vgerik1234
SOLVED: Edit-Update: Its my brand new 1000W PSU giving the coil whine. I shoved a mic all around the GPU doing a recording, trying to find the exact spot it was coming from. It was perfectly consistent throughout the card. I decided to close my case and I set the mic down right behind the PSU. The buzzing was 3x louder. So I took it out of the case and ran everything like I have been. 100% confirmed its the PSU. It was buzzing so loud, it echoed through the case and making it sound like it was coming from the GPU. This is the first time I have actually stressed the PSU since I got it, so it probably wasn't visible until it started getting load. Before the 3090 at peak I was pulling maybe 550W on it. ------------------------------- TLDR: EVGA 3090 FTW - 60%+ power and card gives off electric whine, strong enough to affect sound card 4 slots away. So while troubleshooting my issue with audio whine through the EVGA NU soundcard, I discovered that my 3090 is giving off a boatload of EMI. Enough to affect my audio card 4 slots away. So I took off the side panel of my case and noticed that there is a buzzing/whine from the card sometimes. When the buzzing happens, the noise goes through my speakers as well (EMI). It is not coming from the fans I don't think, because the sound happens even when they are set to 0%. This whine only happens when the power % is above 60% according to the latest Precision. when I first installed the latest precision it updated my firmware. Video: https://www.youtube.com/watch?v=BdTF48-BmyAVideo description: Video starts off with with precision saying power @ 50%. 6 seconds in it jumps to 100%. That is when the whine starts.
post edited by vgerik1234 - 2020/09/25 19:22:17
jPup omg
- Location: Digging through a warehouse of empty 3080 boxes
Re: 3090 FTW Electric Whine - not fan coil whine?
2020/09/25 13:51:01
Is this was jayztwocents was talking about?
jsarver101
2020/09/25 13:51:23
i believe you but im not hearing it in the video
 Enthoo Elite - Asus Rampage - 9900x 4.6 @ 1.26v - 32GB Gskill Trident RGB 3200mhz - RTX 2080Ti FTW3 - Corsair 1500i - Samsung 960 Evo 1Tb NVMe - Samsung 840 Pro 512 SSD - Samsung 850 Pro 1Tb SSD - Samsung 840 Evo 1Tb SSD- Corsair H110i - ROG Swift @ 1440p w/ Gsync x3
arestavo
- Ribbons : 77
2020/09/25 13:52:13
Coil whine can be the card's fault, or it could be from the power supply or UPS. If you are using an UPS, try plugging it directly into the wall - if that fixes it, you'll want to get a pure sine wave UPS (the cheaper ones are square wave, and I ran into an issue with one back with 780 Ti Classifieds with a nice 1000W Platinum PSU from Seasonic). If you aren't running 3 different power cables from the power supply to the card, you might want to try that. If that doesn't fix the issue, you can set a FPS cap. Really high FPS can cause coil whine. You can try a different power supply (a friend's PC maybe?). You can also run a game that causes the coil whine over night to "break in" the card. It may or may not help. Last option would be an RMA.
vgerik1234
2020/09/25 13:52:21
jsarver101 i believe you but im not hearing it in the video
Turn up the audio and wait till the 6s mark.
vgerik1234
2020/09/25 13:54:09
arestavo Coil whine can be the card's fault, or it could be from the power supply or UPS. If you are using an UPS, try plugging it directly into the wall - if that fixes it, you'll want to get a pure sine wave UPS (the cheaper ones are square wave, and I ran into an issue with one back with 780 Ti Classifieds with a nice 1000W Platinum PSU from Seasonic). If that doesn't fix the issue, you can set a FPS cap. Really high FPS can cause coil whine. You can try a different power supply (a friend's PC maybe?). You can also run a game that causes the coil whine over night to "break in" the card. It may or may not help. Last option would be an RMA.
