Chrome-M-Dragon
- Ribbons : 30
Does anyone have a spare one at all? I have done poor research and did not know these fans require their own special controller and not the one I have. I do already have the node part, (thought that was all I needed) Love you all. And thanks.
People are, well, only Human. We know that. The rule of law is borne out in identifying, condemning, and punishing those who violate the standards on which we all agree. This is exactly what we do in america. -James Inhofe Use any of the codes below for a free hug and a high five! Much love to all you wonderful nerds! Associate: 5L1LJB5JQ94H892 Affiliate Code: QRXQKO8ZJS
- Ribbons : 84
Re: Corsair 6 PORT RGB LED FAN HUB
2020/05/28 02:41:12
I'd love to help you but first of all I'd like to know more about what you're doing. Do you wish to run Corsair RGB fans with iCUE? Which Corsair fans are you using or want to use?
- Ribbons : 84
2020/05/28 02:52:09
☄ Helpfulby Chrome-M-Dragon 2020/05/28 07:25:10
zotty
2020/05/28 02:54:14
thats the one.. but for future reference.., always worth reading the Corsair RGB Ecosystem Faq i put togther..
- Ribbons : 84
2020/05/28 02:57:32
zotty
2020/05/28 02:58:55
Chrome-M-Dragon
- Ribbons : 30
2020/05/28 07:24:58
Well, I didn't know it was only 10 bux through corsair, I was lookin all over the place and it's 20 or more. Either way I have 4 SP120 RGB PRO fans and as far as I know the only way to control them is with icue, and that hub. Thanks so much for the link. I swear I looked at corsair before... I'm a derp.
tattude69
- Ribbons : 5
2020/05/28 08:11:57
Another option is using a Aqua Computer Octo and RGBpx splitty 4. i am currently using for corsair Ml pro rgb 140mm fans the Octo is a $55 and splitty is about $10. plus is 8 fan pwm fan controller and connect 4 rgb corsair fans. this will let use RGB from corsair or NZXT but only one or the other. Uses Aqua Computer software instead of corsair link. Disadvantage is 4 port hub but can be expanded. My personal opinion is the corsair link or Icue is kinda like an apple ios and Aqua Computer software would be like android os more customization and not tied to one ecosystem.
post edited by tattude69 - 2020/05/28 08:28:43
Chrome-M-Dragon
- Ribbons : 30
2020/05/28 20:19:30
I like the looks of that for sure, but I've already spent that much on this corsair stuff so I will stick to it for now. I don't get why they had to make everything Corsair only. I will keep that stuff in mind in case I ever have to change things up. But for 10 bux why not get the 6 port for the thing thats in this case.
Bateh91
2020/05/29 16:58:27
Happy I stumbled upon this because I plan on getting some corsair 140mm fans for my case that i am going to order.
CPU-Ryzen 5 3600x GPU- GIGABYTE Nvidia GeForce GTX 1660 Mother Board- AsRock B450 Pro4 RAM-HyperX Fury (4x4gb) Power Supply-EVGA 500BQ Bronze+ Case-Cooler Master Q500L (Taking recommendations for an upgrade) Monitor- MSI 32" OPTIX AG32C Keyboard- ROG Claymore Core Mouse- Logitech G 502 LE
tattude69
- Ribbons : 5
2020/05/29 17:33:07
i have to give GTXJackBauer the credit. He opened my Eyes to Aqua Computer OCTO and the RGBpx Splitty (their was also An Active splitty9 in pic active standalone pwm fan hub) I am very happy i went with this over the comander pro. the software also gives me the ability to read the info from Evga CLC 280 so i do not have to run flow control and can control at least 8 PWM fans or pumps independently and convert RGB (Corsair,NZXT) to RGBpx system
post edited by tattude69 - 2020/05/29 17:46:31
Chrome-M-Dragon
- Ribbons : 30
2020/05/29 17:50:02
Yeah if I could turn back what I did after my screw up I would gladly have gone that route. Bateh91 Happy I stumbled upon this because I plan on getting some corsair 140mm fans for my case that i am going to order.
Just do your research like I didn't if you don't go with the splitty.
