EK Creates Workstation-Grade AM5 CPU Water Blocks
  • Ribbons : 86
2023/02/15 02:20:34 (permalink)
https://www.techpowerup.com/304811/ek-creates-workstation-grade-am5-cpu-water-blocks
EK, the leading liquid cooling gear manufacturer, is announcing the availability of two high-performance liquid cooling solutions for the AMD Ryzen processor family based on the AMD AM5 socket. These single-socket AM5 water blocks are available in both the standard and the 1U-compatible format designed specifically for server racks.
EK-Pro CPU WB AM5 Ni + Inox
Being a dedicated workstation-grade water block for AMD AM5 processors, the EK-Pro CPU WB AM5 Ni + Inox water block features two standard G1/4" threaded ports on its top. Built with performance, reliability, serviceability, and no compromises in mind, this enterprise-grade cooling solution is intended for desktops, workstations, and taller server racks. The water block's top is CNC-machined from durable black POM Acetal, and the hold-down bracket is made of laser-cut stainless steel.
EK-Pro CPU WB AM5 Rack Ni + Inox
The EK-Pro CPU WB AM5 Rack Ni + Inox is a dedicated server-grade water block with 1U rack compatibility. Developed explicitly for AMD AM5-socket processors, it features four G1/8" ports split into two sides for easier tube management and ultimate compatibility with low-profile racks. This enterprise-grade cooling solution has been designed and built with a focus on performance, reliability, and serviceability, seeking no compromises. The top is CNC-machined from durable black POM Acetal, and the hold-down bracket is made of laser-cut stainless steel.
Availability and Pricing
The EK-Pro CPU WB AM5 water blocks are made in Slovenia, Europe, and are available for pre-order through the EK Webshop. These products are expected to ship out in late February 2023. The table below shows the manufacturer's suggested retail price (MSRP), VAT included.
Looks like enterprise water cooling is increasing in popularity.
1 Reply Related Threads
    • Ribbons : 123
    Re: EK Creates Workstation-Grade AM5 CPU Water Blocks 2023/02/15 06:42:14 (permalink)
    I like the side ports
