MikePao
ASUS PRIME X370-PRO NVIDIA RTX 2070 AMD RYZEN 1700 EVGA CLC 280mm , 400-HY-CL28-V1 I have tried installing EVGA Flow Control but the software will not recognize the CLC unit. ERROR: CPUWB - Device not found I have installed the EVGA CLC 280mm as specified here: I have triple checked the three pin connection to the water pump conn. and the USB power connected to the USB 2 conn. Entered BIOS Advanced Mode/ Monitoring /Ignored: CPU fan and Water pump Fan. Q-Fan Configuration: Disabled - CPU Q-Fan Control and AIO_PUMP/W_PUMP+ Control Chassis Fan Configurations are also disabled Changed 3 PIN connector to: CPU_FAN - ERROR: CPUWB - Device not found uninstall reinstall flow control OPT_FAN - ERROR: CPUWB - Device not found uninstall reinstall flow control W_PUMP - ERROR: CPUWB - Device not found uninstall reinstall flow control AIO_PUMP - ERROR: CPUWB - Device not found uninstall reinstall flow control CHA_FAN1 - ERROR: CPUWB - Device not found uninstall reinstall flow control No other connectors remain to connect?
Re: EVGA Flow Control - CPUWB - Device not found - EVGA CLC 280mm
2022/10/03 20:00:25
jdec112016w
2022/10/03 20:05:57
MikePao ASUS PRIME X370-PRO NVIDIA RTX 2070 AMD RYZEN 1700 EVGA CLC 280mm , 400-HY-CL28-V1 I have tried installing EVGA Flow Control but the software will not recognize the CLC unit. ERROR: CPUWB - Device not found I have installed the EVGA CLC 280mm as specified here: I have triple checked the three pin connection to the water pump conn. and the USB power connected to the USB 2 conn. Entered BIOS Advanced Mode/ Monitoring /Ignored: CPU fan and Water pump Fan. Q-Fan Configuration: Disabled - CPU Q-Fan Control and AIO_PUMP/W_PUMP+ Control Chassis Fan Configurations are also disabled Changed 3 PIN connector to: CPU_FAN - ERROR: CPUWB - Device not found uninstall reinstall flow control OPT_FAN - ERROR: CPUWB - Device not found uninstall reinstall flow control W_PUMP - ERROR: CPUWB - Device not found uninstall reinstall flow control AIO_PUMP - ERROR: CPUWB - Device not found uninstall reinstall flow control CHA_FAN1 - ERROR: CPUWB - Device not found uninstall reinstall flow control No other connectors remain to connect?
If you have all your USB turned on in ASUS BIOS, if you can see it in your device manager, it needs a driver to be recognized. Had ASUS Z270 same issue, had to download driver separately. https://www.evga.com/supp...mp;part_number=Default
EVGA Z690 DARK KINGPIN (BIOS VER. 1.15)Temporarily. For now. Z690 Classified (BIOS VER. 1.15)Windows 11 ProIntel i9-12900kEVGA GeFORCE RTX 3090 Ti FTW3 24G-P5-4985-KRSAMSUNG 980 PRO M.2 SSD, 2TBCORSAIR VENGEANCE C70 caseEVGA 1300 SuperNOVA P+EVGA Z20 RGB KEYBOARDEVGA X20 Wireless MouseDell-27" LED QHD G-SYNC Model:S2716DG.G.SKILL (2 x 16GB) F5-6400J3239G16GX2-TZ5RS
MikePao
2022/10/03 20:07:18
Are you referring to the USB or the three pin?
jdec112016w
2022/10/03 20:19:34
MikePao Are you referring to the USB or the three pin?
