EK Water Blocks Unveils EVGA XC3 RTX 3070 Water Block | TechPowerUp EK, the leading computer cooling solutions provider, is launching its premium high-performance GPU water block for the EVGA XC3 edition of the NVIDIA GeForce RTX 3070 graphics cards. The new water block is named EK-Quantum Vector XC3 RTX 3070 D-RGB and is exclusively engineered for the EVGA XC3 RTX 3070 GPUs.
This high-performance GPU water block for the EVGA XC3 RTX 3070 graphics cards actively cools the GPU, top-facing VRAM, and inductors, and MOSFETs in the VRM section. It also features optimized flow paths that reduce hydrodynamic instabilities and vortexing (dead spots) inside them for improved performance. An Open Split-Flow cooling engine design is implemented, which proved to be a superior solution for GPU water blocks. It is characterized by low hydraulic flow restriction, meaning it can be used with weaker water pumps or pumps running on low-speed settings and still achieve top performance. The jet plate and fin structure geometry have been optimized to provide even flow distribution with minimal losses and optimal performance when used in any given coolant flow orientation, unlike some currently available products on the market.
The base of the water block is CNC-machined from nickel-plated electrolytic copper, while its top is CNC-machined either from glass-like cast acrylic or durable black POM acetal. The 2nd-generation Vector GPU water blocks also feature plexi and acetal terminals that match the top cover material. The watertight sealing is ensured by high-quality EPDM O-rings, while brass standoffs are already pre-installed and allow for a safe and easy installation procedure.
Current Compatibility List for EK-Quantum Vector XC3 RTX 3070
- EVGA GeForce RTX 3070 XC3 BLACK GAMING
- EVGA GeForce RTX 3070 XC3 GAMING
- EVGA GeForce RTX 3070 XC3 Ultra Gaming
D-RGB Lighting on the EK-Quantum Vector XC3 RTX 3070 D-RGB
The aesthetic end-piece is housing the addressable D-RGB LED strip. This water block boasts a total of 12 individually addressable RGB LEDs on the Acetal and 5 on the Plexi version. It is compatible with popular RGB sync technologies from all major motherboard manufacturers. The arrow marking on the 3-pin D-RGB LED connector is to be aligned with the +5V marking on the D-RGB (addressable) header.
Backplate for the XC3 RTX 3070 Water Block
EK recommends the purchase of a retention backplate, which improves the overall aesthetics of your graphics cards, and also provides additional passive cooling for the GPU core, backside VRAM on the cards, and backside of the printed circuit board VRM section. They are CNC-machined and come in both black-anodized aluminium and nickel-plated aluminium finish.
Availability and Pricing
The EK-Quantum Vector XC3 RTX 3070 full-cover water blocks and backplates are made and assembled in Slovenia, Europe, and are available for pre-order through the EK Webshop and dedicated reseller network. The water blocks and backplates are expected to ship out in mid-May 2021.
What a fantastic looking waterblock with equally great looking RGB.
