EK Water Blocks Unveils EK-AC Radeon RX 5700 +XT D-RGB Water Block
  • Ribbons : 86
2019/10/15 22:24:22 (permalink)
https://www.techpowerup.com/260157/ek-water-blocks-unveils-ek-ac-radeon-rx-5700-xt-d-rgb-water-block
EK, the leading premium computer liquid cooling gear manufacturer, is releasing the EK-AC Radeon RX 5700 +XT D-RGB water block as a part of the Fluid Gaming lineup. This water block is compatible with reference design AMD Radeon RX 5700 and 5700 XT graphics cards as well. One of the current best-buy graphics cards just got a best-buy block made of aluminium to make the ultimate combo for budget-oriented buyers that value silence and maximum performance with enhanced reliability and longevity.
This aluminium water block directly cools the GPU, 8 GB of GDDR6 memory, and VRM (voltage regulation module) as cooling liquid is channeled directly over these critical areas. The base of the block is made of high-quality aluminium while the top is made of glass-like acrylic material. The entire water block is lit up with D-RGB (Addressable) LED. Sealing is ensured by high-quality EPDM O-Rings with the standoffs already pre-installed allowing for a safe and easy installation procedure.
The EK-AC Radeon RX 5700 +XT D-RGB blocks are made in Slovenia, Europe and are available for pre-order through the EK Webshop or EK Partner Reseller Network. They will start shipping on Wednesday, the 23rd of October 2019! In the table below you can see manufacturer suggested retail price (MSRP) with VAT included.
EK-AC Radeon RX 5700 +XT D-RGB: 109.90€
EK waterblocks always look great and if you watercool your rig this is a fantastic addition if you have an AMD RX 5700 video card that is compatible.
2 Replies Related Threads
    • Ribbons : 123
    Re: EK Water Blocks Unveils EK-AC Radeon RX 5700 +XT D-RGB Water Block 2019/10/16 05:49:12 (permalink)
    "This aluminium water block directly cools the GPU, 8 GB of GDDR6 memory, and VRM (voltage regulation module) as cooling liquid is channeled directly over these critical areas."
    Just make sure your loop is compatible with aluminum
    GTXJackBauer
    • Ribbons : 48
    Re: EK Water Blocks Unveils EK-AC Radeon RX 5700 +XT D-RGB Water Block 2019/10/16 13:33:13 (permalink)
    +1  They need to come out of the gates with big caps stating this because I feel some people will end up ruining their loops.  smh  I always thought this is the elephant in the room for EK.  Never understood the idea of adding a aluminum line (Cheaper) just to make a few more bucks...
    LMD3DNZM9LGK8GJ
