4-pin Molex/Peripheral Cable to power PCIE Riser?
BlakeTheDolphin
2021/03/29 11:30:18 (permalink)
Hello,
I would like to power a PCIE Riser (max wattage pull = 75 watts) with the Molex 4-pin cable that came with my Supernova P2 750 PSU.
Does anyone know the max wattage EVGA's 4 pin molex/peripheral can handle?  FYI - the riser will be power a 1660 super.
I saw an older post saying the max was 54 watts for the molex, but I find that suprising...
1 Reply Related Threads
    • Ribbons : 270
    Re: 4-pin Molex/Peripheral Cable to power PCIE Riser? 2021/03/29 11:52:26 (permalink)
    54 watts is the ATX certified standard.
    That's why 6-pin PCI-E power cables (which are certified for 75 watts) always used two molex connectors when using adapters.
    Don't skimp.
    If your riser board only has 1 molex connector, it was not manufactured in compliance with these standards. Don't use it. Who knows what else is wrong with it. Get a better riser board which is manufactured per standards. If the riser board gets its power directly from the PSU, per standards, it needs 2 molex connectors, or 1 6-pin PCI-E connector.
    post edited by ty_ger07 - 2021/03/29 11:58:37
