Brendruis
Hey guys, I don't recall if I've ever posted here. I've dabbled in nVidia video cards since the Riva TNT2 days. Anyway, I upgraded from a 1080 Ti FE to an EVGA 3080 Ti XC3 Gaming thinking the XC3 being a 'reference board' would at least be the equal of a 3080 Ti FE. I should have done more research into the unique design of the FE this go around. Oh well. On to the issue at hand: I believe I am still noticing a peak power usage issue. While the TDP of the 3080 Ti I understand to be 350W, it should certainly Peak higher than that in many instances unless im mistaken, and does up to 384W in the Guru3D.com review. In all of my tests I cannot get my 3080 Ti XC3 Gaming to Peak higher than exactly 349W . This would all be well and fine, but it's limiting my performance. Raising the power limit to 105% in X1 results in 600 more points in Timespy Graphics (19014 vs 18468) with zero clock changes and I get higher power consumption (as high as 367.5 so far in TimeSpy at 105% power in X1). After reading many threads (including the XC3 Hybrid and Hydro Copper power consumption thread) I'm convinced there is still some BIOS issue with these cards that is artificially limiting the peak power consumption to 349W (and some decimals). Tested with 3DMark and Unigine and others. The Founders Edition may have a funky new connector, but it gets it's power from the same 8 pin connectors we're using on this card. Technically they should both be able to pull 375W (150W for each 8 pin, and 75W for the PCI-E x16 slot). Correct me if I'm wrong or if anyone has advice please. Thanks for reading my WOT, -Brennan
post edited by Brendruis - 2021/11/14 11:37:05
kim666
Re: 3080 Ti XC3 Capped Power Consumption
2021/11/13 23:20:01
sadly xc3 is not even a reference board. more of a modded ref pcb this is a ref 3080/90 pcb. there is a short and long version, but both have the same component layouts https://videocardz.com/ne...board-designs-picturedreference pcb are good for water cooling, simplify block makers the best reference 3080ti pcb is zotac amp holo black, it uses similar vrm as high end pcb, and is more efficient than all 3080ti out now. FE is actually an nvidia customed board other wise your 3080ti is performing as expected....355-366w average load, with peaks at 375w, at least reported on gpuz the only way to get higher TS score is to use hybrid or waterblock cooling
post edited by kim666 - 2021/11/13 23:24:51
Brendruis
2021/11/14 00:11:25
kim666 sadly xc3 is not even a reference board. more of a modded ref pcb this is a ref 3080/90 pcb. there is a short and long version, but both have the same component layouts
Those numbers would be right, but thats not what I'm getting. 367.5W was the max load I was able to achieve during my benchmarking at 105% power. At 100% power, I am never able to achieve anything more than exactly 349W, even though the board could obviously use more if it weren’t running into that hard barrier of 349W. This hard barrier doesn't seem to exist on other cards such as the 3080 Ti FE which claims the same TDP power yet frequently peaks beyond it, as we would expect. Now the XC3 can peak beyond this strange arbitrary 349W if you move the power slider 5% to the right and then begins to behave as a normal stock 3080 Ti (ie: roughly 19k 3dmark timespy graphics). For reference my rig is 11900k not OC MSI Z590-A Pro 16GB Corsair DDR4 3200 EVGA Supernova 1000W G2 (used to SLI) EVGA 3080 Ti XC3 12GB at 105% power no OC.. max power draw exactly 367.5W, which coincidentally is 105% of 350W. at 100% power it is stuck at maximum 349W period it will not exceed that no matter the benchmark. This is strange behavior in comparison to other 3080 Ti of similar make from different manufacturers. I feel like performance is being left on the table. My temps don’t exceed 67c on a timespy run for the GPU. Granted I have great cooling in the case but I feel something is still wrong.. if it’s that cold shouldn’t I boost higher and draw more at 100% than 349W especially in Unigine which I tried also. At least if reviews are to be believed. What’s going on here?
post edited by Brendruis - 2021/11/14 02:41:49
- Ribbons : 271
2021/11/14 06:40:56
kim666
2021/11/14 09:07:41
Brendruis Those numbers would be right, but thats not what I'm getting. 367.5W was the max load I was able to achieve during my benchmarking at 105% power. At 100% power, I am never able to achieve anything more than exactly 349W, even though the board could obviously use more if it weren’t running into that hard barrier of 349W. This hard barrier doesn't seem to exist on other cards such as the 3080 Ti FE which claims the same TDP power yet frequently peaks beyond it, as we would expect. Now the XC3 can peak beyond this strange arbitrary 349W if you move the power slider 5% to the right and then begins to behave as a normal stock 3080 Ti (ie: roughly 19k 3dmark timespy graphics).
