EVGA 1070 max power draw?
chap34
Friday, February 10, 2017 2:25 PM (permalink)
EVGA says the max power draw on a 1070 is anywhere from 150w to 215w depending on the card. With Precision X you can select 112% as max power.
This would make me think for the 1070 FE, the max draw would be 168w(150*1.12).
Could anyone explain why this article has the draw being up to 291w?! http://www.overclockersclub.com/reviews/nvidia_geforcegtx_1070_overclocking/7.htm
Thanks!
4 Replies Related Threads
    Xarzi
    Re: EVGA 1070 max power draw? Friday, February 10, 2017 2:48 PM (permalink)
    Hey may be measuring the draw of the system at the plug. That would show the entire systems usage. It's really hard to say because he doesn't state how he is measuring the power draw on the card specifically.
    evgauser28764
    Re: EVGA 1070 max power draw? Friday, February 10, 2017 3:18 PM (permalink)
    according to the bios settings read by techpowerup, the master bios has 208w max while the slave bios has 226w max.
    DeathAngel74
    • Ribbons : 10
    Re: EVGA 1070 max power draw? Friday, February 10, 2017 4:28 PM (permalink)
    The 1070 SC is also 150W-168W (150*1.12). Other cards, like the ASUS STRIX 1070 OC is 166.1W-199.32W (166.1*1.20), Palit Super Jetstream is 195W-225W (195*1.15), etc.
    Although, there is a lot of debate that the 6-pin can provide more than 75W-105W+ and the 8-pin can provide more than 150W-200W+. I don't think it's safe or worth frying your card.
    The 1070 reference cards can theoretically handle up to 225W from a single 8-pin+PCI-E slot.
    150W(on 8-pin from PSU)+75W(from PCI-E slot)=225W max power draw.
    150W (from 8pin)+75W (from 6-pin)+75W(from pcie slot)=300W max power draw.
    Example from GTX 970 FTW+ power table w/1*6-pin + 1*8-pin:
    post edited by DeathAngel74 - Friday, February 10, 2017 5:01 PM
    Carnage specs:
    Motherboard: ASUS ROG STRIX X299-E GAMING | Processor: Intel® Core™ i7-7820x | Memory Channels#1 and #3: Corsair Vengeance RGB 4x8GB DDR4 DRAM 3200MHz | Memory Channels#2 and #4: Corsair Vengeance LPX Black 4x8GB DDR4 DRAM 3200 MHz | GPU: eVGA 1080 TI FTW3 Hybrid | PhysX: eVGA 1070 SC2 | SSD#1: Samsung 960 EVO 256GB m.2 nVME(Windows/boot) | SSD#2&3: OCZ TRION 150 480GB SATAx2(RAID0-Games) | SSD#4: ADATA Premier SP550 480GB SATA(Storage) | CPU Cooler: Thermaltake Water 3.0 RGB 360mm AIO LCS | Case: Thermaltake X31 RGB | Power Supply: Thermaltake Toughpower DPS G RGB 1000W Titanium | Keyboard: Razer Ornato Chroma | Mouse: Razer DeathAdder Elite Chroma | Mousepad: Razer Firefly Chroma | Operating System#1: Windows 7 SP1 Ultimate X64 | Operating System#2: Linux Mint 18.2 Sonya (3DS Homebrew/Build Environment)
    EllBrad
    Re: EVGA 1070 max power draw? Friday, February 10, 2017 6:16 PM (permalink)
    EVGA SC uses the reference (founders edition) board with a 4+1 phase design and is rated for 150-170 watts. While the FTW on a custom board (10+2 phase) is max 215 watts
    i5 4690k @ 4.5ghz | EVGA GTX 1070SC @ 2.1ghz | 16gb DDR3 @ 1866mhz | Acer XB270HU