The whine is 100% based on what the power usage/% is. This is a brand new EVGA 1000w G+. I am using a power strip, not a UPS. I will try and go direct into the wall to see if that helps though. Edit: Still happens straight from the wall.
post edited by vgerik1234 - 2020/09/25 13:56:49
arestavo
- Ribbons : 77
2020/09/25 13:56:28
vgerik1234
I edited in "If you aren't running 3 different power cables from the power supply to the card, you might want to try that." while you were replying.
vgerik1234
2020/09/25 13:57:48
I am running 3 independent cables. Also, straight to wall didn't help.
post edited by vgerik1234 - 2020/09/25 14:00:51
INGREDCOLD
2020/09/25 13:58:33
you defiantly want a dedicated plug for a 1000 watt ps
Ryzen 5800x X570 Aorus Master EVGA 3080 FTW3 Ultra 32g Ballistix 3600 2tb Intel 660 500mb WD Black EVGA 850 Super nova EVGA CLC 240mm
gsrcrxsi
- Ribbons : 5
2020/09/25 14:00:38
arestavo
vgerik1234
most likely wont change anything
gsrcrxsi
- Ribbons : 5
2020/09/25 14:03:06
some cards just have coil whine. it's been this way for a long time. the whine comes from the power delivery circuitry, not the fans. i also don't hear it in your video, with speakers at 100%
arestavo
- Ribbons : 77
2020/09/25 14:04:14
gsrcrxsi some cards just have coil whine. it's been this way for a long time. i also don't hear it in your video, with speakers at 100%
I had to turn up my 1500 watt 5.1.2 system quite a bit, but it's there.
vgerik1234
2020/09/25 14:05:55
I get coil/electric whine happens, but the fact it's so bad that its affecting my audio card with EMI 4 slots away is pretty insane. With my side panel off, I can hear it everywhere in my office. With the case closed, I can still hear 3ft away, now that I know what I am looking for :(
ngh5833
2020/09/25 14:08:13
Better sell your cards to me.
INGREDCOLD
2020/09/25 14:12:50
I heard it in my headphones
INGREDCOLD
2020/09/25 14:14:38
I had a ftw 2080 super that did the same thing. ended up taking it back to microcenter
vgerik1234
2020/09/25 14:15:14
arestavo
The microphone on my phone probably didn't pick up all the frequencies its hitting. But it is LOUDDDD at 100% power. With the side of my case off, I can hear it in the hallway 10+ feet away.
vgerik1234
2020/09/25 14:33:13
I am gonna run it at 100% for a bit to "burn it in". Hopefully it will tone down after a bit. My biggest issue is the whole EMI causing humming in my audioengine speakers :( My studio headphones somehow aren't picking the EMI up. Both being run from the EVGA NU. Edit: Whine cannot be heard if I have headphones on and side panel closed at least. So it only affects me if I am trying to game w/ speakers or do any rendering work :\
post edited by vgerik1234 - 2020/09/25 14:40:59
Urieldagda
2020/09/25 14:47:31
I can hear something but no whine. Guess my ears suck.. The 3080 XC2 issue with the fans beeping, THAT I heard loud and clear in the requisite video. lol
INGREDCOLD
2020/09/25 15:06:03
I hope everything works out for you
degenerate
2020/09/25 15:06:30
Based on the video your issue doesn't sound as loud/severe but I noticed this was very common in my time spent with 2080Ti's. I had 4-5 different 2080Ti's and they all had varying degrees of VRM/inductor noise, more like a mechanical chirping/switching sound, not a coil-whine. EVGA FTW3 and MSI Lightning were the worst, even my Kingpin had it. Hopefully it is not the same experience with the 3000 series. FWIW based on the PCB's I've seen thus far the Strix cards seems to use the highest quality parts. *Edit - An interesting watch... maybe related maybe not.
post edited by degenerate - 2020/09/25 15:14:37
|5900x|MSI B550 Unify-X|2x16GB G.Skill 3800 C14 @ 1900 FCLK|2TB WD SN850 M.2|EVGA 3090 KPE|EVGA 1600T2|Alienware '25' & LG 48" CX OLED|
vgerik1234
2020/09/25 15:38:46
degenerate Based on the video your issue doesn't sound as loud/severe but I noticed this was very common in my time spent with 2080Ti's. I had 4-5 different 2080Ti's and they all had varying degrees of VRM/inductor noise, more like a mechanical chirping/switching sound, not a coil-whine. EVGA FTW3 and MSI Lightning were the worst, even my Kingpin had it. Hopefully it is not the same experience with the 3000 series. FWIW based on the PCB's I've seen thus far the Strix cards seems to use the highest quality parts. *Edit - An interesting watch... maybe related maybe not.
