Wooohah
Got a bit of a weird problem. I'm uploading a copy of my Dxdiag for Battlefield troubleshooting and I noticed that the "switch to 64x" button is not present, which means my copy of Windows is 32bit. That makes absolutely no sense at all, I'm certain my hardware is meant for 64x, I'm certain I'm running on 64 bit windows, Dxdiag even shows my Operating system as 64 bit. System information also shows me running 64 bit.
Whats wrong here...?
Thanks
CPU: i7 6700k GPU: EVGA GTX 1080 FTW Motherboard: ASUS Z170-ProRam: (2x8GB) 16GB Gskill TridentZ @3200mhzPSU: EVGA 750W G2Storage: 250GB Samsung SSD, 1TB Seagate HDD 240GB Mushkin SSDCooling: 4x 120mm Noctua NF-S12A, 1x 140mm Corsair, Corsair H55 water cooler w/ 2x Corsair 120mm fans.Case: Corsair 400C (Clear/ White) Display: ASUS PG279Q (1440P 165hz IPS Gsync)Sound: Sennheiser HD558 w/ Behringer HA400 Amp.
Re: Dxdiag (DirectX Diagnostic) Running in 32bit on a 64bit system w/ 64bit Win 10?
2017/01/24 17:08:10
It's probably already running the 64-bit dxdiag. Run dxdiag, open task manager, select details tab, look for dxdiag.exe, under the platform column it should read 64 bit.
Wooohah
2017/01/24 18:58:23
I'm a bit worried right now... I'm looking at the Task manager, Dxdiag doesn't show the version.
However when I scroll down and look at other processes... they're all running in 32-bit... Chrome, Bitdefender, Punkbuster, IAStorDataSvc (which should be a windows process).
I'm looking in System information and its showing me running a "64 bit system". Dxdiag is showing my Operating system as Windows 10 Home 64 bit....
I'm really confused...
2017/01/24 19:01:50
Wooohah I'm a bit worried right now... I'm looking at the Task manager, Dxdiag doesn't show the version.
Strange.
- Ribbons : 282
2017/01/24 19:06:31
Windows 7 DX11 64Bit C:\WINDOWS\SysWOW64\dxdiag.exe 32Bit C:\WINDOWS\System32\dxdiag.exe Both are 32Bit  Window 10 DX12
post edited by bcavnaugh - 2017/01/24 19:21:04
Wooohah
2017/01/24 19:08:35
bcavnaugh 64Bit C:\WINDOWS\SysWOW64\dxdiag.exe 32Bit C:\WINDOWS\System32\dxdiag.exe
I have Dxdiag in both SysWOW64 and System32...
- Ribbons : 282
2017/01/24 19:10:52
Wooohah
bcavnaugh Windows 7 DX11 64Bit C:\WINDOWS\SysWOW64\dxdiag.exe 32Bit C:\WINDOWS\System32\dxdiag.exe Both are 32Bit
 Window 10 DX12
Yes I am Old and I am Slow in typing and Posting give us old folk a little extra time. It takes time to create the image go to a different computer transfer files and so on.
post edited by bcavnaugh - 2017/01/24 19:27:40
Wooohah
2017/01/24 19:11:38
I'm doing a bit of reading online and apparently its normal to have a lot of applications running in 32-bit, I was confused because even my flash player was 32-bit. However I'm still rather confused about DirectX, or if there's anything wrong in my situation.
Weird, so if I run Dxdiag in SysWOW64 it shows the button of "Run in 64-bit" It shows "32-bit unicode" in that situation. If I click "Run in 64-bit" it restarts and shows "64-bit unicode"
It showed "64-bit unicode" before when the button was missing, so I'm going to go ahead and assume it was already running 64-bit by default.
Wooohah
2017/01/24 19:14:46
When I run the one in System 32 it runs in 64-bit, When I run the one in SysWOW64 it runs as 32-bit.
- Ribbons : 282
2017/01/24 19:42:32
Wooohah When I run the one in System 32 it runs in 64-bit, When I run the one in SysWOW64 it runs as 32-bit.
You will find that very little apps are running Only x64. Most Process have both x64 and x86 back ends as you have seen in your Task Manager with *32 next to the process. You will sometimes see two program running at the same time on 64Bit the other 32Bit like the Process iexplore.exe and iexplore.exe*32 WmiPrvSE.exe and WmiPrvSE.exe*32 and so on. This is how it has been since Windows XP 64 "Whats wrong here...? " Nothing is wrong here.
post edited by bcavnaugh - 2017/01/24 19:49:27
Wooohah
2017/01/24 20:00:09
Thank you :) I'm sorry, i've been having non-stop issues with computers for the past 6 months, I'm a bit paranoid about every little thing that doesn't seem right.
I was able to learn how to see what bit the programs were running at in the task manager. Most of them were running 64-bit with a few of them running 32-bit.
I suppose with DirectX diagnostic, it just happened to open 64x automatically and the instructions online were likely a bit outdated.
2017/01/24 20:10:50
☄ Helpfulby XrayMan 2017/01/25 20:50:04
Should look like this...
Wooohah
2017/01/24 20:43:53
Thank you! Yep, that's exactly how it looks for me too. Glad there's nothing wrong haha
