Answered3090ti ftw3 ultra Power Draw Question
HeavyUser
2022/05/10 15:05:58 (permalink)
While gaming and benchmarking I noticed the max power draw for my card has peaked at 465watts. I was under the impression it should be using up to 480watts?
I'm running a +125/+850 overlock, voltage and power sliders are set to max in X1, 850watt PSU. Any ideas why I'm not pulling more watts?
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:10:48 (permalink)
850watt psu?? Wow.. living on the edge.
I think min requirement for the 3090ti is 1000watt psu.
I'd use a 1200watt min. Realky I'd feel more at ease with a 1600watt psu and forgetaboutit.
Asus Z390 ROG Extreme XI MB
kraade
  • Ribbons : 7
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:13:32 (permalink) ☼ Best Answerby HeavyUser 2022/05/10 15:21:15
Gaming never pulls full power target, Open Kombustor and Look again
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:18:53 (permalink)
AHowes
Both EVGA and Newegg have the recommended power supply at 850.
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:22:01 (permalink)
HeavyUser
AHowes
So you want over 500watts and leave the rest of the system with 350watts.. prob less.
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:22:06 (permalink)
kraade
This was the answer, downloaded and installed Kombustor --- 475watt power draw.
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:24:13 (permalink)
AHowesSo you want over 500watts and leave the rest of the system with 350watts.. prob less.
No, I only wanted to make sure the card can reach it's peak rated power draw of 480watts. I never mentioned wanting over 500watts.
With prime 95 running and furmark my entire system draw is under 750watts.
post edited by HeavyUser - 2022/05/10 15:50:07
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 15:34:47 (permalink)
My 3090 ftw3 ultra usually will max at 450watts using their 500 watt xoc bios. Throws up power limit from 424watts and on.. solid.
You make sure your on the OC bios? And not the normal bios if theirs a switch?
When your system starts blue screening and randomly rebooting.. think bigger psu. May not be today but maybe months or a year from now with that psu runing full tild majority of the time.
talon951
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 16:23:41 (permalink)
HeavyUser
You're fine with a 850w PSU if it's a decent one. I've hammered my RM850x with the Galax 1kw bios pulling 600w+ on my 3080ti with no issues.
kraade
  • Ribbons : 7
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 16:40:34 (permalink)
Ya I've Pulled 600+w on a KPE with a EVGA 850 Platinum but that was in PR, would not try that now with my OC'ed 12900k
talon951
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 17:24:44 (permalink)
kraade
That's true. I have AMD cpus in both machines which pull less power. Is your cpu power draw that much higher in gaming though? I saw a test somewhere (forget which) recently that only showed a small difference in gaming power draw between AMD and 12th gen.
badboy64
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 17:30:54 (permalink)
What are the rest of your system specs? Are you playing games with a 4k monitor max setting on games or playing at 1440 resolution with max settings? Are you gonna play Kombustor all of the time to get the max power from your 3090Ti card all of the time?
post edited by badboy64 - 2022/05/10 18:59:08
14th Intel® Core™ i9 13900KS CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling.
Speed Way  Score 11,144 points.
http://www.3dmark.com/sw/1540960
kraade
  • Ribbons : 7
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 17:44:06 (permalink)
talon951
kraade
yes in gaming situations it is probably only at 60% utilization and probably only pulling 150-179w , Cinebench its 320w to get that score in the low to mid 29 K and still safe to game. and really as far as that goes I could pimp it out more knowing I'm not close to TJ max but getting ejected from a race is costly in points.
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 17:54:52 (permalink)
Appreciate all the help guys, this was solved. I didn't realize that some games will not pull the max 480watts. I installed Kumbustor as previously suggested and saw a 475watt power draw.
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 17:58:14 (permalink)
People always cheap out on the psu.. always. Like I bet most of the posts on here are because of old cheap psu's.
2k+ gpu and a Buck 50 psu.. yeah let's rock!
I've blown $1100 on my motherboard, $500 on the cpu, $2k on the gpu and $500 on the ram $600 on the drives and prob 2k+ on the water cooling and I still 2nd guess my 4 year old evga 1300watt G2 PSU.
Missed the dang last psu sale by minutes for a bad @aa 1600watt psu.. not for the wattage per say but for the quality.
