3080 FTW3 Ultra 4 red lights on power connectors when PC is off
Nghtmare
2020/12/22 08:52:32 (permalink)
Hi guys, I received my 3080 today and I think I am having an issue. The card works perfectly fine when on, and both BIOS work fine. Once I installed Precision it had asked me to update the firmware which it did. I decided to turn off the PC since I had to work (from home) and it stayed with 4 red lights on the power connectors. I spoke to Support and they sent me both of the latest BIOS so I can install them again (normal-OC). I did that and the problem persists. Now the PC boots fine when I try to boot, it just stays like that after I turn it off.
The PSU that I am using is an EVGA GQ 750w Gold. It came with 2 separate 8 Pin cables and 2 of the "splitter" versions. I have it set up with 3 separate cables, 1 being the "splitter" version but I zip tied the extra end since its not needed. I tried with 2 cables as well (1 8 Pin, and using both ends of the splitter version) and it does the same thing. I previously had a 2080ti, and this never happened.
Anyone have any ideas?
30 Replies Related Threads
    arestavo
    • Ribbons : 77
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 08:55:29 (permalink)
    Possible power feedback?
    Turn off the PSU, or try unplugging the monitor cable (assuming it's DP?). If the DP cable removal stops it, as per Sajin, buy a certified DP cable.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 09:07:44 (permalink)
    arestavo
    I just tried removing the cable while the PC was off and the lights remained on. The DP cable that I use came with my LG monitor.
    The odd thing is that when I turn it off, my X570 Taichi keeps the 2 buttons (Reset and Power) on as well. This never happened before, and it was not happening in the morning before I changed GPUs.
    Once I turn on the PC its like if nothing ever happened, runs fine, overclocking works fine, no crashes while playing Cyberpunk for example.
    post edited by Nghtmare - 2020/12/22 09:10:31
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 10:31:52 (permalink)
    Well even if I set the mobo to Deep Sleep which powers down the whole board, no matter what, the GPU keeps the 4 red LEDs.
    arestavo
    • Ribbons : 77
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 10:34:39 (permalink)
    It's likely from the PSU then. Got a power switch on it? Does it have different modes? Green (or eco) and normal?
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 10:55:36 (permalink)
    arestavo
    It is an EVGA GQ 750w Gold. I checked and it does have an Eco mode switch, 3 years and I was not aware it did. Anyways it has an Eco mode switch, and the switch to kill the power. Eco mode was ON all along, I switched it to OFF to see if it would do anything and the red lights still appear. The power switch of course turns them off but that is because Im just killing the power to the PSU.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 13:03:35 (permalink)
    Well I honestly have no idea what it is. If it happens to be the PSU, I bought it 3 years ago so technically I should have 2 years left on the warranty. It would just seem weird how it never caused issues on my 5700XT and then 2080ti, thought neither of those cards needed 3 8pin cables (if that matters anyways). Im clueless as of what to do.
    arestavo
    • Ribbons : 77
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 13:06:47 (permalink)
    Those other cards likely didn't have LEDs at the power connectors like the 30 series cards do.
    If the card works fine other than those LEDs lighting up when the PC is off, and if really bothers you - just turn off the PSU.
    You might also try disconnecting power to the motherboard to see if it's coming from there as well. If that stops it, maybe there's some setting in the motherboard BIOS that causes it.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 13:13:08 (permalink)
    arestavo
    I had a 2080ti Strix, it does have the white LEDs where the power connectors go.
    I did try disconnecting power to the mothet and the GPU stays that way anyways.
    Its not that it bothers me, based on what I read, and on my friend who also has one, this is not normal. The last thing I want is to end up killing the GPU because I decide to ignore it.
    arestavo
    • Ribbons : 77
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 13:29:48 (permalink)
    Nghtmare
    arestavo
    I don't think leaving it be will kill the card, but EVGA is the expert on it: https://www.evga.com/about/contactus/
    The good news is that EVGA has unmatched warranty/service (at least in the US) should your card suffer a failure.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 13:35:45 (permalink)
    I spoke to them today, made me re install both BIOS versions Normal/OC, I replied letting them know nothing worked. Now I am just waiting for a reply. I made this post to see if anyone had an idea what it could be while I wait. Thanks for the suggestions btw.
    slapn
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/22 14:09:28 (permalink)
    Hmm maybe a grounding issue <plug in somewhere else if possible.///ext cord/// Like a kitchen or bathroom that has gfi .Just a long shot but i'm curious.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/23 03:01:29 (permalink)
    slapn
    Ive tried a different socket and nothing :/
    The only thing that worries me is the 8+8 cable that I am using since it has 1 end going nowhere, but then again almost no power supply gives you 3 single 8 pin PCIE cables. Most bring 2 single 8 pin cables and 2 of the 8+8 versions.