The video seems that is mostly related only to OC'ing stability. On the plus side, my OC'ing hasn't been a problem. The noise is much louder than the video makes it sound. After running 100% power draw for a while now testing OC's, I think the noise is getting better, but it still is pretty loud. Until an EVGA person chimes in, I have basically done all that is possible and will just keep breaking it in. On the super plus side, the studio drivers let me game and the 3090 is a life changer vs my old 980ti :D
eldub0844
2020/09/25 15:42:03
vgerik1234
980Ti to 3090? Wow, that's a HUGE upgrade, enjoy! I'm keeping a close eye on what Jay just reported, I'm not spending a dime until someone speaks up from the manufacturer side!
nirvashone
2020/09/25 15:53:11
vgerik1234 I am gonna run it at 100% for a bit to "burn it in". Hopefully it will tone down after a bit. My biggest issue is the whole EMI causing humming in my audioengine speakers :( My studio headphones somehow aren't picking the EMI up. Both being run from the EVGA NU.
the reason your headphones arent picking it up is probably because theyre shielded. get a better speaker cable, but just to be sure, plug your headphones into all of your audio out jacks to rule out EMI to the audio processor.
vgerik1234
2020/09/25 15:55:42
eldub0844 980Ti to 3090? Wow, that's a HUGE upgrade, enjoy! I'm keeping a close eye on what Jay just reported, I'm not spending a dime until someone speaks up from the manufacturer side!
Yeah, for now just having a new GPU is making me insanely happy. The coil whine is annoying, but no point in doing an RMA (if it is faulty) until there is some manufacturer confirmation and a known fix. If I did try and RMA now, I would just get another 1st batch which would probably be affected the same. No rush, just gotta adapt for the time being and hope there is a solution in the future. I hope its just a burn in thing to lower the whine to a non-issue level.
terry2776
2020/09/25 15:57:39
I received a 3090 FTW3 Ultra and I haven't experienced any of that coil whine or EMI affecting audio, been testing for a couple hours now to beat on it. Hopefully they let you RMA if you can't resolve it.
Intel i9 9900K @ 5GHz Corsair H110i AIO Liquid Cooler Gigabyte Z390 Aorus Master 32GB (4x8GB) GSkill TridentZ RGB @ 3600MHz 16-19-19-39 1.35v Samsung 960 Pro 1TB NVME SSD eVGA RTX 3090 FTW3 Ultra 24GB 1000W Silverstone Strider Plus ST1000-P Power Supply Phanteks Enthoo Primo Case w/ 7 x 140MM Fans Acer Predator XB241YU Monitor 1440p 144Hz Windows 10 Professional 64-Bit
vgerik1234
2020/09/25 16:06:56
nirvashone
I sandwiched 2mm of aluminum foil between two pieces of cardboard and placed it on top of the audio card, the EMI static noise dropped by more than half. So... yeah definitely EMI. I am gonna double the foil and then figure out how to mount it above the soundcard without having it touch. Don't want cardboard to catch on fire somehow.
vgerik1234
2020/09/25 16:25:03
https://www.youtube.com/watch?v=hnLwCg04hUIHere is a 2nd video. Coil whine starts at 2s into it. I tried to lower the fans enough where it wouldn't block the sound but not burn out the card. It is NOT coming from the exposed back area of the card. It definitely is coming from the front of the board some where, or all over it. It still happens with the fans set to 0%. It still happens with LED off. So its only occurring when power usage is over 60%. As for the EMI, cardboard + aluminum foil helps for the sound card, just worried about a fire hazard and have to figure out a solution for now.
srfonden
Flagged as Spam (1)
2020/09/25 16:38:08
It's because you are a vertical cameraman barbarian....
terry2776
2020/09/25 16:46:32
vgerik1234 TLDR: EVGA 3090 FTW - 60%+ power and card gives off electric whine, strong enough to affect sound card 4 slots away. So while troubleshooting my issue with audio whine through the EVGA NU soundcard, I discovered that my 3090 is giving off a boatload of EMI. Enough to affect my audio card 4 slots away. So I took off the side panel of my case and noticed that there is a buzzing/whine from the card sometimes. When the buzzing happens, the noise goes through my speakers as well (EMI). It is not coming from the fans I don't think, because the sound happens even when they are set to 0%. This whine only happens when the power % is above 60% according to the latest Precision. when I first installed the latest precision it updated my firmware.
Video: https://www.youtube.com/watch?v=BdTF48-BmyA Video description: Video starts off with with precision saying power @ 50%. 6 seconds in it jumps to 100%. That is when the whine starts.
Try installing Precision X1 ( the one for 3000 series ) when I did and rebooted and started it up there was a bios update for my 3090 FTW3 Ultra, maybe it will help.
