5.1 Ghz i5 2500K using H60 With Temps! with bios settings! *updated*
C3B0E5FFF3F141E
  • Ribbons : 9
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 05:32:53 (permalink)
OH DUDE im not jelous anymore your using turbo to overclock
turbo can be sustained for only X-amount of time it will sag up and down....still tho your voltage is low
#61
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 05:42:22 (permalink)
warlord420
since u cannot overclock with bclk clock anymore on the new uefi bios, u have to use turbo modifier.. it is not possible to get over 107 bclk clock! :).. it is a new way of overclocking asus found that is better, plus it saves some power (and we are a little green to the environment)
so you have to be jealous ;).. turbo can be sustained for the amount of time u want it.. i can even disable turbo and run 5.1 ghz all the time! :)..
btw, my voltage is not too low since i am stable.. have run linx for hours, and testing with games :).. my computer have not been turned off for days ! ;)..
I am Happy
#62
C3B0E5FFF3F141E
  • Ribbons : 9
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 06:27:34 (permalink)
nah your just a show off :))
i just booted with 4.9 ghz using 1.47 volts ran fine but temps were in mid 70's and its 65 degrees outside in about 3 hours it will turn into a oven.
when my EVGA cooler gets here i will join the club , ill sit there and blow into the cooler if i have to :)
btw your fans are AWSOME i been getting those for last 2 years. the blades are fragile but they move air like madddd
#63
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/17 06:41:01 (permalink)
warlord420
indeed nice fans! :)
looking forward to seeing u in the 5 ghz club! ;).. we are only 2 in there at the moment! :)
very high voltage btw!.. i did 5 ghz with 1.43 stable :P..
but it is real what i am saying :P.. you can't overclock with blck clocking anymore! .. took me a time to get used to i couldn't just put 134.5 in there or something :P.. tried for some time putting in random numbers, adding voltage, taking off voltage.. i couldn't get it to boot what so ever!..
then i went on the internet and after surfing a lot, looking videos and reading , i found out that u can only overclock via multiplier! :)..
it was some new stuff that Asus invented in their "bios" which is called UEFI bios! :P
look this vide .. he works for asus and tells about the new way of overclocking! :)
post edited by IstBarP - 2011/06/17 06:44:02
#64
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 08:19:55 (permalink)
hey there everyone,
im having some issues getting my 2600k to 5.0 stable. I was able to boot at 5.0 and run 20 passes of intel burntest with 1.432 vcore.
But it wouldnt pass 50 passes so i have been bumping voltage and havnt gotten stable yet, but the computer just reboots and i dont get a BSOD so i dont get a code to go off of.
any ideas. VCCIO is set to 1.2 and Vcore is now around 1.46 volts.
Rig Info:
I7 2700K stock clocks(for now)
Gigabyte P67A-UD7
Corsair Vengeance 4x4GB
EVGA GTX TITAN SC
Corsair AX1200
Custom Water Cooling
Corsair Obsidian 800D
#65
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 08:36:27 (permalink)
what motherboard u have? :)..
#66
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 09:04:30 (permalink)
P8P67M-Pro, i know its not the best board for Bios control but i Have seen plenty of people hitting 5.0 on it. Its a pretty decent little microATX board.
Rig Info:
Gigabyte P67A-UD7
EVGA GTX TITAN SC
Corsair AX1200
#67
wmmills
  • Ribbons : 40
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 09:14:34 (permalink)
hay man..i found a new app i kike for temp,load,cores,hdd,gcard monitoring etc... its called open hardware monitor beta...works very well. give it a shot...i think youll like it!!
http://openhardwaremonitor.org/
MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW
 New EVGA product? Register it NOW with this link:
http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII
 Help Our Vets From K-2!
[link=https://strongholdfreedom
#68
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 09:56:53 (permalink)
cblaxx
you followed my Bios settings? .. i were stable with 1.43 volts vcore..
the other volts leave them on auto! :).. board should handle that fine! :)..
oh and btw,
load-line calibration = ultra high
VRM frequency = auto
Phase control = extreme
Duty control = extreme
CPU current capability = 110%
use these settings too under AI tweaker! :)..
#69
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 11:39:45 (permalink)
i dont have those extra settings available to me :(
i can only enable LLC, no different levels.
