EVGA 1080 Ti SC2 not hitting Power limit
leFlynn
2018/11/13 09:08:44 (permalink)
I noticed that my 1080ti doesnt utilize its power limit as it should while doing some thermal tests since i have a morpheus lying around and wanted to experiment a bit with it. BUT even under 20 minutes of any load i could throw at it the temps never exceeded 60c in a about 20c room. The case has ok airflow so the card should be getting way warmer since the fans span at about 50% max. Checking GPU-Z it said that my Power Limit was averaging about 80%. I had everything stock at that time. The GPU boosted to max 1930 MHz and in Timespy hit about 8400 points so lower than it should.
My System:
8700k @ 4.7Ghz
16Gb of Ram @ 2666Mhz
EVGA z370 Classified K
EVGA Supernova 750 G1+
Playing in either 1440p @144hz or 2160p @60hz so shouldnt be a resolution issue
What i already tried:
Lifting the Powerlimit JUST IN CASE did nothing
Lifting the Voltage since GPU-Z said i hit the Voltage Limit GPU boosted a tad higher and the power draw grew a bit but still not exceeding the 90% Mark
Checking all settings in the Nvidia control Panel for Power settings aswell as the Windows Power plan
Reinstalling the Driver with DDU
Overclocking everything ( after 60Mhz+ on the core everything started lagging and crashing giving me 1980 MHZ max but still underperforming)
Tried playing with the memory speed if either over or underclocking did any good and nope it actually let the core drop the clocks to 1898
Resetting all things in Precision X and the same things with Afterburner after that.
Tried the K-Boost button on Precision X
Checked All the Powerconnectors
Also restarting a few times obviously
Even Furmark in 4k didnt manage to exceed the 62c mark tho it managed to let GPU-Z say power limit instead of the Voltage limit.
At this point i am really confused to what i could have missed. Note that the Card is only 3 months or so old and had never been OCd before that.
Any help and advise would be appreciated. (And sorry for the grammar ofc)
Attached are two GPU-Z screenshots after about 5 minutes of heaven in extreme in 1440p
13 Replies Related Threads
    the_Scarlet_one
    formerly Scarlet-tech
    • Ribbons : 79
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 09:15:55 (permalink)
    Did you buy the card brand new or used? I have a reason for asking and just want to verify something if possible.
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 09:18:14 (permalink)
    New. I Actually won it directly from EVGA this summer. Shipped on August and arrived here in September. Hope that helps
    EVGATech_AdamB
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 09:34:52 (permalink)
    What does the power % show as in PrecisionXOC? If you enable the OSD and then make sure the power % graph is enabled then you should be able to monitor it in real-time. Also, what is the graphics card actually benchmarking at? You can download a free version of 3D Mark from https://benchmarks.ul.com/downloads/3dmark.zip. If you run either Time Spy or Firestrike, click on the "compare results online" and then post the results URL to help us see if it is underperforming.
    Like our service? Please provide feedback for us at the link HERE
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 10:04:05 (permalink)
    I just tried to run the test a few times but the Graphics Test 2 never works so i just have the FPS for GT1. Always had problem with 3DMark :/. I am hitting 54.8 FPS there while the FE version tested by Guru3D already hits 61.56 meaning that its performing more than 10% worse in that test.
    The EVGA Precision X was set to 100 and i clicked on default twice before the tests. GPU-Z still claims about 75% AVG and the reported Precision power numbers spiked quite drastically from 60 to 115 i'd guess about 90 avg. there.
    Best regards
    Source (  )
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 10:10:56 (permalink)
    since the link didn't work out apparently ( i am a forum Noob)
    thats their score (
    As noted i hit a graphics score of 8500 this afternoon before 3DMark decided to not work properly anymore So yeah about 1000 points equaling to about 10% again.
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 12:46:44 (permalink)
    388.13 is one of the worst drivers you could be using. I'd recommend updating to at least 399.24.
    To hit your max power limit I would recommend that you overclock your gpu to your max stable overclocks on both the core & memory, and then run unigine superposition on the 8k optimized preset. Doing that will definitely make you hit your power limit.
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 13:26:54 (permalink)
    Thanks for the tip!
    Updated to 416.81 nothing really changed. Can clock to a maximum of +65 with funnily the voltage still at 0% but still the card doesnt exceed 60c with about 50% fan speed. The memory can get clocked ridiculous high up to +600 with ease. Whether that improved performance or started degrading it i could tell yet but still doesnt utilize the power it could. GPU-Z still claims the Voltage as the performance limiter.
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 13:38:54 (permalink)
    On the stock vbios there will always be a performance limiter such a power, voltage, or temp.
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 13:51:57 (permalink)
    but shouln't it be getting a bit warmer than that? and the performance numbers dont really fit either. thats why i am confused. And especially since it was way better just a week ago. There i hit 10000 points Timespy with 70ish degrees on the core.
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 14:01:07 (permalink)
    Yep, I see what your problem is...
    That should read x16 3.0 when under a load.
    leFlynn
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 14:50:13 (permalink)
    So that actually might have gotten it to work! Thanks for that. i dont know how tho. I reseated the card checked all the power connectors and then GPU-Z saw the 3.0 x16 as it should. It is really cold still but atleast performs as other rather slower 1080 tis in Superposition. Aswell that it ocs rather well... poorly. at +55 i am stuck but atleast it does somewhat what it should. hope this is my final word to that.
    Thanks again for the support
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 14:51:10 (permalink)
    the_Scarlet_one
    • Ribbons : 79
    Re: EVGA 1080 Ti SC2 not hitting Power limit 2018/11/13 15:55:39 (permalink)
    Oh, misread part of that.  I was thinking that it showed your card at x16 1.1, not x1 3.0.. big difference there!  I need to start using my computer, as my phone screen clearly isn't big enough.
    post edited by the_Scarlet_one - 2018/11/13 17:26:35
