hotpersuit1
I recently got my hands on an evga ftw 3 ultra gaming 3080 and with it I purchased an evga 850 GQ power supply. I understand the 3080 needs three separate 8 pin power connectors, but my power supply only came with split 2x8pin cables. Do I need 3 single 8pin cables or will 3 split cables be fine?
the_Scarlet_one
formerly Scarlet-tech
- Ribbons : 79
Re: 3080 3x8pin power connectors
2021/01/11 14:26:33
You can use those cables just fine, just plug in the one connecter and tuck the “pig tail” underneath to hide it.
gedmunds
2021/01/11 14:27:44
Ideally, you want three single cables (from what I've read) but I'm running mine with two cables (one with two split connectors, one with only one connector attached) and haven't seen an issue. (Yet)
hotpersuit1
2021/01/11 14:46:04
Fair enough. I would like an official response to confirm.
jankerson
2021/01/11 14:50:37
hotpersuit1 I recently got my hands on an evga ftw 3 ultra gaming 3080 and with it I purchased an evga 850 GQ power supply. I understand the 3080 needs three separate 8 pin power connectors, but my power supply only came with split 2x8pin cables. Do I need 3 single 8pin cables or will 3 split cables be fine?
You can plug in one connection from one of them and use both of the other connections from the 2nd cable. It will work, but it's not the ideal situation.
i9 9900K @ 5.0 GHz, NH D15, 32 GB GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q, Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W. i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W. i7 8700K, AORUS Z370 Ultra Gaming, 16GB 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
- Ribbons : 271
2021/01/11 14:57:55
hotpersuit1 Fair enough. I would like an official response to confirm.
This is not the place to ask for official statements. This is a user-to-user forum.
hotpersuit1
2021/01/11 14:59:15
actek23
2021/01/11 15:13:02
There is literally a post about this like 10 posts down... look for the " PSA: Do NOT use Daisy Chains for 3000 series!!! " post
10G-P5-3898-KR 12/16/2020 9:06:11 AM PT Yes 10G-P5-3888-KR 12/10/2020 9:09:35 AM PT Yes 08G-P5-3767-KR 11/9/2020 11:14:20 AM PT Yes 12G-P5-3968-KR 6/3/2021 7:43:23 AM PT Yes 10G-P5-3897-KR 10/29/2020 7:52:54 AM PT No 12G-P5-3967-KR 6/3/2021 8:25:18 AM PT No
hotpersuit1
2021/01/11 15:43:33
Awesome, this is the info I was looking for. I love buying a 160$ PSU from the same company as the card and not getting the recommended cables for my GPU.
- Ribbons : 271
2021/01/11 15:58:24
hotpersuit1 Awesome, this is the info I was looking for. I love buying a 160$ PSU from the same company as the card and not getting the recommended cables for my GPU.
What's wrong with the cables which came with your PSU? They are fine. Use them. Your PSU has four GPU connection points. Your PSU came with four cables. Use three cables and leave each's daisy-chained + 8 disconnected and dangling. Good to go.
hotpersuit1
2021/01/11 16:07:42
I'm reading everywhere that single cables are recommended and that daisy chained cables are bad for the 30 series as they deliver too much or too little power. I'd rather return this PSU for one with single cables from a reputable brand and not have to worry about anything.
- Ribbons : 271
2021/01/11 16:20:59
hotpersuit1 I'm reading everywhere that single cables are recommended and that daisy chained cables are bad for the 30 series as they deliver too much or too little power. I'd rather return this PSU for one with single cables from a reputable brand and not have to worry about anything.
You are misunderstanding what you are reading. There is nothing wrong with cables with daisy-chained connectors. Just don't use those daisy-chained connectors if you can avoid it. Having extra unused connectors dangling won't hurt anything. A connector which isn't plugged into anything can't "deliver too much or too little power".
hotpersuit1
2021/01/11 17:13:44
So what I'm understanding is that the problem isn't power it's that a split cable gets too hot delivering power to the gpu and can be a fire hazard. So if I run 3 separate split cables this problem goes away. Out of pure ignorance on the subject I'm still concerned whether the power that would be going to the unplugged connector would be reverted to the 1 connector plugged in.
- Ribbons : 271
2021/01/11 18:06:11
facepalm
I mean, that's not how electricity works.
I'm not going to argue with you. Believe and do whatever you want. I tried. You don't believe me. Peace.
jankerson
2021/01/11 19:55:15
That means using one connection per cable. You have 4X cables, use 3 of them and use one connection per cable. THAT is what is ideal.
Gogod2020
2021/01/12 06:10:22
Thats not what people say. Even if you get modular sleeved cables by corsair they come with pigtail cable. You can ignore the pigtail (tie wrap it carefully with the main cable and make sure no connector touches anything) OR (which I would NOT recommend) you can use 1 6+2 and its pigtail to plug 1 and 3 pcie slots of your GPU and on slot 2 you add a separate 6+2 and leave its pig tail hanging or tie wrap it. HOWEVER: The best thing to do is put 3 SEPARATE pcie cables leaving their pigtails carefully hidden or hanging (as long as their connections don't touch something) and you will be perfectly fine. The electricity delivered will be EXACTLY the same as a pcie cable without the pigtail. ON CONTRARY, the pigtail cable MAY deliver a bit less electricity and thats why we don't prefer it for main connection. Hope this helps and clarifies the issue.
Intel Core 10700K, Z490 Aorus Elite AC v.1.0, GSkill 32GB 3000/CL14, EVGA 3080 FTW3 Ultra, Corsair HX1200, Dell S2721DGF, DRP4, Be Quiet SW3 140mm pwm high speed x4, Be Quiet 500DX, Samsung NVME 970 Evo Plus 1TB, Samsung SATA 860 Evo 1TB
hotpersuit1
2021/01/12 06:13:47
Yeah, I installed the PSU and connected 3 separate pigtail cables to the gpu and everything seems to be working fine. Doubled my previous heaven benchmark score with a 2070. Thank you everyone for your time and help.
sunlight0
2021/01/22 05:51:47
thanks for the info, I need to buy a new PSU
