jimin9292
Hi I have EVGA 1080ti FTW3 Elite Gaming card. I recently fresh installed windows 10, installed the latest Nvidia driver, installed Precision X1, and noticed something strange. I remember that my card comes with an asynchronous fan control function, where each of the 3 fans is tied to the GPU, Power, and Memory respectively, and fan speeds are controlled asynchronously for each of the 3 fans. I installed the 1.18.0 version and noticed that all three fans are tied to GPU despite my card is ICX capable (see attached image). It used to be that first fan - GPU, second fan - Power, third fan - Memory. I confirmed this by running a GPU stress test and observing that the fan speed % for all three fans are indeed tied to the GPU and change synchronously. All the sensor readings in ICX are normal (10 sensors). I thought maybe this only happens in a newer version of PX1, so I installed the 1.0.7 version (July 2020) which I confirmed in the past that it correctly controlled the fans asynchronously and the problem was still there. Could this be the issue that comes with the newer Nvidia driver? I know cards that are not equipped with ICX have "GPU" written for all their fan but I remember that wasn't the case for my card. Any insight would be very appreciated
post edited by jimin9292 - Thursday, May 20, 2021 7:05 PM
- Ribbons : 123
Re: Asynchronous fan control for ICX capable card
Thursday, May 20, 2021 1:42 PM
is the "chain icon" for the fans a "broken link" on the main page of X1 ?
jimin9292
Thursday, May 20, 2021 5:47 PM
Cool GTX is the "chain icon" for the fans a "broken link" on the main page of X1 ?
Yes, they are broken. But I think they only control the manual fan sliders - i.e. when you slide one fan, it slides all the other fans together.
post edited by jimin9292 - Thursday, May 20, 2021 5:48 PM
jimin9292
Saturday, May 22, 2021 1:10 AM
Is there no one who had a similar issue? EVGA ICX page clearly states each fan is controlled independently by GPU, Power, and Memory so I think it counts as a bug if PX1 doesn't support it.
yoadknux
Saturday, May 22, 2021 10:05 AM
Sounds like normal experience for an FTW3 card using Precision
jimin9292
Saturday, May 22, 2021 6:41 PM
yoadknux Sounds like normal experience for an FTW3 card using Precision
That's interesting. So even the FTW3 cards all the fans are now synchronized to GPU temperature?
jimin9292
Monday, May 24, 2021 10:35 PM
Just an update, I talked to EVGA tech support team and they suspect it's most likely the newer Nvidia driver that's causing this issue. They said they will keep an eye out for this, but if you are having similar issue as I am, you can try rolling back the driver version to see if it fixes it.
Kbird666
Monday, May 24, 2021 10:54 PM
On my 1070ti I use the older Prec. OC ( 6.25 I think?) as X1 never worked properly with it..... 1.1.9 works on my 3080XC but 1.2 does not ....it won't remember Fan Settings. KB
GByte Z590 Aorus Elite AX MB + 11700K 32GB Kingston Fury DDR4 @3200mhz EVGA Nvidia RTX 3080Ti EVGA G6 850watt P.S. (3) 32" BenQ BL3200PT Monitors (CAD-WS) .
jimin9292
Monday, May 24, 2021 11:01 PM
Kbird666 On my 1070ti I use the older Prec. OC ( 6.25 I think?) as X1 never worked properly with it..... 1.1.9 works on my 3080XC but 1.2 does not ....it won't remember Fan Settings. KB
X1 (1.1.8) will remember the fan settings for my card - 1080TI FTW3 Elite Gaming - but all three fans are tied to GPU temp instead of being individually controlled by GPU, Power, Memory temp sensors. The problem was still there even when I rolled back the X1 to older versions which I remember to handle fan speed correctly, so it's most likely the Nvidia driver that's causing the issue I think.
Kbird666
Tuesday, May 25, 2021 10:00 PM
jimin9292
I checked my old system 1070ti FTW2, and it has precision XOC 6.2.7 and the fans (GPU + Power) have no issues running at different speeds.
jimin9292
Tuesday, May 25, 2021 10:47 PM
Kbird666
jimin9292
May I ask what Nvidia driver version you are using?
Kbird666
Tuesday, May 25, 2021 11:10 PM
May I ask what Nvidia driver version you are using? How did I know you'd ask that :) I forgot to get it earlier and knew I should have :) 461.72 KB
post edited by Kbird666 - Tuesday, May 25, 2021 11:11 PM
Phrank44
Monday, June 14, 2021 5:58 PM
I'm wondering this as well. EVGA RTX 3080ti FTW3 Ultra - Precision 1 installed, have set a custom fan curve, but am confused about the ICX button. I turn ICX on I see my fan curves on the left, the Fan Speed Auto (the chain is connected) and the Auto fans are all at 0%. If I click on ICX, the fan display on the left disappears, as does the Auto Fan Function on the right, so does this mean the fans are now controlled by the ICX sensors?
Use an Associates Code & SAVE 5% - 10% on your purchase. Just click on the associates banner to save, or enter the associates code at checkout on your next purchase. If you choose to use my code I want to personally say "Thank You" for using it.
Kbird666
Monday, June 14, 2021 7:10 PM
Phrank44 I'm wondering this as well. EVGA RTX 3080ti FTW3 Ultra - Precision 1 installed, have set a custom fan curve, but am confused about the ICX button. I turn ICX on I see my fan curves on the left, the Fan Speed Auto (the chain is connected) and the Auto fans are all at 0%. If I click on ICX, the fan display on the left disappears, as does the Auto Fan Function on the right, so does this mean the fans are now controlled by the ICX sensors?
No , they are still controlled by your Fan Curve , the ICX button ( and sensors) on the 3000 Series appear to show/do little except show the GPU temp unlike my ICX2 on a 1070Ti which shows memory temps etc as well at 9 different points. ( with shortages everywhere on chips, maybe EVGA just couldn't get the sensors so they aren't even on the PCB? ) with precision x1 1.2.1.0 ( 1.2.0.0 had issue here) with no fan curve and Auto Fan OFF the fans should run at 33% apparently ( since 1.2.0.0)....... but I use the stealth curve myself.
Phrank44
Monday, June 14, 2021 9:28 PM
Kbird666
Thanks! I've got 10 sensor readings on the card - so that part is working correctly. I've got a custom curve, although I like the Stealth curve as well, just using my Custom curve that's worked so well for me previously for now. So even though I've got all these temp readings, I can clearly see that ICX should run the individual fans according to hot-spots the software just isn't functioning right now as advertised? Is there a way to correct this or am I just not doing something correctly? lol Cheers!
post edited by Phrank44 - Monday, June 14, 2021 9:32 PM
Kbird666
Monday, June 14, 2021 10:06 PM
Best to start your own thread instead of tacking onto this one.... different issue and cards interesting as I have never seen anything under ICX except GPU temp I think if the Fan are linked ( chain) they all go at the same speed though.... ie 2&3 spin per no#1 for example.
Slade__
Tuesday, June 15, 2021 3:08 AM
Hopefully we can find a fix soon
