irakandjii
Wednesday, October 14, 2020 0:28 PM
I read with great interest a discussion regarding high temperatures on a FTW 3080. There was a lot of speculation regarding the root cause. It turned out that the problem was mitigated by adding some fans to the case. I would ask that EVGA provide some design data on the air flow rate required by the FTW3 cards to ensure adequate cooling. Reason outlined below. My background is mechanical (aeronautical) engineering so thermodynamics / aerodynamics was part of my training. At the air velocities generated in a computer case and through a GPU card, the air flow is incompressible. This means there is useful data that would help in designing case builds and diagnosing overheating problems. 1) If we knew the "ideal" airflow through the GPU at a couple of points, say: - fans at 100% = X cfm (cubic feet per minute)
- fans at 75% = Y cfm
- fans at 50% = Z cfm
With this data, can calculate a estimated minimum airflow required through the case. Basically you want to replace the total amount of air in the case with AT LEAST the "ideal" airflow required through the GPU as stipulated above. Put simply. You want to get rid of the air, you just heated, with the GPU just as fast as you heated it up! So how would I create a simple rule of thumb for case airflow? (Note: I could get way more complex, but that would really mess up the "rule of thumb".)So let's take an educated guess and make a simplified example of the method assuming 100% fans speeds on the GPU My assumptions about the FTW3 Ultra: A high end noctua NF-F12 120mm industrial fan turning @2000 rpm moves air at 122 m3/hr or approx. 72 CFM Lets assume the FTW is using comparable technology, the blade area will be less since the fan is smaller. So I will "wave hand" and assume each of the 3 GPU fans can push 100 m3/h or 59 cfm. So with 3 fans, I would need 177 or approx. 180 cfm of fresh air to "feed" this ideal GPU. Note: due to restrictions in the flow etc. The number would be lower. Now we have a starting point and can do a rough specification on the case. Case fans: Let's assume we use Noctua case fans. - Each, Noctua 140mm NF-A14 PWM @1500 rpm, moves air at 140 m3/h or approx. 82 cfm
- I would install fans in sets of push/pull (one fan pulling air into the case, one fan pushing air out of the case). Push/Pull is to overcome flow resistance, in the case, not to increase unrestricted flow. Please note! -> The push/pull configuration still moves 82 cfm of air, "NOT 164". The air flow is incompressible so each fan moves the same amount of air.
- Base on the above I would want two (2) sets of 140 mm fans in push/pull installed on the case for the GPU alone. I would then add and additional set in push pull to account for the CPU and other sources of heat in the case M.2 drives etc.
This suggests that you need at least 3 sets of 140 mm fans in push/pull to keep the GPU refreshed with new air if the fans run at 100%. Note: The analysis suggests that folks with small cases are going too have a really hard time keeping temps down on the 3080's. I trust this may be helpful to some, and would ask the EVGA consider it.
jilljill2002
Re: Air Flow through the FTW 3080 Cooler. Is there a specification?
Wednesday, October 14, 2020 5:10 AM
A lot of heat air comes out from the top of my 3080 FTW3, directly hit my side case cover I am a little bit worry the cover cannot hold a long time direct heat air
njbongo
Wednesday, October 14, 2020 6:35 AM
jilljill2002 A lot of heat air comes out from the top of my 3080 FTW3, directly hit my side case cover I am a little bit worry the cover cannot hold a long time direct heat air
You are talking about the side panel? What material is it, metal, plastic or glass? If you worried about the heat damaging a side panel, I would not worry about that. Unless you have a super-cheapo off-brand case side panels should EASILY handle any normal computer heat. If it got THAT hot, for some reason, I think you're components would die long before the side panel gets damaged......
