AMD Radeon "RDNA 4" RX 9000 Series Will Feature Regular 6/8-Pin PCI Express Power Connecto
  • Ribbons : 86
2024/12/31 00:42:19 (permalink)
https://www.techpowerup.com/330348/amd-radeon-rdna-4-rx-9000-series-will-feature-regular-6-8-pin-pci-express-power-connectors
AMD will continue using traditional PCI Express power connectors for its upcoming Radeon RX 9000 series RDNA 4 graphics cards, according to recent information shared on the Chiphell forum. While there were some expectations that AMD would mimic NVIDIA's approach, which requires the newer 16-pin 12V-2×6 connector for its GeForce RTX 50 series, the latest information suggests a more traditional power approach. While AMD plans to release its next generation of graphics cards in the first quarter, most technical details remain unknown. The company's choice to stick with standard power connectors follows the pattern set by their recent Radeon RX 7900 GRE, which demonstrated that conventional PCI Express connectors can adequately handle power demands up to 375 W. The standard connectors eliminate the need for adapters, a feature AMD could highlight as an advantage. An earlier leak suggested that the Radeon RX 9070 XT can draw up to 330 W of power at peak load.
Intel reportedly cited similar reasons for using standard power connectors in their Arc "Battlemage" graphics cards, suggesting broader industry support for maintaining existing connection standards. NVIDIA's different approach reportedly requires all board partners to use the 12V-2×6 connector for the RTX 50 series, removing the option for traditional PCI Express power connectors. In contrast, AMD's decision gives its manufacturing partners more flexibility in their design choices, and MBA (Made by AMD) reference cards don't enforce the new 12V-2×6 power connector standard. Beyond the power connector details and general release timeframe pointing to CES, AMD has revealed little about the RDNA 4 architecture's capabilities. Only the reference card's physical appearance and naming scheme appear to be finalized, leaving questions about performance specifications unanswered, as early underwhelming performance leaks are somewhat unreliable until final drivers and final optimizations land.
I assume this approach will also save AMD some money.
0 Replies Related Threads
