samsonlabs
Just got the z690 and paired it with the 3090ti and a 1000 watt P6. Right of the bat I found that the EPS cables to the CPU (8 pin into the psu and 4+4 into the motherboard) are not keyed the same as the CPU power socket on the motherboard. Also if both the motherboard sockets and the CPU sockets on the PSU are the same and both are 8 pin, why not just make 2 8 pin to 8 pin keyed the same? Why the 4 +4 end? Its a pain to plug in and the clips do not line up with the retainer on the mobo socket to boot. Anyone else found their PSU cpu cables dont match the z690 socket? Is there another cable that needs to be bought?
B0baganoosh
- Ribbons : 30
Re: CPU power socket not keyed same as CPU cable
2022/08/13 15:24:23
Nope. Did not have that problem with the g3 power supply cables.
6Q6CPFHPBPCU691 is a discount code anyone can use. i9 13900k - EVGA Z690 Classy - EVGA RTX 3080 ti FTW3 Ultra (+Hybrid Kit) - G.Skill 32GB DDR5-6000 - WD SN850 2TB NVMe Gen4 - EVGA 1000W G3 - BeQuiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
uplink_svk
2022/08/13 15:57:14
samsonlabs Just got the z690 and paired it with the 3090ti and a 1000 watt P6. Right of the bat I found that the EPS cables to the CPU (8 pin into the psu and 4+4 into the motherboard) are not keyed the same as the CPU power socket on the motherboard. Also if both the motherboard sockets and the CPU sockets on the PSU are the same and both are 8 pin, why not just make 2 8 pin to 8 pin keyed the same? Why the 4 +4 end? Its a pain to plug in and the clips do not line up with the retainer on the mobo socket to boot. Anyone else found their PSU cpu cables dont match the z690 socket? Is there another cable that needs to be bought?
That's some weirdness there mate. EPS cables are universal. They're 4+4 because there are many boards that sport either single 4 pin EPS [not many nowadays], but more that sport 8 + 4. Can You send photos of these faulty cables? Their board connectors?
post edited by the_Scarlet_one - 2022/08/14 16:47:56
mobo: EVGA Z690 DARK K|NGP|N, 121-AL-E699-KR | bios: 1.14 | cpu: Intel® Core™ i9-12900T Processor | vga: Nvidia GeForce RTX™ 3090 Ti Founders Edition | ram: DOMINATOR® PLATINUM RGB 32GB (2x16GB) DDR5 DRAM 6600MHz C32 Memory Kit — Black [SKU CMT32GX5M2X6600C32] | nvme ssd: Samsung 980 PRO NVMe™ M.2 SSD 1 TB & Samsung 980 PRO NVMe™ M.2 SSD 2 TB | psu: Asus ROG THOR 1000P2 GAMING cooler: Asus ROG RYUJIN II 360 | monitor #1: 31.5'' 4K OLED Display with Pixel Dimming and 1M : 1 Contrast Ratio [32EP950-B] | monitor #2: LG Ergo 27UN880 | mouse: Logitech Master 3S | keyboard: Logitech MX Mechanical + MX Palm Rest
jdec112016w
2022/08/13 16:16:07
You must be looking at it wrong somehow, never heard of that issue, as for your other question, some motherboards just use, 1-8 pin & 1-4-pin, at the CPU socket on the motherboard, why the split 4+4 pin. They use the 1, 8-pin + the 1-4 pin. Why I not buy a motherboard like that, they claim they can handle the i9-12900k, reviews on those motherboards say otherwise.
EVGA Z690 DARK KINGPIN (BIOS VER. 1.15)Temporarily. For now. Z690 Classified (BIOS VER. 1.15)Windows 11 ProIntel i9-12900kEVGA GeFORCE RTX 3090 Ti FTW3 24G-P5-4985-KRSAMSUNG 980 PRO M.2 SSD, 2TBCORSAIR VENGEANCE C70 caseEVGA 1300 SuperNOVA P+EVGA Z20 RGB KEYBOARDEVGA X20 Wireless MouseDell-27" LED QHD G-SYNC Model:S2716DG.G.SKILL (2 x 16GB) F5-6400J3239G16GX2-TZ5RS
samsonlabs
2022/08/13 17:47:51
uplink_svk
post edited by the_Scarlet_one - 2022/08/14 16:48:45
samsonlabs
2022/08/13 18:01:04
Also
samsonlabs
2022/08/13 18:42:52
I just read that the one 4pin that has all rounded corners will plug into any socket IE with 2 square and 2 rounded. So use the one 4 pin that is correctly keyed to the motherboard, and plug the 4 rounded corner plug in beside it with the clip on the same side and you are fine. The 2 sockets on the motherboard that are rounded will orient the plug so you dont plug it in backwards...the other 2 rounded will simply plug into the square sockets on the mobo. Somehow I got it in my head that it should have been keyed the same on both sides but now that I think about it, I remember that that second half of a 4 pin could be plugged anywhere.....