njbongo
Wednesday, October 14, 2020 6:57 AM
irakandjii, I do not have the answers you want, obviously, but I would love to get your opinions on my case setup. I have an MSI Sekira 500x (recently bought it, just for a change). I have some BASIC airflow knowledge, mostly from reading about it online. Anyway. The case has 2, 200 MM fans in front as intake, 2 200MM Fans on top as that are now exhaust (they ship the case with them as intake which I thought was REALLY stupid so I flipped them. 1, 120 MM fan as exhaust on the rear. I also have an NZXT Kraken x73 AIO liquid CPU cooler mounted horizontally at the top, under the 200MM exhaust fans in the radiator bracket. I set the radiator fans as exhaust also so basically the radiator is sandwiched between the two sets of fans both exhausting air (2, top 200mm fans and the 3 120s that the Kraken came with. I originally, by mistake, had the Kraken fans as intake, and quickly realized my mistake and fixed it when the CPU started going over 45 at idle. :) Anyway, if I stress test for an hour, my 9900K maxes out at about 72C, and my 2080 Ti maxes out about 75C both respectable temps for a 100% load. Under normal conditions while gaming, I get average CPU temps of 45C and average GPU temps of 57C. I really have NO ISSUES right now, but I am planning on getting whatever 3080 I can get my grubby little paws on first. I was wondering if the way I have the airflow setup now is as optimal as I can get it? I don't want to mod the case, at all, or add anything that would take away from the aesthetics, it's a pretty setup. Any thoughts? I figures since heat rises top exhaust is always the best, the front intake seems optimal to me because they are large fans and there is a clear airflow path to the mother board (memory and VRMs) and the GPU as well. It's a Strix 2080 Ti OC model, HUGE heatsink and 3 fans pointing down that rarely speed up much. I was thinking about the rear exhaust fan, from what I have read a SMALLER fan is better back there for air pressure. It's the only 120MM, but there is room for a 140 I believe. I can post some pics of the system if that would help. The case has hinged glass panels on both sides, and I can sort of hear and feel the change in pressure with I close them if that makes sense? I tried running the system with the sides and top removed and it actually goes UP a few degrees on average (3-4C maybe). I tried with JUST the top, and just the sides removed and there's really no difference from running it full assembled (maybe 1C variation which isn't really anything to analyze). That would indicate a decent airflow patter/setup, right?
post edited by njbongo - Thursday, October 15, 2020 10:31 PM
jilljill2002
Wednesday, October 14, 2020 7:02 AM
njbongo
Yes, side panel, sorry that English is not my mother language. Tempered Glass, said on official website. The reason I worried this is because I saw some side panel beak into pieces on Internet. Maybe they are using the super-cheapo off-brand case side panels you mentioned.
Dabadger84
- Ribbons : 10
Wednesday, October 14, 2020 7:28 AM
Unless the side of your case is made of extremely cheap plastic or acrylic, you have nothing to worry about. No metal or glass typically used in cases is going to "melt" or get damaged from whatever heat a GPU can put out, keep in mind the 3080 will thermally throttle in the 85-90C range at worst, and the 3080 FTW3 Ultra won't hit anywhere near that unless your case's airflow is atrocious (for reference I got my card today, my case has insanity-level airflow, and I only saw 63C peak load under 3DMark testing so far, with both vRAM & VRM temps on the iCX readouts being even lower than that, and that's with the fans maxing out at 75% so not even near full speed). In case you're wondering what "insanity level" (in my opinion) airflow looks like:
njbongo
Wednesday, October 14, 2020 8:28 AM
jilljill2002
njbongo
You will be fine. As the poster above said (and myself in my original post) any decent case is designed to withstand the heat of PC components, easily. Unless your motherboard is on fire and starts flame-throwing against the side panel.....it will never get damaged...and you will have much more to worry about than your case in that far fetched scenario. :P Tempered glass can withstand much higher temps than your PC will ever see. I would not worry.
njbongo
Wednesday, October 14, 2020 8:30 AM
Dabadger84
Holy #%$@# !!! lol, that is insane, what case it that? Too much of a closeup picture for me to tell. It's cool looking though.
Dabadger84
- Ribbons : 10
Wednesday, October 14, 2020 8:45 AM
njbongo Holy #%$@# !!! lol, that is insane, what case it that? Too much of a closeup picture for me to tell. It's cool looking though.
