EK Water Blocks Announces Active Backplate for RTX 3090 Founders Edition
  • Ribbons : 86
2021/06/16 05:24:12 (permalink)
EK Water Blocks Announces Active Backplate for RTX 3090 Founders Edition | TechPowerUp
EK, the leading computer cooling solutions provider, is introducing a long-awaited special edition Active Backplate for the NVIDIA GeForce RTX 3090 Founders Edition GPUs. The EK-Quantum Vector FE RTX 3090 D-RGB Active Backplate is made to complement the existing EK-Quantum Vector FE RTX 3090 - Special Edition water blocks and actively cool the backside of a Founders Edition NVIDIA GeForce RTX 3090 GPUs.
The EK-Quantum Vector FE RTX 3090 active backplate links the water block and active backplate with a new terminal, which replaces the original terminal that comes with your water block. As a result, the whole enclosure requires only one inlet and one outlet, which removes unnecessary additional tubing and reduces clutter. It is the ultimate aesthetic and performance solution that sandwiches your GPU between two water blocks, allowing for maximum cooling.
The new terminal has 4 ports, two direct (end ports) and two through port-style (either on the bottom or top of the terminal). It can be flipped to have the through ports either on the side of the water block or active backplate, but the flow cannot be reversed. The inside of the water block follows the stock backplate aesthetics with ribs that span the entirety of the block.
The brand new Vector Active Backplate directly cools all PCB hotspots found on the backside of the GPU core and VRM, but especially the rear-mounted VRAM. Cooling liquid is channeled over all these critical areas. These newly developed active backplates require at least one slot above them to be empty as they stand 16.8 mm tall from the PCB across the whole GPU.
The base of the active backplate is CNC-machined out of nickel-plated electrolytic copper, while the top is CNC-machined out of glass-like cast acrylic. Just like on the water block itself, the external enclosure does not have any contact with the coolant. It is machined out of a thick solid piece of aluminium, which is afterward anodized into black or gray color, depending on the version. The watertight seal is ensured by high-quality EPDM O-rings.
Availability and Pricing
The EK-Quantum Vector FE RTX Active Backplate is made in Slovenia, Europe, and is already available for pre-order through the EK Online Shop and Partner Reseller Network. They are expected to start shipping in early September 2021.
  • EK-Quantum Vector FE RTX 3090 Active Backplate D-RGB - Silver SE 249.90€
  • EK-Quantum Vector FE RTX 3090 Active Backplate D-RGB - Black SE 249.90€
EK's quality is superior, but the pricing is a bit high in my opinion.
0 Replies Related Threads
