mbeh4sh
Hi, I've run into a challenge with my 1300 G2 PSU. When I connect CPU1 or CPU2 to motherboard 8pin (JPWR2) pc is not starting. First I couldn't figure out what was causing so removed all cables except 24pin cable and connected all components one by one until it stopped and looks like it's CPU1/CPU2. I have tried both CPU1 and CPU2 and with different cables. As soon I connect 8pin (JPWR2) I hear a click sound then nothing more. What could this be ? Is it the CPU1/CPU2 port on PSU or 8pin (JPWR2) on motherboard ? Rgs
![](//www.evga.com/community/modsRigs/images/sm_mods_off.gif)
Re: EVGA 1300 G2 .Connecting CPU connector to motherboard 8pin (JPWR2). Click sound,not st
2017/05/16 13:16:28
- Ribbons : 282
2017/05/16 13:22:35
The EVGA 1300 G2 only comes with two CPU cables, what other cables did you test with? Let's hope you did not use a PCIe GPU Power Cable. Take your MB out of the Computer Case and test on a table top. You can only use the Cables that came with your G2 or other EVGA G2/3 P2 or T2 Cables. Do Not Use any Corsair Cables.
post edited by bcavnaugh - 2017/05/16 13:26:34
- Ribbons : 282
2017/05/16 13:28:03
Information about your Computer will allow members to help you. This info will really help other Forum Members to help you. Computer Case: Make: Model: Motherboard: Make: Model: Bios Version: Is Bios Current Yes or No. CPU: Model: Settings: Memory: Make: Model: Settings: GPU/Video: Make: Model: Driver Version: AGE: GPU/Video: Make: Model: Driver Version: AGE: Monitor: Make: Model: Video Cables Used: Type: Versions: AGE Monitor: Make: Model: Video Cables Used: Type: Versions: AGE TV If Used: Make: Model: Video Cables Used: Type: Versions: AGE PSU: Make: EVGA Model: 1300 G2 AGE: Other PCI/PCIe installed Devices: Make: Model: Slot Number Installed: Driver Version: Other PCI/PCIe installed Devices: Make: Model: Slot Number Installed: Driver Version: OS: Version: Service Pack Level: Windows/Patch Level:
mbeh4sh
2017/05/16 13:45:58
bcavnaugh The EVGA 1300 G2 only comes with two CPU cables, what other cables did you test with? Let's hope you did not use a PCIe GPU Power Cable. Take your MB out of the Computer Case and test on a table top. You can only use the Cables that came with your G2 or other EVGA G2/3 P2 or T2 Cables. Do Not Use any Corsair Cables.
I have only used CPU cables that came with the PSU. Motherboard is an MSI z170A Gaming Pro Carbon. At the moment I only have connected 24pin to JPWR1 and CPU1 cable to 8pin (JPWR2) on motherboard. If I remove 8pin it starting as it should. I just have the motherboard and psu on an wooden table.
2017/05/16 13:59:28
mbeh4sh
Sounds like you may have a faulty cable. Converting a 6-pin pci-e to an 8-pin atx will help you narrow things down.
mbeh4sh
2017/05/16 14:55:02
mbeh4sh
The other brand new PSU cabel did not make any difference that came with package, I tried with another motherboard also. Two new faulty cables sounds crazy. The result is pretty much the same, the only thing that differs is that the fan starts and stops real quick. It looks like a normal start for 1 sec. It's like it needs that little extra power to make it going. On the first motherboard it's only click sound. Disconnecting 8pin on motherboard both starts. How does service and replacement looks like ? (Norway, near Oslo) Rgs
- Ribbons : 282
- Ribbons : 282
2017/05/16 14:58:35
What do you have for a CPU Cooler Installed? What CPU is installed on your Motherboard? Best of luck
post edited by bcavnaugh - 2017/05/16 15:19:02
mbeh4sh
2017/05/16 15:13:36
bcavnaugh You have two cables? Both cannot be bad?
24pin is working. Its the 8pin what is causing it not go start.
mbeh4sh
2017/05/16 15:15:18
Intel® Celeron® Processor G3900 (2M Cache , 2.80 GHz) and fan that came with box.
2017/05/16 15:52:10
mbeh4sh The other brand new PSU cabel did not make any difference that came with package, I tried with another motherboard also. Two new faulty cables sounds crazy. The result is pretty much the same, the only thing that differs is that the fan starts and stops real quick. It looks like a normal start for 1 sec. It's like it needs that little extra power to make it going. On the first motherboard it's only click sound. Disconnecting 8pin on motherboard both starts. How does service and replacement looks like ? (Norway, near Oslo) Rgs
Both motherboards are MSI z170A Gaming Pro Carbon's?
post edited by Sajin - 2017/05/16 16:04:01
mbeh4sh
2017/05/16 23:40:22
Yes both are same model but different revision. One of them are new and the other one year old. I will try to get my hands of another psu to troubleshoot. I want to pinpoint what is causing it.
mbeh4sh
2017/05/17 03:41:20
After more digging it might not be the PSU actually. I connected ram, cpu fan, ssd and 24pin and 8pin to motherboard and rig it's starting. So perhaps it's the cpu that's causing it. When I attach the cpu it's not starting that's for sure.
2017/05/17 09:57:44
Running without the cpu in the socket is pretty much the same thing as running withtout the 8-pin connected. Let us know how the new psu works.
mbeh4sh
2017/05/17 12:20:05
Sajin Running without the cpu in the socket is pretty much the same thing as running withtout the 8-pin connected. Let us know how the new psu works.
Yes, I let you know. If I try to start with cpu in socket it won't start, when I remove cpu from socket it starts. 8pin connected in both cases.
mbeh4sh
2017/05/21 01:37:33
A new CPU solved the issue :)
2017/05/22 18:18:18
mbeh4sh A new CPU solved the issue :)