BIOS all MB USBs on, connect it to the ASUS pump header, change to DC Volts, not AUTO, running at 100% speed, 12VDC AIO do not like reduced voltage. Your Pump header is on automatically. Fans can be set on a AUTO curve. And preferred both fans to be connected to your MB CPU fan headers. With ASUS BIOS PUMP & fans be set to monitor TEMP of CPU. Not matter with pump at 100%, will matter for fan curve.
post edited by jdec112016w - 2022/10/03 20:24:36
MikePao
2022/10/03 20:36:20
In the BIOS I only have the ability to Ignore or Disable three and four prong conn. Advanced Mode/ Monitoring /Ignored: CPU fan and Water pump Fan. Q-Fan Configuration: Disabled - CPU Q-Fan Control and AIO_PUMP/W_PUMP+ Control I have tried setting the power manually in the bios to 100%. Uninstall reinstall flow control never loads - ERROR: CPUWB - Device not found I have a USB 2.0 conn. and a USB 3.0, I've tried both same result.
MikePao
2022/10/03 20:54:53
Thanks for the link. Followed each step. Still won't even load Flow control just the errors out.
jdec112016w
2022/10/03 21:06:06
MikePao In the BIOS I only have the ability to Ignore or Disable three and four prong conn. Advanced Mode/ Monitoring /Ignored: CPU fan and Water pump Fan. Q-Fan Configuration: Disabled - CPU Q-Fan Control and AIO_PUMP/W_PUMP+ Control I have tried setting the power manually in the bios to 100%. Uninstall reinstall flow control never loads - ERROR: CPUWB - Device not found I have a USB 2.0 conn. and a USB 3.0, I've tried both same result.
It is the 2.0 USB connection, that is what it is made for. You will may have damaged the MB trying to put a 2.0 USB device into that 3.0 USB slot on your MB. That 3.0 USB port on your MB is a header for coming from front panel.
MikePao
2022/10/03 21:10:15
Power consumption: USB 2.0 provides up to 500 mA whereas USB 3.0 provides up to 900 mA. The USB 3 devices provide more power when needed and conserve power when the device is connected but idling. USB 3.0 is backwards compatible—meaning it's designed to work with older USB versions including USB 2.0 and USB 1.1. You can plug a USB 2.0 device into a USB 3.0 port and it will always work, but it will only run at the speed of the USB 2.0 technology.
jdec112016w
2022/10/03 21:12:20
jdec112016w
2022/10/03 21:21:11
MikePao Power consumption: USB 2.0 provides up to 500 mA whereas USB 3.0 provides up to 900 mA. The USB 3 devices provide more power when needed and conserve power when the device is connected but idling. USB 3.0 is backwards compatible—meaning it's designed to work with older USB versions including USB 2.0 and USB 1.1. You can plug a USB 2.0 device into a USB 3.0 port and it will always work, but it will only run at the speed of the USB 2.0 technology.
We talking about the motherboard headers not external plug ins. His MB from looking has 2- USB 2.0 at bottom, 1- 3.0 USB header for front panel.
jdec112016w
2022/10/03 21:30:40
MikePao
2022/10/03 21:36:02
This guy has the exact same issue as I do and they had to replace the pump!
Not happy I just received this yesterday and it's defective?
MikePao
2022/10/03 21:39:13
CLC 280 - Pump not being detected [Screenshots attached] "{forums.evga.com/CLC-280-Pump-not-being-detected-Screenshots-attached-m3292709.aspx}"
jdec112016w
2022/10/03 21:46:13
I will say if he is typing on PC he is using something is making the EVGA AIO work, overheat CPU and shut down if AIO is not working, agreed?
MikePao
2022/10/04 05:03:44
Still trying to get this to work. Device manager now shows Asetek USB Device. I had to manually add the driver from flow control driver folder. I have not seen the CCVI everyone is talking about? Asetek USB Device says device descriptor failed driver provider: Asetek A/S date:10/14/2015 version:6.7.2.0 ERROR: CPUWB - Device not found I saw them talking about a version 6 driver? I'M GOING DEAF TRYING TO FIX MY CLC280 SOMEBODY PLEASE HELP"{}" cannot post web links?? Don't understand why devs couldn't get this fixed after so many problems in the past 5+ years.