It's a Thermaltake View 91, retails for $449+, I had the unfortunateness of it arriving with the front panel of glass "broken off" of it's clips... I would have RMAed it with where I bought it from because of that, but I as planning on removing the front glass anyway. In the picture I posted it's modified pretty substantially, the default side glass is off, the front glass is attached to part of the side to direct the "front" airflow towards the GPU/CPU areas instead of letting some of it "leak" out the side of the case, and I moved the fan brackets from the back area (they were there for some reason as it shipped, I don't get why, unless it was to cool the HDDs if you mount them back there maybe?) to the front side so they could be used for side airflow, as I'm pretty picking about keeping my VRMs & RAM (and GPU) cool. Here's what it looks like "stock":   And yes, it's massive:
irakandjii
Wednesday, October 14, 2020 1:56 PM
njbongo irakandjii, I do not have the answers you want, obviously, but I would love to get your opinions on my case setup. I have an MSI Sekira 500x (recently bought it, just for a change). I have some BASIC airflow knowledge, mostly from reading about it online. Anyway. The case has 2, 200 MM fans in front as intake, 2 200MM Fans on top as that are now exhaust (they ship the case with them as intake which I thought was REALLY stupid so I flipped them. 1, 120 MM fan as exhaust on the rear. You did the correct thing here, using 4 200 mm fans to push air into the case with 120 mm fan pulling it out is just really, really BAD engineering. The biggest advantage of 200mm fans is reduced noise through reduced rpm, that being said, the best rule of thumb I could find for a 200mm fan was 110 CFM @ 700 rpm. So you have about 220 cfm of airflow through the case. (less case specific losses which I cannot determine in detail). The 120 mm fan will have some impact, by forcing air out of the case it will reduce static pressure inside the case marginally and offset some airflow resistance to your main airflow. I also have an NZXT Kraken x73 AIO liquid CPU cooler mounted horizontally at the top, under the 200MM exhaust fans in the radiator bracket. I set the radiator fans as exhaust also so basically the radiator is sandwiched between the two sets of fans both exhausting air (2, top 200mm fans and the 3 120s that the Kraken came with. Usually, and a in a perfect world, I would try to set this up as a "push / pull". Use the Kraken mounted fans to push the air upward through the radiator and the 200 mm to draw the airflow away from the radiators and out of the case. BUT!!! it is unlikely to make a big difference. The Kraken should be properly engineered with the appropriate fans (high flow or high static pressure) so changing the direction might actually reduce their effectiveness. Bottom line, I suspect what you have done is very close to optimal here and any modifications would be very close to diminishing returns. I originally, by mistake, had the Kraken fans as intake, and quickly realized my mistake and fixed it when the CPU started going over 45 at idle. :) Anyway, if I stress test for an hour, my 9900K maxes out at about 72C, and my 2080 Ti maxes out about 75C both respectable temps for a 100% load. Under normal conditions while gaming, I get average CPU temps of 45C and average GPU temps of 67C. I really have NO ISSUES right now, but I am planning on getting whatever 3080 I can get my grubby little paws on first. I was wondering if the way I have the airflow setup now is as optimal as I can get it? I don't want to mod the case, at all, or add anything that would take away from the aesthetics, it's a pretty setup. Any thoughts? I figures since heat rises top exhaust is always the best, the front intake seems optimal to me because they are large fans and there is a clear airflow path to the mother board (memory and VRMs) and the GPU as well. It's a Strix 2080 Ti OC model, HUGE heatsink and 3 fans pointing down that rarely speed up much. I suspect you will be fine, the Strix is a well engineered card. The 3080 may demand some more air flow, but with the "guesstimated data" I have now, the air flow through your case sounds good. If you have a problem the first thing I would do would be to add a 120 or 140 mm fan to push more air into the case and support the 120 mm fan you have in push pull. I was thinking about the rear exhaust fan, from what I have read a SMALLER fan is better back there for air pressure. It's the only 120MM, but there is room for a 140 I believe. I can post some pics of the system if that would help. The case has hinged glass panels on both sides, and I can sort of hear and feel the change in pressure with I close them if that makes sense? I tried running the system with the sides and top removed and it actually goes UP a few degrees on average (3-4C maybe). I tried with JUST the top, and just the sides removed and there's really no difference from running it full assembled (maybe 1C variation which isn't really anything to analyze). That would indicate a decent airflow patter/setup, right? There are large percentage increases in flow rate as you initially move up the "fan size" curve. This is because of the hub in the center. It is the blades that do the work, and in a shrouded fan, the outer edges that do the most work. So as a simplfied example: Hub Area (40 mm hub) = pi * r squared = ~1250 mm2 We need to subtract this from the total area of the fans since air cannot flow through the hub :) So, by analysis:
- Working Area 120 mm fan = 11,300 mm2 - 1250 mm2 = ~ 10,000 mm2
- Working Area 140 mm fan = 15,400 mm2 - 1250 mm2 = ~ 14,150 mm2
- The 140 mm fan will move approximately 141% more air per turn.
