFiRE
2014/01/14 13:55:01
Sheesh yeah, that's really good. Amazing work, I'm incredibly jealous ;P Especially like that you made it happen in the Air, the Hydro just isn't as elegant looking haha.
Sam Nicko
2014/01/15 22:45:21
WOW..That's a B E A U T Y Y Y !! Awesome rig!
Dedaciai
2014/01/16 03:29:43
Intel Core 4770K @4.25GHz Asus Maximus VI Impact Crucial MX200 M.2 SSD 512GB EVGA RTX 3070 XC3 Ultra Corsair Vengance PRO RAM 16GB @ 2400MHz DAN CASE A4 ThermoCool Copper CPU Cooler Corsair SF600 Watt PSU
Infidelity
2014/01/20 19:23:35
kcamrn
2014/01/27 13:22:24
How were you able to mount the rad to the top of the case like that?
Infidelity
2014/01/27 14:27:12
I modded Scythe Slipstreams 120mmx12mm fans so that I could flush it inside the radiator.
WhiteFireDragon
2014/02/02 04:58:41
Holy moly, everything about this looks so sexie. Size, color scheme, watercooling, photography, everything...
Jaig Eyes
2016/05/20 12:32:53
Looks great! I found some other slim fans that might also work, can you specify the amount of room between the mobo and rad?