Looks fine to me. XC3 is rated up to 366W, to reach that you need to increase to 105% power. You can run timespy and it should float around 350~365W, spike peak will be 375W. XC3 is kindly the worst budget line around. hehe components used in Nvidia FE is much higher than XC3. Evga dont seems to seed many XC3 for reviews either.
post edited by kim666 - 2021/11/14 09:10:29
Brendruis
2021/11/14 11:26:42
It hovers around 345-350 during the tests with peak at 376.5, exactly 105% of 350.. (ie: 350x1.05=367.5). That seems like a hard limit of 367.5 for peak, not 375. Can anyone with more experience enlighten me on what the peak power numbers for this ‘basic’ version of a 3080 Ti AIB (I guess you’d call it) really is? I don’t know if I’m going to take the loss for a trade but if I’m limited that much that I might as well have a lesser card then I feel obliged to try to get what I paid for.. This is the first time I’ve heard of the nVidia FE parts being used on the actual PCB being superior to other manufacturers unless it’s new for this generation. I certainly would have spent $50 more on eBay if I knew for certain that was the case, and might even trade this for one if someone can prove it to me. I know they have a good look and have premium anodized metal finishes and accents on the outside that encase it in almost a shell which I’m sure adds a little to the value for some, and they have a worse warranty. What steered me away from the FE this time was the strange push pull cooling that doesn’t perform as well that I’ve seen In reviews as the ICX3 cooling by eVGA or other solutions for that matter. it’s too bad you can’t take advantage of the cool temps because the card seems to be artificially power limited. If it could it would easily clock up and challenge a FE out of the box since it’s running at 68c (which it should, not be 6-700 points behind as it is at 100% power). If changes were made when the other threads [which I’ve entirely read] came to prominence, who’s to say there isn’t still a BIOS issue lurking somewhere still? All I ask is that someone look into it if possible.
post edited by Brendruis - 2021/11/14 11:36:29
kim666
2021/11/14 11:42:34
Brendruis It hovers around 345-350 during the tests with peak at 376.5, exactly 105% of 350.. (ie: 350x1.05=367.5). That seems like a hard limit of 367.5 for peak, not 375. Can anyone with more experience enlighten me on what the peak power numbers for this ‘basic’ version of a 3080 Ti AIB (I guess you’d call it) really is?
yes the 3080Ti FE is way superior to XC3. The cooler isnt as good on VRAM cooling though. it uses 15+3 70A MPS components. https://www.techpowerup.com/review/nvidia-geforce-rtx-3080-ti-founders-edition/3.html 3080Ti XC3 uses 14+3 50A Onsemi components iirc. 3080 XC3 was even worse Evga icx3 cant even read VRAM temps on their PX1 sadly :(
CraptacularOne
- Ribbons : 222
2021/11/14 12:07:21
Yes the card is capped at 366w in the BIOS. This is by design, what you are experiencing is normal and expected behavior of what is EVGA's "entry level" RTX 3080 Ti. The card has a power target of 350w which your card is hitting.
Brendruis
2021/11/14 13:04:36
No ****, I wish I would have read that article before purchase. It would be pretty cool if this were more well known. Hey, maybe eVGA could have released review samples of the XC3 instead of just the FTW3 to oooh and ahh about and sweeping the poor scores of the XC3 under the rug. I guess at least I can approach FE numbers at 105% power… it seems the problem was worse before. I don’t think I can stomach a 12% loss selling it on eBay and then another 7% sales tax plus $650 scalper tax. We’re talking big money to swap this for an FE since step up queue is down for new entries. Probably not worth it for 200 3DMarks and a few frames in whatever game. Still always hurts to be jipped… thank you for all the info provided.. unless there is an additional magical additional BIOS change which I doubt it seems it is a limitation of the hardware itself.
post edited by Brendruis - 2021/11/14 13:11:08
CraptacularOne
- Ribbons : 222
2021/11/14 13:09:51
Brendruis No ****, I wish I would have read that article before purchase. It would be pretty cool if this were more well known. Hey, maybe eVGA could have released review samples of the XC3 instead of just the FTW3 to oooh and ahh about and sweeping the poor scores of the XC3 under the rug.
