Just got my 980 classy and I love it but I wanted to make sure I don't screw it up. My corsair RM750 power supply's 8pin PCI cahles are daisy chained. 2 8 pin is on one cable (going to psu).
Will it be ok to use that or should I use 2 cables ? I recall the amd 295x2 you need to have 2 separate 8pins with at least 30 amps on each. Now I know that card is a dual gpu 500 watt tdp but Id though I'll ask if my daisy chained PCI power will be ok for this.
Thanks
Intel Core I9 9900K @ 5ghz
Gskill 32GB (2X16) DDR4 @3200mhz
EVGA RTX 2080 Ti FTW3 Hydrocopper
GIGABYTE Z390 AORUS MASTER
Fractal Design DEFINE S
Corsair RM750 Gold PSU
Asus PG27UQ 4K 144hz HDR G-Sync monitor
EK Supremacy Clean CSQ Nickel + Plexi
EK D5 Vario X-RES 140
Alphacool NexXxoS ST30 Full Copper 240
Alphacool NexXxoS XT45 Full Copper 360
Bitspower Black Sparkle 3/8" (5/8") Fittings