MikePao
2022/10/04 05:16:45
//forums.evga.com/I39M-GOING-DEAF-TRYING-TO-FIX-MY-CLC280-SOMEBODY-PLEASE-HELP-m2885551.aspx
lastsamurairick
- Ribbons : 6
2022/10/04 09:38:38
I am going relive this since I am having similar problem. CPUWB - Device not found Ran compatibility test that lot hog wash don't option to try run it in Windows 10 nor 11 only windows 8 and below crap. What funny about this I was running EVGA Flow control just fine for like 6-7 months all sudden wake up at 9am turn PC on and get this CPUWB Device not found tiny massage on screen. Ok so like about 6-7 months ago I had my CLCooler RMA so can't be hardware itself but funny thing is I experience stranger than this. Why would a driver that was working fine before on same OS and nothing change to an extreme level that would cause this issue. I need to comprehend why this driver acting up now. It would those need help too. No horse crap just plain trying give a possible solution. BTW cooler seems to be working fine temps are 32*C and ambient are 75*C so there no Overheating which is cool with me, give me understanding pump is working fine. when gaming temps are like 46*C to 50*C with ambient temps @ 75*C. Not bad at all so seems 100% software related.
post edited by lastsamurairick - 2022/10/04 09:46:09
Intel 10900k @ 3.7 Stock EVGA Z490 Dark EVGA GEFORCE RTX 3070Ti FTW3 G SKILL TRIDENT Z ROYAL 32GB EVGA 1000G5
jdec112016w
2022/10/04 14:19:28
MikePao Still trying to get this to work. Device manager now shows Asetek USB Device. I had to manually add the driver from flow control driver folder. I have not seen the CCVI everyone is talking about? Asetek USB Device says device descriptor failed driver provider: Asetek A/S date:10/14/2015 version:6.7.2.0 ERROR: CPUWB - Device not found I saw them talking about a version 6 driver? I'M GOING DEAF TRYING TO FIX MY CLC280 SOMEBODY PLEASE HELP "{}" cannot post web links?? Don't understand why devs couldn't get this fixed after so many problems in the past 5+ years.
"Asetek USB Device says device descriptor failed driver provider: Asetek A/S date:10/14/2015 version:6.7.2.0" Honestly I have no idea where that came from. I have had my EVGA CLC 280 0n 7 different motherboards throughout the years, never saw that one, in device manager or otherwise. https://www.evga.com/software/ is the software download page, for the CLC280. https://www.evga.com/support/download/ is the driver page for the CLC 280 support page. Should look like above. What you are looking for.
lastsamurairick
- Ribbons : 6
2022/10/04 15:42:35
My issue does not even show in device manager. Just wont run at all EVGA Flow control.
jdec112016w
2022/10/04 16:08:01
lastsamurairick My issue does not even show in device manager. Just wont run at all EVGA Flow control.
lastsamurairick My issue does not even show in device manager. Just wont run at all EVGA Flow control. Then your MB BIOS must be running it. Curious though is the EVGA RGB logo lit up on the AIO??
lastsamurairick
- Ribbons : 6
2022/10/04 16:13:34
Yes AIO is Lit and stay lit even if EVGA Flow control is not running. I came across this youtube video is simple enough to not really link here I did PC shut down and waited 30 sec started PC Voila it's working again without CPUWB Device not found. Huh That means I can't put PC to sleep anymore or just restart if I want it working.?
jdec112016w
2022/10/04 16:28:59
lastsamurairick Yes AIO is Lit and stay lit even if EVGA Flow control is not running. I came across this youtube video is simple enough to not really link here I did PC shut down and waited 30 sec started PC Voila it's working again without CPUWB Device not found. Huh That means I can't put PC to sleep anymore or just restart if I want it working.?
As long as your MB BIOS is running it, I would not lose any sleep over it. MB BIOS has to be running it. Your CPU overheat bigtime if not. It is weird though 7 MBs my part always has worked.
lastsamurairick
- Ribbons : 6
2022/10/07 07:32:19
Update all it took is restart of PC to fix Flow control is being working fine now.
