maniacvvv
- Ribbons : 165
Re:Battlefield BC2 Graphic Settings Guide
2011/10/21 08:12:04
You didnt even bother to read my guide.... LOLOL, I'm sure you will after you install the second 580 and "Max" your settings... Good Luck with that novice, you should have read the guide and the comments While its doubtful you will post again, when your screen is flickering black and the game is crashing... *Just come back read the guide, and it will fix you right up bro
post edited by maniacvvv - 2011/10/21 08:19:30
Zibri
2011/10/21 08:32:53
Your guide is just wrong. I rarely read guides and seldomly write them. And I prefer to get maximum quality and no "performance" settings like you suggest. Crashing? Flickering? I get none of these with my settings and my actual setup.
Running on Core i7 950 @ 4.2 ghz 2x EVGA GTX 580 in SLI @ 920 / 2250 / 1.150v 24/7 on 335.23 whql
downie20
2011/10/21 08:56:31
maniacvv Kinda going off topic here. Are you going to do a guide for BF3 after it's released? That would be awesome. BTW I think your guides rock. IMO to a person that lacks the knowledge and experience they help explain in detail why or how each step if required or needed.
Affiliate Code: IY2CSZIKRN Heatware EVGA X58 E760** i7 920 D0 @ 4.21Ghz**Corsair Dominiators 6GB (7-7-7-20) 1600Mhz**Corsair HX1000 PSU Noctua NH-D14 Cooler**EVGA GTX 580 Classy-SLI*Tri-SLI SOON*OCZ Vertex 60GB SSD**(2x) WD Caviar Black 640GB-Raid 0
maniacvvv
- Ribbons : 165
2011/10/21 09:02:02
downie20
maniacvv
"Are you going to do a guide for BF3?" You bet I am http://forums.evga.com/fb.ashx?m=1267475
Zibri
2011/10/21 09:10:43
maniacvvv: I don't understand why you are heating up so much... maybe your cooler is defective ;) Mine was not a personal attack, just my own opinion and tested settings. Guides are a good thing for newbies and even experienced people can learn something from them (vsync broken? what issues do you see? I see none) In your guide you "crank up" game settings while degrading visual settings in nvidia control panel. I just have a different opinion and a screenshot can prove bfbc2 on my system is visually near to perfect (It will be when I will also maximize AA and aniso) For your own knowledge, I tried to run the game at 1920x1200 and INDEED AA have a major role at that definition. Get yourself an HP Zr30W (H2 IPS, 1 billion colors, 2560x1600) and you will see the difference :)
NordicJedi
- Ribbons : 77
2011/10/21 10:30:01
Let's keep this on-topic. Now back to the good part!
Zibri
2011/10/21 21:29:24
Sorry NJ, I just proved my point. No harsh feelings nor flaming intended. Anyhow! I just finished installing the second EVGA GTX 580. My game settings now are: settings.ini [WindowSettings] Width=2560 Height=1600 Fullscreen=true RefreshRate=59.972 VSync=true [Sound] Quality=high VoipEnable=true SpeakerCount=0 [Graphics] Effects=high Soldiers=high Vehicles=high Overgrowth=high Undergrowth=high StaticObjects=high Terrain=high Shadows=high Bloom=true HSAO=true MSAA=4 Water=high MainQuality=custom Texture=high DxVersion=auto Aniso=4 Detail=high RenderAheadLimit=0 Fov=74 [Chat] ChatWindowAlpha=10 SmallChatWindowTimer=5 NVidia CPL is at default settings after a clean install. Both cards are clocked at 920/2200 @ 1.113v Here is a screenshot :) Click on the image and open in a new tab or save it. It's 2560x1600 :)
maniacvvv
- Ribbons : 165
2011/10/21 21:58:15
Please explain How are you getting 122.2fps with Vsync "ON" as shown in your settings file? I know why, do you? Also your stated AA levels appear to be incorrect We can clearly see you do not have Transparency AA enabled in the above shot.... And if the game were at x16 pure AA and x16AF (you stated settings) Why are we seeing the artifacts on the light poles, aircraft and on the ground shadows? And the artifacting on the pilots gamer tag speaks for itself running at 2560x1600.... Thank you for posting the original screenshot at full 2560x1600 res, as that removes any doubt about the discrepancy between your posted settings file and what was really used for the screenshot. I happen to know a great deal about the BFBC2 game engine, its settings and what given settings produce inside the game. You post does not appear to be factual I am happy you finally bought the right hardware to drive your monitor, and that whatever the settings you are using are working for you. (maybe you read my Guide after all) You appear to have no concrete experience or even basic knowledge of Nvidia drivers, the NVCP or what the effects of different settings in the Nvidia control panel and inside of a given game engine produce when used together, in terms of graphical quality... I stand by my guide and the hundreds of posts from users who found it helpful, informative and produced the results promised. Your "stated" settings (and posted screenshot) do not match the known performance levels in BFBC2. Not even close. You have indeed proved a point....
post edited by maniacvvv - 2011/10/22 01:34:01
XRAYTEKCA
Re:Battlefield BC2 Graphic Settings Guide for GeForce 400 and 500 series cards
2011/10/22 02:35:01
ok, you are correct about my failed install of the game, i did copy and paste the game between drives, and may have corupted files. here is the funny thing, i did a remove game from control panel, which it did, but bc2 icon was still up, and when clicked, was still playable!!! LOL. also, when i did the fresh install (dvd) on my storage drive, it did a new 745XXX update on the game and my old version was 6XXXXX. i just played a few maps, will give you a new update if i artifact again. thanks for your help :)
i7 920(vanilla), x58 LE bios 82, corsair xms 6gb,1.5vram gtx 580(vanilla), pc power 1000watt ps, crucial m4 64 gb boot, 1000gb wd storage, corsair h60, corsair cobsidian 800d.