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:01:28 (permalink)
kraade
Metro exodus pc enhanced edition @ 4k & almost max/max settings pulls tons of power.
kraade
  • Ribbons : 7
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:02:02 (permalink)
MEGA sales on PSUs right now on EVGA.com
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:05:31 (permalink)
kraade
Yup.. elite sale currently for the 1300watt psu's.
AHowes
  • Ribbons : 27
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:05:54 (permalink)
kraade
Glad I got that game installed haha. , ;)
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:16:24 (permalink)
AHowes
kraade
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:24:06 (permalink)
AHowes
I'm using a Cooler Master V850 SFX Gold. It was the highest wattage psu I could fit into a mini-itx case. Unfortunately my choices were very limited due to the size of the case.
  • Ribbons : 135
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:37:06 (permalink)
HeavyUser
AHowes
As a rule of thumb you should size your PSU so that under maximum load,  you never exceed 80% of its rated continuous output on the 12v rail.
As a personal thing, I don't have that much sympathy for  ITX case users with power hungry components.  9 times out of ten, they are losing significant performance just because of being unable to control thermals.
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/10 18:43:41 (permalink)
Luckily I have zero thermals issues.
GPU Hotspot Temp maxes out at 78.9c. Below thermals are after a few hours of RD2.
https://photos.app.goo.gl/5Jv7R7D8ouVrkUVx9
#23
B0baganoosh
  • Ribbons : 42
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/11 07:13:49 (permalink)
kraade
Also, BFV will max you out while loading the next map. If you have speedy SSDs, it won't do it for very long, but you'll still be drawing 90+% power from your GPU and 100% max your CPU for that map load. It was quite handy to find out if my temperatures were stable with my overclocks actually. First map gets a good heat-soak going, then you start loading the next map (while GPU is still rendering stuff) and your CPU pegs to 100%...here come the temperatures.
6Q6CPFHPBPCU691 is a discount code anyone can use.
i9 13900k - EVGA Z690 Classy - Nvidia RTX 4090 FE - G.Skill 64GB DDR5-6000CL30  - WD SN850 2TB NVMe Gen4 - Be Quiet! Straight Power 12 1200W - Be Quiet! Dark Base 900 Pro. MO-RA3 420 Pro. Dark Palimpsest MODS RIGS post for build notes.
#24
HeavyUser
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/11 07:28:28 (permalink)
B0baganoosh
BFV was weird for me. At 2k res the gpu usage would fluctuate from 80-95%usage, it never pegged at 99% like it should have. I had all the graphics turned up and no dlss. Do you game at 4k?
#25
B0baganoosh
  • Ribbons : 42
Re: 3090ti ftw3 ultra Power Draw Question 2022/05/11 10:44:05 (permalink)
HeavyUser
Nope, 1440p. The GPU power % does usually fluctuate in that game (and most). I was mainly referring to the CPU going to 100%. The GPU stays heavily loaded in that time, the 80-95% number you gave lines up with what I've seen. I think I have seen it go to 99% while actually playing, but at that point my CPU has dropped to about 40%. It's just the map-loading part where the game is still rendering scenes on the screen where you're GPU is fairly heavily loaded still and your CPU cranks up full speed. My settings are 1440p, everything on Ultra, DX12, all RT on high, DLSS off (I think they may have disabled it because it was completely broken), and I turn one of the terrain settings to medium because that exposes snipers that think they're hiding in bushes. Also, I turn off motion blur, lens flare, chromatic aberration, and vignette.
Also, 2042, while I haven't touched it in months...because...well 2042...anyway it doesn't use all of any of my hardware. I can never get it to use more than ~70-80% of my GPU power limit and 30-45% of my CPU. Nothing I change gets me more FPS in that game. It just makes my GPU load go down even farther.
What CPU do you have? BF has generally been one of those engines where it only uses so many threads (I think BFV can use 8?), but it wants the CPU cores those threads are on to be really fast in order to feed the GPU more data. Of course, this is pre-2042...no idea what that game is trying to do. It is extremely poorly optimized. Anyway, in BFV, the 3090ti might be powerful enough to chew through everything you try and send to it with any CPU that currently exists unless you're at 4k...so because the game is CPU-thread limited, it can't send your GPU any more data.
#26