    AngryAce
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/23 03:44:34 (permalink)
    Maybe try to update your motherboard's bios. Worth a try if you know how to do it, if not, do not attempt it.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/23 03:53:16 (permalink)
    AngryAce
    Yeah I update the BIOS most of the time, I am actually on version 3.80 from the X570 Taichi which is a few days old. I tried going back to 3.61 (previous version that supports my 5800X) and it did it as well.
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/23 04:16:09 (permalink)
    Something to add, it did go into these 4 red lights and 100% fan speed while updating the firmware the first time I opened Precision, and back to normal once it was done. Ive seen people call that "Flash Mode", but of course the card is on, and 100% fan speed, this is with the fans off, and GPU off. I am going to try and get a few second video showing what it does.
    Edit: I uploaded a short clip showing it (dont mind the PCIE cables, getting a vertical mount later today)
    Please let me know if its not allowed.
    watch?v=N-MKQou8w6E
    post edited by Nghtmare - 2020/12/23 04:26:41
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 03:57:24 (permalink)
    Well since Support has not gotten back to me (probably busy with holidays and stuff), I ended buying a new PSU today. Mine was only 3 years old but wanted to see if the problem was the PSU or the card. Well with my new RM850x the problem still persists. So the problem seems to be the card at this point.
    post edited by Nghtmare - 2020/12/30 04:27:57
    • Ribbons : 86
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 04:02:42 (permalink)
    Please apply for an RMA
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 04:25:06 (permalink)
    Thanks, I will do that now. I was waiting for Support to reply with further instructions from the last time we spoke, but I'll start the RMA now. Thank you.
    finaltouch68
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 09:36:37 (permalink)
    During an RMI like this beings the card is still in operation.. Do they send you a new card then you send the needing fixed one back? Say someone doesn't have an extra card while shipping that one back. Are they simple out of a pc till the new card arrives months later lol. Or does RMA grab first priority? I am a 3080Ultra owner and those are legit questions. Dont get me wrong my card runs great but need to know for the vault.
    arestavo
    • Ribbons : 77
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 09:41:38 (permalink)
    finaltouch68
    Only way to get a new card before sending the old one back is to purchase an advanced RMA and put up collateral: https://www.evga.com/support/ear/
    finaltouch68
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2020/12/30 10:01:41 (permalink)
    arestavo
    Sweet thanks for the heads up I will look into that for my new purchases. Especially the K|NGP|N when I get my hand on it.
    post edited by finaltouch68 - 2020/12/30 10:04:11
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/01 04:44:09 (permalink)
    Sorry to bother you, it is asking me for a Support Ticket Number however Support has not given me one yet. I have spoken to someone on the phone, and received email replies, but I have not been provided with one and it does not auto-populate on the RMA form. Should I wait for their reply and ask for one? I live in the UK if that matters.
    #23
    • Ribbons : 86
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/01 04:57:30 (permalink)
    Nghtmare
    Send me a PM on Monday afternoon if you do not get a support number by that time. If you are unable to send me a PM then make a post in this thread.
    #24
    Nghtmare
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/01 04:59:22 (permalink)
    Nghtmare
    Will you, thanks and happy new years.
    #25
    exilelrrp
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/03 18:13:42 (permalink)
    I'm also having the (4 Error Red Led) on my GPU, I had to open a thread, please check it out.
    post edited by exilelrrp - 2021/01/03 20:09:00
    *Lian Li PC-011D Mini (Black) *i9-10900K *ROG Strix Z490-G *Nzxt Kraken Z73/Lian Li UNI SL120 Series *Corsair Vengeance Pro RGB 64GB (4x16GB) DDR4 *Corsair HX1200i *EVGA GeForce RTX 3080 Ultra FTW3 *Samsung 970 Evo M.2 1TB *Samsung 960 Evo M.2 500GB *Samsung 840 Evo Series 1TB SSD *Asus ROG Swift PG43UQ *Corsair K70 MK.2 RGB *Corsair Dark Core *Corsair Gaming MM800 *Corsair ST100 *Razer Nari Ultimate.
    #26
    • Ribbons : 271
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/03 18:21:44 (permalink)
    Nghtmare
    Does your motherboard have an ErP mode option in its BIOS?  If so, is it enabled?  If ErP was disabled, and you enable ErP, this problem should go away ... I think.
    #27
    • Ribbons : 271
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/03 18:22:35 (permalink)
    exilelrrp
    I'm also having the (4 Error Red Led) on my GPU: All I did was switched over from one case to the new case.
    You should start your own thread.  Your issue is different than this user's issue.
    #28
    exilelrrp
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/03 20:09:51 (permalink)
    exilelrrp
    Yeah, I just noticed that and will do.
    #29
    exilelrrp
    Re: 3080 FTW3 Ultra 4 red lights on power connectors when PC is off 2021/01/03 20:14:44 (permalink)
    Nghtmare
    Yeah, I was about to tell him that, I always set Erp ready to ( S4+S5 ) Enabled, which shut's down completely even with charging devices that stay attached.
    #30