- The 200 mm fan will move 300% or 3 times the amount of air per turn ( I leave it you you to do the math and prove it)
What this means :
- You can stay at the same noise level -> rpm and move more air
- or,
- You can reduce the noise level (reduce rpm) and stay at the same amount of air.
This is the real purpose of larger fans. (Note: noise is strictly driven by the rpm, the higher the rpm the higher the noise)
I trust this helps. Give a man a fish and feed him for a day, teach a man to fish and feed him for a lifetime.
kevinc313
- Ribbons : 22
Wednesday, October 14, 2020 2:16 PM
irakandjii I read with great interest a discussion regarding high temperatures on a FTW 3080. There was a lot of speculation regarding the root cause. It turned out that the problem was mitigated by adding some fans to the case. I would ask that EVGA provide some design data on the air flow rate required by the FTW3 cards to ensure adequate cooling. Reason outlined below. My background is mechanical (aeronautical) engineering so thermodynamics / aerodynamics was part of my training. At the air velocities generated in a computer case and through a GPU card, the air flow is incompressible. This means there is useful data that would help in designing case builds and diagnosing overheating problems. 1) If we knew the "ideal" airflow through the GPU at a couple of points, say:
With this data, can calculate a estimated minimum airflow required through the case. Basically you want to replace the total amount of air in the case with AT LEAST the "ideal" airflow required through the GPU as stipulated above. Put simply. You want to get rid of the air, you just heated, with the GPU just as fast as you heated it up! So how would I create a simple rule of thumb for case airflow? (Note: I could get way more complex, but that would really mess up the "rule of thumb".) So let's take an educated guess and make a simplified example of the method assuming 100% fans speeds on the GPU My assumptions about the FTW3 Ultra: A high end noctua NF-F12 120mm industrial fan turning @2000 rpm moves air at 122 m3/hr or approx. 72 CFM Lets assume the FTW is using comparable technology, the blade area will be less since the fan is smaller. So I will "wave hand" and assume each of the 3 GPU fans can push 100 m3/h or 59 cfm. So with 3 fans, I would need 177 or approx. 180 cfm of fresh air to "feed" this ideal GPU. Note: due to restrictions in the flow etc. The number would be lower. Now we have a starting point and can do a rough specification on the case. Case fans: Let's assume we use Noctua case fans.
Excellent work. Sorry to see these clowns hijacking your thread.
post edited by kevinc313 - Wednesday, October 14, 2020 2:24 PM
kevinc313
- Ribbons : 22
Wednesday, October 14, 2020 2:37 PM
njbongo I have an MSI Sekira 500x (recently bought it, just for a change).
Garbage airflow, why did you buy it?
njbongo
Wednesday, October 14, 2020 6:15 PM
kevinc313
Because, that's not true, and I felt like it.
kevinc313
- Ribbons : 22
Wednesday, October 14, 2020 7:49 PM
njbongo
kevinc313
It's literally a glass box with tiny mesh side vents.
njbongo
Thursday, October 15, 2020 8:05 PM
kevinc313
njbongo
kevinc313
I'm sitting next to the case as we speak, the vents along the sides, front, and bottom on both sides are far from tiny. If I put my hand along the top side vents I can actually feel the hot are getting pushed out from the radiator underneath it which is setup as push/pull using the rad fans and the case fans. If you actually read my original post, I'm already getting decent temps on my current hardware. I only asked irakandjii for his opinion to see if there was something I can add or change to IMPROVE airflow more before I actually get my 3080, it wasn't about airflow issues. Is there a point you're trying to make, or just random comments you feel like we need to know about?
- Ribbons : 123
Thursday, October 15, 2020 8:19 PM
Airflow is one of the issues in any case You need to remove the heated air from around the cooler, before it gets recycled into the cooler - this causes a heat loop
kevinc313
- Ribbons : 22
Thursday, October 15, 2020 8:20 PM
njbongo
kevinc313
njbongo
kevinc313
You are not getting good results. 72C on a 9900K with a 360mm AIO with push pull fans is bad. 75C on a 2080 Ti is bad.
