ericbartman
Re: 3080 Ti ftw3 ultra fan noise unbearable.
2021/11/09 16:11:33
rjbarker The OP now can understand why many if us enthusiasts ditched “stock air coolers” many years ago….noise n heat ! Now back in the multi gpu days can you imagine what 2 * 3080Ti’s (SLi) what that would sound like? I think youre confusing an actual water cooled system, including GPU w Waterblock vs a Hybrid Card (not the same at all…I wouldn't even call a Hybrid Card liquid cooled. Anyhow, a Hybrid Card may also bother you with pump noise. Honestly, the only way to silence these beasts is with a “proper waterblock” and custom loop.
I think overall you are correct, but I don't think that is the only way to cool. My buddy has a 3090 suprimX and his air cooler sounds just like previous generations of EVGA air coolers. Just a "whoosh", no high frequency annoying sound even at 100% fan speed. Something has certainly changed with EVGA fans in this generation.
irocziv
2021/12/19 12:06:39
So many people saying the card runs hot, but that isn't really the problem with this card, it's that the fans are louder than they should be. I just upgraded my 1080Ti, and at 80% fan speed it was "quieter' than 65% fan speed of the EVGA FTW3 card. I didn't actually measure the dBs, but it was more pleasant on the ears. This card reminds me of my old gtx470 with a blower fan on it.... I think the difference in sound between my old card and this on is that the fan size on the 3080Ti is smaller, but it could be something else too. To deal with this, I've had it target a temp of 65C. Which most of the time works ok, but it's a bit sad that I'm not able to run the card up to its full potential. I know EVGA could sell these cards no matter how loud they are, but it doesn't help their brand image. With a known hot card, more effort should be made to adjust the sound at higher speeds, since they need that cooling in order to hit their max potential.
kraade
- Ribbons : 7
2021/12/19 14:49:13
With the Card installed normally in most cases , the cooler does not exhaust well , it's got no where to go against the PCB and if the glass is on about an inch away it really blocks it, even when case fans blow across it . so if you have the option of turning the card 90 degrees with pcie Riser cable , I think you could get much more efficiency out of this cooler.
ericbartman
2021/12/19 15:15:55
Dude just stop. I can have my side panel open and it barely makes a difference 2 degrees max. Furthermore, the whiny fans, no excuse for them at all when previous iterations of evga fans were always better than whatever this is.
redteamgo
2021/12/19 15:54:03
ericbartman Dude just stop. I can have my side panel open and it barely makes a difference 2 degrees max. Furthermore, the whiny fans, no excuse for them at all when previous iterations of evga fans were always better than whatever this is.
there is some merit to what he’s say. it does depend on the form factor and airflow. My mini itx htpc has a 3080ti ftw3 on air in a phaneks air shift 2 has a 15-20C hotspot delta when it’s in the case vs sitting out of the case next to it at 100% util . Lots of gear in a tight space is my problem which creates extra heat soak. Maybe your airflow could be improved? Edit the fan noise isn’t that bad even at 100%, I’ll make a vid later if interested.
post edited by redteamgo - 2021/12/19 16:09:09
CPU: Intel 12900K EK 1700 Quantum Mag AcetelGPU: EVGA 3090 KPHCMB: EVGA Z690 DarkPSU: EVGA SuperNOVA 1600 P+Memory: G.SKILL Z5 6600mhz XMP3NVME: Samsung 980 Pro Gen 4 1TB, Gen 3 970 1TBCooling: MO-RA3 420 P/P 8x200mm Noctua HS PWM, Dual D5Case: Fractal Design Define 7 MOD Rigs!!!
kraade
- Ribbons : 7
2021/12/19 16:08:22
Well , I got about 4-5 C by pulling my panel and was going to try the vertical mount kit idea because its still only freeing up half the exhaust , the PCB still blocked, I ended up undervolting that card to 835mv and locking the clock at 1875 w/+1050mem, and the found it would run 99% of stock and the GPU stayed 70-71 with 55% fan speed with the glass installed, This card makes score on massive amounts of power and you got to have to get rid of it somewhere. Next move was buying a hybrid off Ebay and reselling the card and ended up getting the card less than MSRP (net) Do what you want but complaining like you have been wronged by fan speed is a bit silly imho...
ericbartman
2021/12/19 18:25:45
Yes, for temps in SFF he is right. But in every other regards he is missing the point. Especially on noise per unit rpm.
redteamgo
2021/12/20 07:03:23
irocziv So many people saying the card runs hot, but that isn't really the problem with this card, it's that the fans are louder than they should be. I just upgraded my 1080Ti, and at 80% fan speed it was "quieter' than 65% fan speed of the EVGA FTW3 card. I think the difference in sound between my old card and this on is that the fan size on the 3080Ti is smaller, but it could be something else too.
good morning video card friends. My HTPC is waiting for an upgraded riser cable so I was able to make a quick video comparison. here is a video of my 1080 TI FTW3 at ~3000 rpms vs my 3080 TI FTW3 at ~3000rpms . my opinion is that the 3080TI FTW 3 is quieter. i disagree that the 1080TI is quieter at any given RPM.. in fact, when you crank up the 1080TI FTW3 to 3000 RPMs, it reminds me of standing outside on an airport jet tarmac. LOL I agree with kraade that there is exhaust coming through the backplate with the 3080TI and depending on your build, there is no where for it to go unless you have good airflow. it is also a thicker card than the 1080TI creating even more of an airflow debacle depending on your case and card orientation. you be the judge. best regards. 1080 TI FTW 3 https://www.youtube.com/watch?v=njHa2Gg4_3A3080 TI FTW 3 https://www.youtube.com/watch?v=6GkUBy0fN_c
post edited by redteamgo - 2021/12/20 07:12:58
ericbartman
2021/12/20 07:37:06
First of, really good comparison. Thank you for recording these videos.
Now if we listen closely, see how 1080ti just makes a loud whoosh sound, and 3080ti makes a higher pitched whine. This is exactly what is driving me nuts. That whine is a lot more annoying. Noise profile of 3080ti fans is horrendous.
redteamgo
2021/12/20 08:31:08
you're welcome. I know exactly what you mean, the 3080ti has more of a hydraulic type sound vs the 1080ti. some people's ears are more or less sensitive to certain frequencies. condolences it might come down to the shroud design. the 1080TI has gaps in the shroud and is much more "open", whereas the 3080TI is solid across the intake. an interesting experiment might be to pop off the fan shroud and put three 90mm fans (NF-A9?) on there but I'll have to leave that to someone else since my ears are ok with it
ericbartman
2021/12/20 08:34:45
That is precisely what I wished to do. I was thinking about designing a 120mm fan shroud for this card and share it with the community. So I approached EVGA customer service to provide me with accurate heatsink or shroud measurements, and they told me to piss off. :(
irocziv
2021/12/21 18:03:04
Just found a thread that someone did modify a card for different fans, might try it, though modifying a card that costs so much is a little worrying I can't seem to put any links in forums.evga.com/EVGA-RTX-3080-Ti-FTW-custom-fans-guide-m3502802 .aspx
post edited by irocziv - 2021/12/21 18:07:45
Gamer-Monk
2021/12/22 07:12:49
I would double check the fan on the power supply it might run at higher speed try to cool itself due to high power output.
ericbartman
2021/12/22 07:43:44
My power supply is EVGA 1000watt platinum. It runs dead silent. Edit: I can manually turn up the fan RPM, same noise. Look at the videos posted by a good man on this thread. It is quite clear where the whining noise is coming from.
post edited by ericbartman - 2021/12/22 07:44:52