Bee_Dee_3_Dee
- Ribbons : 21
2022/08/13 22:06:06
samsonlabs I just read that the one 4pin that has all rounded corners will plug into any socket IE with 2 square and 2 rounded. So use the one 4 pin that is correctly keyed to the motherboard, and plug the 4 rounded corner plug in beside it with the clip on the same side and you are fine. The 2 sockets on the motherboard that are rounded will orient the plug so you dont plug it in backwards...the other 2 rounded will simply plug into the square sockets on the mobo. Somehow I got it in my head that it should have been keyed the same on both sides but now that I think about it, I remember that that second half of a 4 pin could be plugged anywhere.....
yep -- i went through the exact same thing. with a Corsaire AX860 PSU when i first assembled my current build last February. and i felt i needed an additional adapter or two just to be a perfectionist like i do when building a PC. this thread seems as good a place to note it: CPU 8 Pin Power Extension Cable ATX CPU 8 Pin Female to 8(4+4) Pin Male EPS Extension Cable for Motherboard (Not PCI-e VGA) 12 Inches (2 Pack) TeamProfitcom i believe the EVGA Phone Support confirmed all u have posted too on this thread. Plus pics on the ^^product link confirms it. and i think i found a full explanation of all ^^ on web too, using keywords like "CPU 8 Pin Power Cable" and especially "Not PCI-e VGA". Note: that in addition to the pics on the ^^product link, the reviews for it and questions for the product also helps to understand all questions in OP for anyone that reads this thread now or in the future. the two CPU 8 Pin Power Extension Cables ^^ have worked flawlessly for going on seven months now. the quality look and feel is excellent. GL on ur build!
post edited by Bee_Dee_3_Dee - 2022/08/13 22:17:51
> PSU: EVGA SuperNOVA 1000 P2> Mainboard: EVGA Z690 CLASSIFIED (BIOS v1.03 12/3/2021)> CPU: Intel Core i9-12900KF> AIO: EVGA CLC 240mm> Physical Memory: G.SKILL Trident Z5 32GB (2 x 16GB) DDR5 5600> Physical Memory Model#: F5-5600U3636C16GX2-TZ5S> Monitor: Alienware AW2721D> Video Card: EVGA 3090 FTW3 ULTRA GAMING> Case: Cooler Master HAF X (942)> DAS: Sabrent DS-SC5B
Hoggle
2022/08/14 01:18:49
uplink_svk
While the plugs are universal it’s always best to replace the cables any time you replace a PSU or contact the manufacturer to make use the cables are wired the same. People have fried computers thinking because the connectors on the ends fit into the PSU itself that the wired the same on the PSU end. The mother end should be universal though.
post edited by the_Scarlet_one - 2022/08/14 16:49:33
uplink_svk
2022/08/14 15:16:53
samsonlabsI just read that the one 4pin that has all rounded corners will plug into any socket IE with 2 square and 2 rounded. So use the one 4 pin that is correctly keyed to the motherboard, and plug the 4 rounded corner plug in beside it with the clip on the same side and you are fine. The 2 sockets on the motherboard that are rounded will orient the plug so you dont plug it in backwards...the other 2 rounded will simply plug into the square sockets on the mobo. Somehow I got it in my head that it should have been keyed the same on both sides but now that I think about it, I remember that that second half of a 4 pin could be plugged anywhere..... Sorry mate, was away for the weekend. Well, I just meant to ask You, it's like that kids old toy, block to square opening, prism to triangle opening, ball to circle opening, etc. So they fit and work correctly, right?
Bee_Dee_3_Dee
- Ribbons : 21
2023/01/24 04:09:12
Someone was asking today about CPU 8 Pin Power connectors and i decided to point them to this thread and in addition add the Pic below. It's of a GIGABYTE Z690 AERO D, that i discovered today. (MOBO with one 4-pin and one 8-pin EPS Connections on it).
- Ribbons : 281
2023/01/24 16:34:12
Yep! Solid 8-Pin goes to the PSU and 4+4-Pin to the Motherboard.
Black_Hawx1
2023/02/03 05:26:44
check if u are not trying to push the gpu pins into the CPU pins (we all make that mistake at some point, i almost did that with my z690 classy and my supernova 1000 p6 modular)
MONITOR: MSI 27" IPS MAG274R2 G-Sync 165Hz 1080PCASE: EVGA DG 77 BLACK -MODDEDMB: EVGA Z690 CLASSIFIEDCPU: i5 12400 AIO: Asus ROG Ryuo 120 -MODDEDRAM: 32 Gb ram Corsair DOMINATOR DDR5 5200 MhzSSD NVMe: WD SN850 NVMe 500 Gb 7000 mb/s (+500 x2 SATA3 SSD)GPU: EVGA RTX 3060 12 Gbs XCPSU: EVGA P6 SUPERNOVA 1000W PLATINUM MOUSE: G Pro X SuperlightKEYBOARD: G915
build: https://i.imgur.com/s56ZcCq.jpeg