njbongo
Thursday, October 15, 2020 8:22 PM
irakandjii
What this means :
- or,
irakandjii, THANKS !!!! There's some confusion. First, the rear exhaust is 140 not 120, my bad. Also, the radiator does have a push/pull config already. I flipped the top case fans to exhaust. mounted the radiator under them, and the radiator fans at the bottom also se to exhaust to the air is all moving in the same direction. You are right about the ASUS 2080 ti, it IS designed really well. But, with the RTX 3080 shortages, and EVGA's que system my chances of getting an EVGA card are obviously WAY better. I read today that out of all the stores that took preorders, all the ASUS models had the highest numbers, it does not surprise me. This is the one I had https://www.asus.com/Graphics-Cards/ROG-STRIX-RTX2080TI-O11G-GAMING/HelpDesk_Download/ I just sold it a few days ago for a ridiculous price because I MIGHT upgrade to the new AMD 5900x after I see third party benchmarks. I'm currently using my old ZOTAC 1070 AMP EXTREME until I get a 3080. Anyway, thanks for the advice again! I guess at this point I will wait and see how the 3080 performs, but like you, I am interested to see if I get crazy high temps like all the people on the forum are posting. I hope not, because I don't want to have to RMA or sell the card to get a different brand......who knows when I would get another in either option.
njbongo
Thursday, October 15, 2020 8:36 PM
kevinc313
njbongo
kevinc313
njbongo
kevinc313
In what universe? Those temps you took from my post are MAX temps during a 1 hour stress test at 100% load on BOTH, not average. I also did not play with any fan curves for the case fans, NXZT Kraken or the GPU fans, and left everything at stock settings to see how everything performed. The actual temps while gaming are much lower. I didn't post my average temps for "normal use", which right now are CPU 31C and GPU 35C which is now my old 1070 since I sold the 2080 ti. But that card was within -/+ 2 or 3 degrees at idle. Not everyone wants a jet engine turbine on their desk, and compared to reviews of other cases, those temps are more than acceptable. I'm not looking for the lowest temps possible, I'm making sure NOTHING is getting throttled when playing games, and it isn't.
post edited by njbongo - Thursday, October 15, 2020 8:41 PM
kevinc313
- Ribbons : 22
Thursday, October 15, 2020 8:50 PM
njbongo
kevinc313
You didn't cite ANY sort of app or load or power level or OC. So yeah, those temps are bad.
njbongo
Thursday, October 15, 2020 9:07 PM
kevinc313
njbongo
kevinc313
Actually, I DID state those temps were max temps at 100% load for a stress test. The 9900K and the 2080ti both start throttling around 84-89C, that's common knowledge any idiot can find at any good review site. Both my stress test and gaming temps are WELL under that. If I had anything overclocked, I would have stated it. Maybe learn to read?
Hoggle
Thursday, October 15, 2020 9:08 PM
I would think that the computer would overheat long before any quality tempered glass case would have any trouble.
kevinc313
- Ribbons : 22
Thursday, October 15, 2020 10:26 PM
njbongo
kevinc313
njbongo
kevinc313
Sigh. 100% *utilization* is meaningless when attempting to describe cooling capability. On a 9900K, 100% utilization can be anywhere from under 100w to over 200w, on stock settings. More with an OC. On a 2080 Ti, 100% utilization can be under 260w with a light load that's hitting voltage/frequency limit with stock settings, or up to ~375w-380w with a power limited heavy load with a Galax or FTW3 bios OC'd. Watts -----> Temps. I'm currently running CPU-Z stress test which is a light 115W load (100% utilization) on my 9900K stock, while simultaneously running Unigine Heaven at stock 260W TDP on 2080 Ti (power limited, 85-100% utilization). 9900K package at 68C after a half hour.........with my TINY 120MM Evga CLC120 AIO. My GPU is at a luke warm 49C with a hybrid kit. I could run this for a day and my temps wouldn't budge. Everyday fan settings. I hit about 75C after a half hour of handbrake (AVX) at 150w. Let me reiterate that's with a 120MM AIO. Oh.....and my case is a 4U rack case with a 1814 in3 volume, less than half your case's ~4000 in3 volume. With four 120mm fans and two 80mm fans. 3 NMVe ssd's and 2 spinners. So yeah, your temps are bad and you should feel bad. Please go run Prime95 Small FFT with AVX and report back with power and temp readings. Good luck.
