- Ribbons : 86
https://www.eteknix.com/antec-releases-signature-platinum-titanium-psus/ Antec, a leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, broadens its range of power supplies with the new Signature Series Platinum and Titanium models. The PSU line MSRP is now commercially available from US$ 229.99 for the 1000 W Platinum and US$ 269.99 for the 1300 W Platinum and US$ 279.99 for the 1000 W Titanium PSU. All models will be available at the beginning of May in US. Equipped with features that ensure peak performance for the enthusiast and gaming-oriented segment, the Signature Series features a fully-modular cable management system which enables users to use only the cables which are needed, greatly simplifying installation and helps clear out excess cables that can obstruct and reduce airflow. The whisper-quiet, fluid dynamic bearing 135 mm fan provides high airflow with durability and longevity. The Zero RPM fan mode further ensures a longer-lasting and quieter system, by using thermal sensors to activate the fan only when you need it. All models of the Signature Series are a great choice for a reliable and efficient PC system for gamers and professionals. This new PSU line from Antec pushes the standard for excellence with the circuit shield suite of industrial protections and is backed by a 10-year warranty. The 10 year warranty is definitely great value in my opinion. The fully modular design also looks very good.
Bobmitch
- Ribbons : 49
Re: Antec Releases Signature 80 PLUS Platinum and Titanium Power Supply Lines
Monday, April 27, 2020 1:49 PM
Antec has always been a solid brand. Owned a few...never an issue.
MSI MAG X670-E Tomahawk; Ryzen 7 7800X3D; Asus TUF RTX 4070 TI OC; Seasonic Vertex GX-1000 PSU; 32 GB Corsair Vengeance DDR5-6000 CL30 RGB; Corsair iCue Link H150i LCD 360MM AIO; 2-Western Digital Black 4 TB SN850X NVMe; Creative SoundBlaster Z; Lian Li Lancool III; Corsair K70 RGB Pro MX Speed Silver Keyboard; Razer Viper 8K Mouse Heatware: https://www.heatware.com/u/72402 Affiliate code: 1L2RV0BNQ6 Associate Code: UD82LJP3Y1FIQPR
Miguell
Monday, April 27, 2020 2:37 PM
bobmitch Antec has always been a solid brand. Owned a few...never an issue.
have my SEASONIC M12 700W since 2008... STILL strong! never, ever and issue! 12 years and counting!
Case: Cooler Master Stacker 830Display: 32" AOC Q3279VWFD8 @2560x1440@75HzCpu: Intel Core i7-8700Cpu Cooler: Cooler Master - MasterLiquid ML120L - RGBMobo: Asus ROG Strix Z390-H GamingVga: Asus Dual RTX 4060 Ti 16GB Advanced EditionRam: 32GB DDR4 G.SKILL - RIPJAWS V @3200MhzSound: Hama uRage soundZbar 2.1 Unleashed - (Optical)Storage: 500GB SSD M.2 A2000 NVMe Kingston (OS) + 8TB (4+4) HDD X300 Toshiba (Data)Psu: SeaSonic M12 700W Os: W10 Pro 64Bit
- Ribbons : 123
Monday, April 27, 2020 2:51 PM
28 (18+10) pin MBU socket – For possible future MBU connectors --> interesting
GTXJackBauer
- Ribbons : 48
Monday, April 27, 2020 4:47 PM
Miguell have my SEASONIC M12 700W since 2008... STILL strong! never, ever and issue! 12 years and counting!
Are these rebraned Seasonics? They look similar.
Miguell
Thursday, April 30, 2020 10:18 AM
GTXJackBauer
i bought seasonic cause someone told me they where "THE ONES" behind many famous brand labels out there... so i bought this one.. costed me a whooping 250 euros back in 2008!! but worth it!! still going strong!! right now? i am not sure how SeaSonic is doing but i would NOT buy another brand! this is the one i bought: 5 years warranty bt after 12 years... no problems at all!
post edited by Miguell - Thursday, April 30, 2020 1:56 PM
Miguell
Thursday, April 30, 2020 2:11 PM
and if i could i would buy this 750W prime ultra titanium right now! much much better , for 200 euros ( yikes!!) and 12 year warranty instead of 5yrs /  only 2 stores have it here in Portugal!
post edited by Miguell - Thursday, April 30, 2020 2:22 PM
Hoggle
Thursday, April 30, 2020 4:31 PM
I like the look. Very clean and not that much flash to it but enough to make it look high end. Being Antec I trust that they are good PSU's.
