EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB
likeucare
Wednesday, June 23, 2021 6:38 PM (permalink)
Hey there,
I have recently bought an ABS Legend system from Newegg which comes with the EVGA 3080 FTW3 Ultra Gaming graphics card.
Performance is solid so far in benchmarks.
However, I do have two issues.
First, the RGB does not work at all on the card. It defaults to a rainbow even after installing and reinstalling PrecisionX with LED sync, the moment any LED software begins to run I get 4 flashing red LEDs where the power connectors are located on the card. The LED button in Precision stays grayed out.
I have confirmed I am running 3 separate power cables from my PSU to the GPU and everything is firmly connected. As long as I do not run any of the LED software the blinking will not happen.
The second issue is related to the fans. They erratically spin up very fast (and often) even at idle, making a lot of noise.
I do want to point out that the first time I installed the Precision software, I was prompted to update the GPU firmware (which I did and was given the update success) and I thought the issues would be fixed.
Alas, that is not the case.
I do want to point out that after a second Precision software reinstall, I am now able to see the 3 GPU fans in the main window. Earlier, I could only see 2.
I think it seems to be a firmware problem. Any ways to reflash it somehow? I'd love to avoid RMA!
I contacted ABS support and they think it can be a faulty GPU but they want what EVGA support's feedback on this.
So here I am, stuck in the middle of you! :)
Awaiting your feedback for this EVGA support.
Thanks in advance for your help
Kind regards,
6 Replies Related Threads
    kram36
    The Destroyer
    • Ribbons : 72
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Wednesday, June 23, 2021 6:41 PM (permalink)
    Did you get the latest version of Precision X1? If you did, did it ask you to update the bios?
    Before you update the bios read this thread.
    https://forums.evga.com/Enable-Resizable-Bar-on-EVGA-GeForce-RTX-30-Series-m3248555.aspx
    aka_STEVE_b
    EGC Admin
    • Ribbons : 69
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Wednesday, June 23, 2021 6:42 PM (permalink)
    it sounds like bad software to me - the card is probably running fine otherwise ?
    PX1 is still , unfortunately, not exactly great software....Have you read thru that forum area lately ?
    https://forums.evga.com/EVGA-Precision-X1-f22.aspx
    AMD RYZEN 9 5900X  12-core cpu~ ASUS ROG Crosshair VIII Dark Hero ~ EVGA RTX 3080 Ti FTW3~ G.SKILL Trident Z NEO 32GB DDR4-3600 ~ Phanteks Eclipse P400s red case ~ EVGA SuperNOVA 1000 G+ PSU ~ Intel 660p M.2 drive~ Crucial MX300 275 GB SSD ~WD 2TB SSD ~CORSAIR H115i RGB Pro XT 280mm cooler ~ CORSAIR Dark Core RGB Pro mouse ~ CORSAIR K68 Mech keyboard ~ HGST 4TB Hd.~ AOC AGON 32" monitor 1440p @ 144Hz ~ Win 10 x64
    likeucare
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Wednesday, June 23, 2021 7:07 PM (permalink)
    kram36
    Hi kram36,
    Yes, I've installed the latest EVGA Precision software, the EVGA Precision X1_1.2.2.0.exe.
    The GPU bios was updated with the Precision software. Everything looks green in the Resizable BAR tab as you can see here:
    post edited by likeucare - Wednesday, June 23, 2021 7:21 PM
    likeucare
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Wednesday, June 23, 2021 7:09 PM (permalink)
    aka_STEVE_b
    Hi Steve_b,
    I imagine the card is fine aside of the issues mentioned in the OP.
    I'll have a look at the forum.
    If it is too much hassle, I might have to RMA to ABS.
    Thanks for your help
    likeucare
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Thursday, June 24, 2021 5:58 PM (permalink)
    Hi,
    A little update.
    Without any changes lately, I opened up PX1 software this morning and again, PX1 only shows 2 fans out of the 3.
    Is there anything that I could do... reflash the Bios maybe?
    Thanks!
    likeucare
    Re: EVGA 3080 FTW3 Ultra Gaming 4 red blinking led when controlling RGB Friday, June 25, 2021 4:08 PM (permalink)
    RMA'ed the PC.