post edited by kevinc313 - Thursday, October 15, 2020 10:51 PM
njbongo
Friday, October 16, 2020 0:07 PM
Sigh. 100% *utilization* is meaningless when attempting to describe cooling capability. On a 9900K, 100% utilization can be anywhere from under 100w to over 200w, on stock settings. More with an OC. On a 2080 Ti, 100% utilization can be under 260w with a light load that's hitting voltage/frequency limit with stock settings, or up to ~375w-380w with a power limited heavy load with a Galax or FTW3 bios OC'd. Watts -----> Temps. I'm currently running CPU-Z stress test which is a light 117W load (100% utilization) on my stock 9900K, while simultaneously running Unigine Heaven at stock 260W TDP on 2080 Ti (power limited, 85-100% utilization). 9900K package at 68C after a half hour.........with my TINY 120MM Evga CLC120 AIO. My GPU is at a luke warm 49C with a hybrid kit. I could run this for a day and my temps wouldn't budge. Everyday fan settings. Oh.....and my case is a 4U rack case with a 1814 in3 volume, less than half your case's ~4000 in3 volume. With four 120mm fans and two 80mm fans. So yeah, your temps are bad and you should feel bad. Please go run Prime95 with an AVX load and report back with power and temp readings. Good luck. Actually, they aren't, I probably made a typo in my original post, and did not even catch it until now. My max temp under load is 62, not 72. Really wasn't relevant to my question for irakandjii since it was about case fan placement and direction, which he answered thoroughly. The screen shot is from Prime95, w/AVX and you can see the timestamp. And before you bother commenting, the 97% CPU load in the screen shot is because I clicked on the screen grab icon on the task bar to tale take the picture. It was running at 100% up until then for about 30 mins. I can't wait for the next issue I "should feel bad" about. https://drive.google.com/...NPfvoJzTcVXFGZyst/view
kevinc313
- Ribbons : 22
Friday, October 16, 2020 0:42 PM
njbongo Actually, they aren't, I probably made a typo in my original post, and did not even catch it until now. My max temp under load is 62, not 72. Really wasn't relevant to my question for irakandjii since it was about case fan placement and direction, which he answered thoroughly. The screen shot is from Prime95, w/AVX and you can see the timestamp. And before you bother commenting, the 97% CPU load in the screen shot is because I clicked on the screen grab icon on the task bar to tale take the picture. It was running at 100% up until then for about 30 mins.
OK, almost there. Run Prime95 AVX Small FFT for 10 minutes and post a screen shot of HWiNFO64 or HWMonitor showing CPU POWER along with temps. You can't make a claim about temps and having effective cooling without citing power draw.
njbongo
Friday, October 16, 2020 0:50 PM
kevinc313
OK, almost there. Run Prime95 AVX FFT for 5 minutes and post a screen shot of HWiNFO64 or HWMonitor showing CPU POWER along with temps. You can't make a claim about temps and having effective cooling without citing power draw.
Really I can, because my question was to the OP about fan placement and mounting direction, asked an answered. My goal in life is not sitting around running stress tests all day, the only reason I even bothered to post this picture was because of my typo in my first post. We're done, none of this is going to simulate using my PC to play games, or help.
kevinc313
- Ribbons : 22
Friday, October 16, 2020 1:00 AM
njbongo
kevinc313
OK, almost there. Run Prime95 AVX small FFT for 10 minutes and post a screen shot of HWiNFO64 or HWMonitor showing CPU POWER along with temps. You can't make a claim about temps and having effective cooling without citing power draw.
Your temp claims are completely pointless if you're not citing power figures. Your temps are still bad and your case still has poor air circulation. Prove me wrong. I'm not the one who hijacked this thread.
post edited by kevinc313 - Friday, October 16, 2020 1:18 AM
njbongo
kevinc313
njbongo
kevinc313
Your temp claims are completely pointless if you're not citing power figures. I'm not the one who hijacked this thread.
And your comments on this thread are completely pointless in regards to my question to him. If criticizing the products (with baseless information) other users on the forums have, or like, does something for you, maybe find some new hobbies. I'm also not the first person to comment on the thread after he posted it, but was genuinely trying to help the person that "hijacked the thread" asking about his side panel. The only reason I even asked irakandjii a question was because I saw his background, that he posted, and thought he would have a decent opinion on fan placement and it was sort of related to what he was talking about. And by the way, that comment you posted to me that you decided to delete or edit, I actually saw because I got the Subscription Notification email before you made the change, and it proves my point. You're not trying to help anyone. "sigh" to you too.
kevinc313
- Ribbons : 22
Friday, October 16, 2020 1:34 AM
njbongo
kevinc313
njbongo
kevinc313
You're not going to get anywhere here if you're not willing to post relevant data. Good luck.
njbongo
Friday, October 16, 2020 1:51 AM
