EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem
jun3on
Tuesday, June 15, 2021 2:11 PM (permalink)
Hello everyone,
I have a problem related to the built-in RGBs of my new EVGA 3070 FTW3.
The configuration of my equipment is as follows:
MSI MPG B550 GAMING PLUS
AMD Ryzen 5 5600X 3.7GHz
Crucial Ballistix RGB DDR4 3600Mhz PC4-28800 16GB 2x8GB CL16
Corsair RMx Series RM650x 650W 80 Plus Gold Modular
Corsair iCUE 4000X RGB Tempered Glass USB 3.1 RGB Black
Corsair iCUE H115i ELITE CAPELLIX Liquid Cooling Kit
WD Black SN750 NVMe 500GB SSD M.2 PCI Express 3.0
I installed the card and worked perfectly, all the LEDs lit up with the rainbow cycle effect. I updated the VBIOS to be able to use the Resizable Bar technology with the "Precision X1 v1.2.1.0" software version. The card was updated without a problem. While I was using the computer I did not see any problem with the RGBs of the card.
When I turned off & on the computer again, I realized that not all the LEDs were on. Only 2 or 3 LEDs remain on, the rest remain off.
In case it was some problem related to Precision X1, I have tried this:
- Uninstalled precision software
- Deleted folders in c:\Users\xxx\AppDatal\Local\evga-folder
- Restarted the PC
- Ran DDU
- Power off the power supply for 2 3 minutes.
I have also tried uninstalling all the software related to the MSI B550 GAMING PLUS board and the EUCI software in case it could be a software incompatibility.
I have tested the card on my other computer to rule out that it was not a problem of incompatibility with the board and only 2 or 3 LEDs were lit up.
I do not know what else to do :(
Can it be a problem with the firmware update? or can it also be a problem with Precision X1 not saving rgb profiles well with that version of software and firmware?
Thanks for the help in advance!
post edited by jun3on - Tuesday, June 15, 2021 3:39 PM
18 Replies Related Threads
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 2:20 PM (permalink)
    Have you tried turning them all off, save and then set it the way you want it again?
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 2:29 PM (permalink)
    kram36
    Thank you kram36 for the quick response,
    Yes I tried turning off all the leds, I don't remember the name in Precision X1, I think is static Off or something like that.
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 2:32 PM (permalink)
    Reinstall/Update the driver for the card and see if your setting will take then.
    jun3on
    I just realized that neither the video nor the image has been attached to the post
    EDIT: When I have 9 posts I think I can post the video because I have some restrictions for being newbie in the forum
    post edited by jun3on - Tuesday, June 15, 2021 2:41 PM
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 2:34 PM (permalink)
    jun3on
    You don't have enough post to post a link. When you turned off the RGB lights did that work or did it still stay stuck with a few lights on?
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 2:47 PM (permalink)
    kram36
    If you mean nvidia drivers, I only can try to downgrade to another older versión because I have the latest.
    kram36
    When I turn off the RGB lights via Precision X1 works and all the lights go out.
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 10:53 PM (permalink)
    kram36
    I have tried several things, uninstalling / reinstalling / updating drivers and trying older versions of nvidia with DDU and without it, I have also tried different versions of Precision X1 and nothing has worked.
    DerpMagoo
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 10:54 PM (permalink)
    take a vid and upload to youtube and link it
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 10:58 PM (permalink)
    kram36
    Now when I try a lot of different RGB settings with Precision X1 sometimes, and only sometimes when I choose "static off" to turn off the leds, some lights stays on.
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:04 PM (permalink)
    DerpMagoo
    I have a vid with the problem in youtube but I can't post any url. I have restrictions for being a new user.
    glenn37216
    • Ribbons : 9
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:07 PM (permalink)
    Report to evga's support directly. They might tell you to RMA.
    9800x3D
    GIGABYTE X870 AORUS ELITE
    G.SKILL Flare X5 Series AMD EXPO 64GB 6000
    4TB - SAMSUNG 990 EVO SSD
    2X - Crucial MX500 4TB 3D NAND SATA 2.5 Inch Internal SSD
    Montech King 95 Pro Dual Chamber ATX Case
    Cooler Master MasterLiquid 360L
    EVGA - 1300 G2 PSU
    RTX 5080 - COMING SOON
    CULTS3D   PRINTABLES
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:15 PM (permalink)
    glenn37216
    I think it's the best option, I've been struggling for 5 days testing things and there is no way to revive the RGB
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:17 PM (permalink)
    I have exactly the same problem as the OP in this thread with a 3080:
    "EVGA 3080 FTW3 Ultra RGB not working (second post because image did not work)"
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:34 PM (permalink)
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Tuesday, June 15, 2021 11:44 PM (permalink)
    jun3on
    DerpMagoo
    Whats the ending of your video link? I'll post it.
    jun3on
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Wednesday, June 16, 2021 0:03 PM (permalink)
    kram36
    jun3on
    DerpMagoo
    yrVoyrEL7IM
    Thx
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Wednesday, June 16, 2021 0:04 PM (permalink)
    jun3on
    kram36
    jun3on
    DerpMagoo
    yrVoyrEL7IM
    Thx
    No problem.
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA GeForce RTX 3070 FTW3 ULTRA GAMING RGB problem Wednesday, June 23, 2021 0:27 PM (permalink)
    Did you ever figure out your RGB issue? I was looking at a picture I just saved and there is a spot for the number of leds that you can control. Have you checked that?
