Anikillz
For the past week or so I've been noticing a slightly different sound coming from my PC when I am gaming. I started investigating where it's coming from and finally found that the 3rd fan on the GPU sounds different from the other 2. I have attached some screenshot of the fans graphs and you can see that 1 and 2 are the same while 3 looks quite different. It's especially noticeable on the 4th screenshot where I locked the fans at 40% speed. Fan 1 and 2 stayed at 40% the entire time but fan 3 just can't stay steady! I've been using the card for about a month and a half now and this issue only came up recently, the noise coming from the pc was quite different. I am unsure how to describe it but it's different enough to be noticeable. I am using the normal BIOS and both the latest firmware/X1 updates. Anybody experienced similar issues? I can honestly deal with it as I game with headphones but if it's a precursor to the fan possibly dying then I'll have to do something about it.
homestyle
Re: 3080 FTW Ultra Fan 3 weird issue
2021/01/26 00:29:51
Acrab67
2021/01/26 02:06:30
I have the same issue with my 3070 XC3 Ultra Gaming
Fractal Designe Define R6 (blackout) - Intel Core I7 10700K (Noctua NH-D15 con embellecedores y ventiladores Chromax) - MSI MPG Z490 Gaming Plus - 2 X 8 Gb Crucial Ballistix DDR4 3600 CL16 - EVGA RTX 3070 XC3 Ultra Gaming - WD SN750 500 Gb - Samsung 840 EVO 250 Gb - Samsung 860 EVO 500 Gb - Samsung Spinpoint F3 1TB - Corsair TX650 650W - DELL U2515H - Corsair K70 Lux MX Cherry red - Logitech G402 - Edifier S350DB/Superlux HD668B
Dabadger84
- Ribbons : 10
2021/01/26 02:16:33
I think this is a fan control issue related to drivers that hasn't been fixed yet, same as the temperature spike readout error on iCX sensors that is NVidia driver related and has been present since the 2nd release of drivers for the 30-series cards. If your HWInfo64 is not reading out all 3 fans on a 3-fan card, there should be an HWInfo update that fixes that, as my 3080 FTW3 Ultra I used to have did not have a reporting issue after an update that HWInfo put out like 2 months ago, so make sure your HWInfo is the newest version. The fan control is something where you can always try setting the 3rd fan higher if it's running slower or whatnot, highly recommend doing a custom curve regardless, don't let the fans auto-control themselves, it's not ideal for cooling. Set it up so that the fans are off at idle/desktop temps, but once you hit "gaming" temperatures, it ramps up - figure out what speed is a maximum acceptable "noise level" for your personal preference, and set it to max out at that speed starting at ~55C, and you should have an effectively cooled card from there on out.
Acrab67
2021/01/26 02:22:21
GPU-Z, MSI Afterburner, and HWinfo, show two fans only. Last version installed.
Anikillz
2021/01/26 06:21:24
My HwInfo does show the fan but it's in its own category and called right fan, not fan 3 for some reason. I do have a custom fan curve enabled as you can see from my previous screenshots. The flat one was just for testing. Cooling wise everything is good with the card. The third fan is not acting idly different either but I find it concerning that 2 fans have the exact same speed% graph while the 3rd, while following the same curve, is quite different. My main worry is that new sound I have been hearing for the past week or so, it's not the normal sound of the fans ramping up and down. I am honestly not bothered even if the fans are loud since I've got headphones on most of the time, I am bothered by the fact that this new weird sound came up recently combined with the fan not being as stable as the other two. Those two things lead me to believe the fan is faulty in some way, such as a bad bearing or not properly lubricated leading to that weird sound. I just don't really know much about this stuff so I'm trying to find out if some people had similar issues to inform myself. Lastly, this sound is only noticeable when the fan speed is over 60ish%. It only come from the 3rd fan as turning it down on it's own the sound goes away. Worst come to worst I will have to RMA the card but I'd rather not have to go through this entire process unless absolutely necessary.
Axon14
2021/01/26 06:52:26
I'm a huge EVGA fan so I hate to say this, but the fan noise sucks on my 3070 FTW3 line and I regret getting it. My MSI Gaming X trio is much better in both noise and temps, that thing is dead silent. While I can control the 3070 FTW3 temps with a curve, there's no such need with the Gaming X trio. Even at 20 percent speed, the FTW3 fans are audible. At least it's quiet during office work. Maybe I got a bad one, I don't know. I'll admit that I'm crazy about fan noise, but you hear this thing buzzing when the fans are on. it sounds like a $20 CPU cooler. Immensely disappointing. I'll give this third fan setting a try.
post edited by Axon14 - 2021/01/26 07:07:56
piloth
2021/04/04 14:16:51
I also have problems with fan3 on my 3080 ftw3. Extremely annoying modulating sound. Sounds like it's pulsing up and down in RPM.
Ekamin
2021/04/04 14:25:50
piloth I also have problems with fan3 on my 3080 ftw3. Extremely annoying modulating sound. Sounds like it's pulsing up and down in RPM.
Deinstall msi afterburner if u have it installed. It fixed it for me because it overrides evgas fan curve which is 0 rpm or >40 so the sound cant appear anymore.
MDN79
2021/04/05 04:32:53
Ekamin Deinstall msi afterburner if u have it installed. It fixed it for me because it overrides evgas fan curve which is 0 rpm or >40 so the sound cant appear anymore.
It's enough just to set more %% in MS AB. For example, I set 50% and have 860 RPM on all 3 fans (bios w/o RBar, I switched to that as RBar vbios isn't good at fans control) without start-stops.
