toshiro76
Clovis559
Highly recommend the Optimus FTW3 waterblock. Their current in stock version is $378 and has been selling out like hotcakes for the past... every month. It's just recent that you've been able to order it on any other day then Friday.
It seems they have the block in stock but not the rest of the parts. Maybe I could get some EK water block for the radiator, fans, reservoir/pump, fittings, and hose?
If you don't have a loop, EVGa has a Hybrid kit for the FTW3:
https://www.evga.com/products/product.aspx?pn=400-HY-1988-B1For only $118. (Currently not instock, you know the Notify Drill)
My friend actually just installed it within the hour, I bet I could get some temps from him if you go that route.
But if you want to go full performance crazy, EKWB is a decent bet, but before you jump the gun you could blow your brains out with all your options:
Frozencpu.com:
https://www.frozencpu.com/cat/l2/g30/c95/list/p1/Liquid_Cooling-PC_Water_Cooling_Radiators.html (Click that link for going balls deep into a 186 different radiators)
Ekwb.com: (Of course)
Alphacool.com /
https://www.aquatuning.us/ : Great stock alphacool products/horrid shipping costs
titanrig.com (This is my go to atm, competitive pricing with quick cheap shipping options. Also had a problem with a order and in the manner they took care of it, it actually made me want to shop there more).
performance-pcs.com
modmymods.com (Slow website, they had some recent problems with their website host, but I got all my stuff just fine).
Koolance.com
(I've ordered from all of these sites within the year and I would order from all of them again).
I personally would dig and build my own setup. I've never had a radiator though for my loops so I lack that knowledge.
P.s. With Optimus products you get Fuji Poly pads and Kingpin thermal grease, which shows you how much they care about performance. (I should be a salesperson for Optimus but I'm not)
post edited by Clovis559 - 2021/04/27 21:05:16