Rig Info:
Gigabyte P67A-UD7
EVGA GTX TITAN SC
Corsair AX1200
#70
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 14:10:37 (permalink)
hmm... so u changed the multiplier to 50 and turned of the EPU?.. :)..
voltage should be around 1.43 as i said earlier..
what blue screen are u getting? :)..
this was posted by another member in here... kody7839 if i remember right! :)
"BDOS CODES: Here is a list of Common BDOS Errors and what to do to get rid of them; these suggestions are from trial and error, and many BDOSes from hundreds of hours of overclocking. I have gotten many of these BDOSes and checked them out (tried to cause them) and I have modified that list, here it is.
BSOD Codes  0x124 = add/remove vcore or QPI/VTT voltage (usually Vcore, once it was QPI/VTT)
0x101 = add more vcore
0x50 = RAM timings/Frequency add DDR3 voltage or add QPI/VTT 0x1E = add more vcore
0x3B = add more vcore
0xD1 = add QPI/VTT voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0X109 = add DDR3 voltage
0x0A = add QPI/VTT voltage"
#71
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 14:12:47 (permalink)
im not getting a blue screen, the computer just reboots. i dont get it.
I dont think my board has EPU, but the TPU is turned off.
the no BSOD is the issue cause i have no way of knowing what went wrong.
Rig Info:
Gigabyte P67A-UD7
EVGA GTX TITAN SC
Corsair AX1200
#72
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 14:15:09 (permalink)
cblaxx
what voltages are u using
or what have u changed? :)..
#73
cblaxx
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 14:46:46 (permalink)
Im using a ~1.46 vcore. my board only supports offset voltage control and not manual(major pain in my opinion). I bumped the VCCIO voltage to 1.2 since i read somewhere that bumping that could help with stability at higher speeds, seemed to help a little but nothing major.
other than that, there arent many more options for me to change.
no phase stuff, just can turn LLC on but no levels. PLL voltage is eneabled but again, i cant control the level of that voltage.
PS. im using an H60 for the cooling, Its doing a decent job, i havnt had any alarming temperatures yet.
Rig Info:
Gigabyte P67A-UD7
EVGA GTX TITAN SC
Corsair AX1200
#74
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 15:05:47 (permalink)
hmm.. doesn't seem like a good motherboard to overclock on.. u sure there is no manual voltage
try lowering ur voltage to 1.41 on vcore, this guy runs p8p67M pro and 5 ghz.. could be that ur voltage is too high that it just restarts.. :)
http://forums.hardwarezone.com.sg/showthread.php?t=3063249
remember to keep an eye on the temps.. was around 5.0 with linx i hit the 86 degrees where the motherboard tool began to alarm me of temps :P..
got mine running 5.1 though without increasing temps.. :P.. but to get to 5.2 i'll have to increase voltage much :/..
#75
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 16:13:56 (permalink)
btw.. i read this on another forum!
Expectations regarding K series overclocking in general and on ASUS P67 motherboards
 Prior to the recommendations on overclocking the K series, I am outlining our results to set expectations.
The results below are based on the range of the CPU turbo multiplier when overclocking.
Results are representative of 100 D2 CPUs that were binned and tested for stability under load; these results will most likely represent retail CPUs.
1. Approximately 50% of CPUs can go up to 4.4~4.5 GHz
2. Approximately 40% of CPUs can go up to 4.6~4.7 GHz
3. Approximately 10% of CPUs can go up to 4.8~5 GHz (50+ multipliers are about 2% of this group)
http://hardforum.com/showthread.php?t=1578110
#76
HeThing
  • Ribbons : 42
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 16:58:06 (permalink)
IstBarP
showoff on luckyness!
#77
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 17:15:28 (permalink)
hething
IstBarP
#78
HeThing
  • Ribbons : 42
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 17:19:13 (permalink)
#79
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 18:45:16 (permalink)
hething
[image of third party facepalm]
jealousy is a bad thing ^^..
#80
HeThing
  • Ribbons : 42
Re:i5 2500k 4.5ghz H60 With temps 2011/06/19 18:49:11 (permalink)
says..
#81
IstBarP
  • Ribbons : 10
Re:i5 2500k 4.5ghz H60 With temps 2011/07/13 06:25:04 (permalink)
i will not stop ;D..
hehe
#82