I guess at least I can approach FE numbers at 105% power… it seems the problem was worse before. I don’t think I can stomach a 12% loss selling it on eBay and then another 7% plus scalper tax. We’re talking at least $4-500 to swap this for an FE since step up queue is down for new entries. Probably not worth it for 200 3DMarks and a few frames in whatever game. Still always hurts to be jipped… thank you for all the info provided.. unless there is an additional magical additional BIOS change which I doubt it seems it is a limitation of the hardware itself.
Cool, being a dick will get you far on this forum. The only person you have to be mad at is yourself for not doing any research before you spent your money. Why do people like you do this? Spend your money then decide to investigate what it is you bought then get mad? It's idiotic and ignorant. At the end of they day, you're still getting RTX 3080 Ti performance, you're just not going to be overclocking it as high.
post edited by CraptacularOne - 2021/11/14 13:11:18
Brendruis
2021/11/14 13:23:05
CraptacularOne
Don’t see where I was a dick at all what is your issue? Because I didn’t read that one article? I did actually search for difference in board components. I guess sorry my search wasn’t as fruitful or I used different keywords? I’m not sure why you are so angry. This is the first time the Founders Edition has been so drastically different from reference boards and “budget AIBs” with a cut PCB, a modified power connector and completely different parts AFAIK. I owned a 1080 Ti FE not even a month ago before I sold it to buy this thing. It wasn’t any different in performance than the other brands so I instructed my wife to buy any modem that became available because it was a scarcity on launch of that GPU (though not nearly this bad). She kindly had the browser refreshing every second to get one on Newegg when it came out. I didn’t care if it was the Founders Edition or EVGA or MSI because they all scored the same. It scored no different than eVGA 1080 Tis it any other unless they were OC models, and those sometimes had 2x8 pin connectors instead of 8+6. At the time, none of that extra power was needed unless overclocking. This is the first series to exhibit any discrepancy with performance on stock clocks and I asked politely if anyone knew anymore information about it on the new cards.. I don’t get your response so I’m gonna disregard it unless you have information to add. Thanks to everyone else who contributed to the thread
post edited by Brendruis - 2021/11/14 13:32:47
CraptacularOne
- Ribbons : 222
2021/11/14 13:32:43
Brendruis
CraptacularOne
This is the first time the Founders Edition has been so drastically different from reference boards and “budget AIBs” with a cut PCB, a modified power connector and completely different parts AFAIK. I owned a 3080 Ti FE not even a month ago before I sold it to buy this thing. It scored no different than eVGA 1080 Tis it any other unless they were OC models. This is the first series to exhibit any discrepancy and I asked politely if anyone knew anymore information about it.
Perhaps I took that the wrong way then, it seemed to me you were saying "No XXXt to me" as being condescending. All the initial reviews of the Nvidia FE cards went over how the FE cards this generation weren't in fact using "reference design" PCBs and this was the first time Nvidia themselves would be using a custom design and compete with higher end cards directly themselves. Your PCB isn't "cut" or limited, it's in fact adhering to Nvidia's recommended reference design power budget for your GPU. Had you bought a different card be it from PNY, Palit or Zotac etc that use the reference design they too are set to 366w max with a target of 350w. While this card doesn't use the reference design PCB, it does adhere to the recommended default power budget set by Nvidia, not EVGA.
Brendruis
2021/11/14 13:41:26
CraptacularOne
Brendruis
CraptacularOne
Thanks for any info and sorry if you took that wrong, I wasn’t saying “no ****” to you but more of just to myself.. like a surprised reaction. Sorry if offense was taken or if I got off topic I meant the FE is a “cut” PCB and by that I just meant it has those diagonal cutouts to fit the custom cooler they have. I didn’t watch the release event or anything, and I only have myself to blame for that and missing that they were “competing with the higher end cards themselves now.” Do you happen to know if that’s an actual quote from someone at NVDA? Thx again
post edited by Brendruis - 2021/11/14 13:42:28
Brendruis
2021/11/14 13:54:23
Thanks to all for any information provided or additional information that may be available. Not that I doubt you at all, but I'm still not clear how having Onsemi instead of MSO voltage regulation components would result in this limitation. Is Onsemi known to have poorer quality components? Their annual revenue is much higher than MSO, though of course that is not an indicator of their product quality directly.
post edited by Brendruis - 2021/11/14 14:22:52
CraptacularOne
- Ribbons : 222
2021/11/14 14:13:52
Brendruis
CraptacularOne
Brendruis
CraptacularOne
Thx again
I don't have an official quote from Nvidia other than what I've seen in reviews from the launch last year when they were all going over how this generations "FE" cards are not reference design PCBs.
