Do i need a heat sink AND a fan?
raz3r_a99
2010/04/27 17:49:47 (permalink)
Alright so i need a new GPU. I have a ATI rage theater or X-1950 GPU i want to put in. im Currently running a Nvidia gt 220. My problem is the ATI needs the fan it has on it to be plugged in. but it has a huge copper heat sink on it and several other small one all over it. My motherboard only has like one fan plugin with is already being used by the Case fan. My question is should the GPU be fine without the fan on it being plugged in or should i unplug the case fan and plug in the GPU fan?
here is a pic of the Ati
and here is my case, small i know
10 Replies Related Threads
    Halo_003
    • Ribbons : 51
    Re:Do i need a heat sink AND a fan? 2010/04/27 18:19:05 (permalink)
    You'll want that fan turned on, or when it gets a 3d load it'll really heat up. If you don't have an available fan plug, use this:
    http://www.sidewindercomp..s.com/akakcaadfor4.html
    i7 7700K - ASUS Maximus IX Apex - 16GB G.Skill TridentZ RGB 3466MHz C16 - 5700 XT 50th Anniversary
    dlb134
    Re:Do i need a heat sink AND a fan? 2010/04/27 18:25:03 (permalink)
    Isn't the gt 220 better than the x1950?
    raz3r_a99
    Re:Do i need a heat sink AND a fan? 2010/04/27 19:07:48 (permalink)
    is it rlly?
    cuz im playing Battlefeild Bad company 2 and it heats up to 68 C
    and the frame starts to glitch
    dlb134
    Re:Do i need a heat sink AND a fan? 2010/04/27 19:42:49 (permalink)
    hmm manually adjust the fan speed.
    raz3r_a99
    Re:Do i need a heat sink AND a fan? 2010/04/27 19:50:34 (permalink)
    its running at 90 percent fan speed now
    so is a ATI radeon X1950 XT better than a Nvidia Geforce 220?
    the_real_maverick
    Re:Do i need a heat sink AND a fan? 2010/04/27 19:51:45 (permalink)
    Ya, you need that fan on for sure.  That GPU will get very hot under load and that fan is going to need to be moving air over that heatsink.  Like other have said, try to get a 4 pin splitter
    Intel i7 6700K 4.0Ghz/ EVGA 980TI Classified / 16GB G.Skill DDR4 2400 / Gigabyte G1 gaming mobo / Western Digital Black 1 TB HDD/ Mushkin 1TB SSD / Corsair 750W PSU / 27" Asus ROG PG279Q IPS 1440 G-sync 165hz / Razer Deathadder / Logitech G810 Spectrum / Windows 10 64bit / K70 RGB
    http://www.heatware.com/u/70338
    raz3r_a99
    Re:Do i need a heat sink AND a fan? 2010/04/27 19:56:10 (permalink)
    yeah
    but i mean someone said the GT 220 is better than the Ati x1950 XT?
    so why use it if its worse?
    wich is better in your guy's opinion
    Ati Radeon X1950XT OR Nvidia Geforce GT 220?
    dlb134
    Re:Do i need a heat sink AND a fan? 2010/04/28 12:43:38 (permalink)
    Before you do anything get the latest drivers from nvidia's website. I'm pretty sure the gt220 is better.
    lehpron
    Regular Guy
    • Ribbons : 191
    Re:Do i need a heat sink AND a fan? 2010/05/01 14:27:18 (permalink)
    You GPU takes precidence as it will overheat much more quickly than the case as a whole; your system can live without the rear casefan running, your GPU may not.  Only if you had a large heatsink such that the extra mteal fin surface area made up for a lack of active circulation, for instance from passive or ambient circulation already in the case from other coolers, would you not need a fan.
    But you definitely neeed a heatsink of some kind.  The die itself is too small a surface to get rid of the heat itself, the whole point of the heatsink is to increase that heat dissipation surface area as the heat pressure conducts through the sink.
    raz3r_a99
    Lower end doesn't progress that quickly since those folks don't demand as much the higher-end crowd.  So a GT220 isn't much faster than a 9400GT or 8500GT or 7600GT.  The AMD/ATI counterpart to 7600GT was Radeon X1600.  But only you can see for certain if your X1950XT is better or worse than GT220 by testing it out -- or find reviews that happen to make daisy-chained tests of cards mentioned.  You're not going to find a review where someone compares a new low-end to a 4yr old high-end.
    Most who bought higher-end then will buy higher end now, for the price you paid for a Radeon X1950XT, that's about a Radeon HD5850/5830 now (or like the upcoming GeForce GTX460).
    For Intel processors, 0.122 x TDP = Continuous Amps at 12v [source].
    Introduction to Thermoelectric Cooling
    dlb134
    Re:Do i need a heat sink AND a fan? 2010/05/01 17:51:17 (permalink)
    The gt220 is better than the x1950xt it gets higher 3dmark scores. Hell the x1950xt came out before 3dmark 06 since the 7 series the low end has been much improved.