Zibri
2011/10/22 05:24:21
That was a speed screenshot with vsync OFF *OBVIOUSLY*. This one has VSYNC on.
post edited by Zibri - 2011/10/22 05:28:51
- Ribbons : 85
2011/10/22 10:16:44
I'll give a warning in this thread that everyone has to stick to the EVGA forum terms of service for the forum. If there is a post that someone finds offensive make a ticket and/or contact a mod. Any further violations might result in this thread being locked.
Zibri
2011/10/22 10:23:38
maniacvvv
- Ribbons : 165
2011/10/22 11:16:58
What? my reply is edited? Fine... this thread will be locked or I will remove it. I will not allow false and misleading information to be posted in my Guide.
post edited by maniacvvv - 2011/10/22 11:20:40
- Ribbons : 85
2011/10/22 11:36:05
Locked per request of the OP
- Ribbons : 85
2011/10/27 01:11:58
The OP has asked for an unlock of this thread. This unlock is conditional. I expect posts to stay on subject. Do not attempt any attacks on the OP nor any off subject posts or those will be deleted.
Zibri
2011/10/27 06:26:51
rj: I never attacked anyone, I've just been insulted with no reason other than expressing my opinion.
maniacvvv
- Ribbons : 165
2011/10/31 01:45:59
XRAYTEKCA
Good job!
XRAYTEKCA
2011/11/01 07:23:58
ok.....its solved for bc2, but.....it does the same thing for bf3 :( i did follow your temp guide for bf3, but it does not look good...but does not crash. when i kick it all up to ultra, runs well, but will crash like the screen shot that i upload. i have the 1.5 vram gtx 580, vanilla card....i suspect bad ram again........
rtessenear
2011/11/01 08:30:12
In your post you show advanced graphics option. How do you turn that on? All I see is the standard graphics settings shown here!
Link to My Boreas Cascade all H20 cooled build: http://forum.coolitsystems.com/index.php/en/home/7-boreas-mtec-chiller/4270-all-liquid-cooled-boreas-cascade.html X58 Classified 4 way , 21X 211 Bclk 1.328 Vcore Coolit dual Boreas in a cascade H2O cooled Tecs 1400W 3 Vertex EX SLC in Raid 0 (root) , 3 Vertex EX SLC in Raid 0 (Games) i7 920 D0 @ 4.431 GHz Corsair DOM GT 2056 6 GB Tri Chn @2000 2:10 ratio with 21 Uncore total 21500Mb/s in Memtest 2 EVGA GTX 580 FTW Hydro Copper 2, 1 EVGA GTX 285 FTW 772, 1773, 1450 Bios hard flashed for PPU ABS 1300 watt and Thermaltake Pwr Express 650W logitech G5 V2, MT Mods Ascension , 2 QUAD Hardware Labs Rads , 1 HK 3.0 CPU WB , 1 Full BD WB from EK 1 Koolance WB for the gtx-285 GPU Win 7 RTM X64
maniacvvv
- Ribbons : 165
2011/11/01 10:14:38
rtessenear
2011/11/01 10:21:56
I truly don't mean to be dense; however the pic I posted is all I see. Where are you in the game for your settings? I select, options then video. As you can see in the pic, it looks nothing like what you are posting. Is the info your providing for the Beta or the retail version? I have the retail version.
maniacvvv
- Ribbons : 165
2011/11/01 10:24:13
rtessenear
Check your PM's please
rtessenear
2011/11/01 10:32:12
sent... Strange your settings page looks nothing like mine. Sorry to be a pest man. Hope you can help. Also do you know why Battlefiled 3 keeps launching through Game Manager? I had a few launches through Origin, now Origin redirects my launch through Game Manager.
rtessenear
2011/11/01 10:34:47
Well now I, I guess I should learn to read first. Thanks, sorry about the confusion on my part. This is a guide on Battelfield 2 not 3. Thanks for clearifying for me.
maniacvvv
- Ribbons : 165
2011/11/01 10:34:59
Sent you a PM with the link to the "temporary" Battlefield 3 guide http://forums.evga.com/fb.ashx?m=1293763 This Guide is for Battlefield Bad Company 2 -not- Battlefield 3 There are differences in the NVCP settings needed, so be sure to note those changes from what was posted in this thread
HAMMERSWIFT
2011/12/10 20:49:32
Will you or can you do a guide for SWTOR using 3 screens in sli?
maniacvvv
- Ribbons : 165
2011/12/10 20:56:00
HAMMERSWIFT
Sorry, at this time I only have one monitor.. so surround setup guides are out of the question. I am still working to complete my Battlefield3 guide... After that is done I am not really thinking about doing another guide until ARMA3. ARMA3 will be my next major project, along with a Nvidia Kepler Driver Guide early next year
maniacvvv
- Ribbons : 165
2012/09/07 22:56:08
Here is the Guide... you can post here, or PM me bro
- Ribbons : 135
2012/09/07 23:18:36
maniacvvv Here is the Guide... you can post here, or PM me bro I just have to ask...who and what are you referring to?
maniacvvv
- Ribbons : 165
2012/09/07 23:22:45
HeavyHemi maniacvvv Here is the Guide... you can post here, or PM me bro I just have to ask...who and what are you referring to? User was looking to play BFBC2 and I told him it was in the gaming section... Forgot it was in here buried away...
