Controlling a Non-PWM fan with PWM Project
S2000Gan
Friday, July 22, 2011 0:06 PM (permalink)
Hey guys Im ordering myself some Fans that are Non-PWM and Im going to be getting a Maximus IC Gene-z so I said hmm 5 PWM headers and only 1 PWM fan (the CPU fan)..... I wonder if I can make a small circuit to control the fan with PWM
I have some experience with electronics and after a bunch of reading and thinking I cam across this
Seems good to me but I was wondering if anyone else here has any input on the circuit design
I decided to look for an OpAmp circuit because I understand they dont interfere with the Tachometer
Im not sure how the PWM would interact with LEDs though
Id have to isolate the LEDs of the fan in order for them to not get dimmed by the PWM controller correct?
Or are the LEDs generally already on a separate circuit so that the LEDs always draw their 3.3V (or whatever x amount of Volts)
Other thoughts, what do you guys think of only using the PWM pin of the mobo and using the 12V pin from a molex as to not over draw current from the motherboard for higher current fans?
Although im not using any of those insane Delta fans, so is that even worth doing?
:'( RIP EVGA GPUs :'( 2009(9500 GT) - 2019(RTX 2070)
My Rig: CPU i7-9700K   Motherboard Asus Maximus XI Code   RAM 32GB G.Skill Trident Z
Graphics Card
EVGA GTX 2070   Power Supply Corsair RM850x
Case Fractal Design Define R6   CPU Cooling XSPC Raystorm & 2x 240mm Radiators
2 Replies Related Threads
    KenMcC
    • Ribbons : 21
    Re:Controlling a Non-PWM fan with PWM Project Friday, July 22, 2011 0:25 PM (permalink)
    Not really into circuit design, but doesn't all the voltages on the mobo come from PWM for the boards fan controll?
    KenMcC
    Z170 Classy K; i7-6700 CPU,
    Corsair CMK16GX4M2A2400C14
    Seasonic SSR-360GP 360W;
    Samsung 950 Pro M.2 256 GB
    Samsung 850 Evo 500 GB SATA
    Samsung 850 Evo 256 GB SATA
    Samsung SSD 840 Series 250 GB SATA
    Samsung 860 EVO 1 TB SATA
    Windows 10 x64 Prof.
    S2000Gan
    Re:Controlling a Non-PWM fan with PWM Project Friday, July 22, 2011 0:28 PM (permalink)
    the PWM voltage turns the 12V on and off
    Graphics Card