Brendruis
2021/11/14 14:21:53
Np man, thx for any input you've given. Time is money.
talon951
2021/11/14 14:33:38
Well you could try to score a 3x8pin card. It's not like it would be hard to sell the XC3 for good money right now.
Brendruis
2021/11/14 15:17:35
talon951 Well you could try to score a 3x8pin card. It's not like it would be hard to sell the XC3 for good money right now.
It’d be $351 with 12% on eBay seller fees and 7% in Florida sales tax, that’s assuming I could sell the card for what I bought it for, which is unlikely given its now used or at the very least “open box” so I’d probably lose more than that. I think a 3x8pin would solve the issue.. it’s just is it worth that amount. I would not be losing that small bit of performance and I wouldn’t have to go in and set power to 105%.. on the other hand I’m not much of an overclocker (too much variance in games with stability testing and scanning for artifacts constantly). I agree there’s a choice to make.. hmm
post edited by Brendruis - 2021/11/14 15:26:17
talon951
2021/11/14 15:30:22
Brendruis
Reality is the performance difference is small and you'll never notice without a frame counter probably. BUT, have you looked to see what cards are selling for right now?!
Brendruis
2021/11/14 17:17:07
talon951 Reality is the performance difference is small and you'll never notice without a frame counter probably. BUT, have you looked to see what cards are selling for right now?!
I know but if I didn’t reveal I got this card on eBay sealed and paid the scalper premium of $600 a month and a half ago. Prices have risen about $50 since. It would be totally worth it if I got this at MSRP on here or somewhere but I didn’t.
post edited by Brendruis - 2021/11/14 17:18:09
talon951
2021/11/14 18:40:38
Brendruis
I'd probably just try to enjoy the card and do some gaming then. You could pick up the hybrid kit or do a loop to gain some performance. Cooling it a lot better will gain as much or more performance than more power (assuming you haven't already done that). Obviously all of that costs more $$$ though.
sethleigh
2021/11/14 20:55:39
Are you really going to notice the difference between the 151fps you could have gotten in some game instead of the 149fps or 150fps you're actually going to get? I think it's well past time for you to reconcile with the fact that you've bought yourself a pretty damn fast card that's still better than 99% of the cards out there, even if part of the 1% includes a different version of the card you got that's very marginally faster. Try loving that card for what it isn't rather than hating it for what it isn't, and then research harder in a few years when it's time to upgrade it to the 5080ti.
Happy EVGA customer. Affiliate Code: 0Y7-1VU-ATW2 GigaByte X570 Aorus Master, AMD Ryzen 5900x under Optimus Foundation block, 32gb G.Skill DDR4 @ 3800 MHz 14-14-14-28, EVGA 3080ti FTW3 Ultra under Optimus block, 2TB 980 Pro SSD, EVGA Supernova G6 850W PS, ASUS 34" 3440x1440p 120Hz ultrawide, Lenovo 24" 1080p secondary monitor, Win 10
Brendruis
2021/11/15 01:03:43
I would if it was really 1% we’re talking about, and probably will just keep it, but if you kindly would read the thread I was down about 5% in scores before raising the power limit to 105%. At 100% I was losing nearly 800 marks versus an FE clocked exactly the same. To me anyway that was enough to warrant at least asking the question if anything could be done to obtain the same without adjustment of the settings from stock. That was the purpose of the thread, now fulfilled with the answer being no. You could argue it went off on a tangent towards replacing it which I was only barely considering due to the sheer price for a 1% gain. 5% I felt was worthy of a question that I’d all. I said I might consider paying if it were proven the components were actually appreciably better; I am still unconvinced that MOS made power components are inherently better than Onsemi. The Techpowerup article which identifies the make and model of the power components very accurately in close up photographs but doesn’t elaborate on quality versus Onsemi. I understand if you think 1% is unremarkable, so do I.. but I was originally talking about closer to 5%. Again thx to all for answers and if there aren’t any more feel free to let the thread die
post edited by Brendruis - 2021/11/15 01:11:00
