Helpful Reply1080Ti FTW3 Fan control help
Blackshadow007
Wednesday, July 26, 2017 6:25 PM (permalink)
Hello guys , i am very much excited to play around with my brand new 1080ti ftw3 which i got one day ego . Now as i noticed that 6.1.12 version XOC i can't install cause that keep crashing whenever i start , looks like 6.1.11 version stable for me but that Memory slider bug still there . Anyways i just got the card one day ego as i told so i was just testing it with some games BF1 , Mafia , AC Unity now i noticed that using factory default settings everything i was hitting around 75 - 80 degree for 1440p DSR [ I have 1080p monitor currently , ordered 4k Monitor on the way ] for all 3 game i was trying . Then i did some reading around the forum and sites and saw people use custom fan curves and keep the card cooler , now i tested it with Aggressive Fan profile [ I am too afraid to mess with that fan lines lol ] then i saw dramatic temp reduce . Now my card sitting around 66 degree for both 1440p / 4k DSR which is cool i guess . Now my inquiry is using aggressive fan profile all the time will reduce my card's fan's longevity ? should i use this fan profile only when i am doing intense gaming ? ; also i noticed i was max hitting 1949 Mhz clock , i saw people doing 2000 Mhz + don't know how may be OC stuff .. i don't have much knowledge of it so i guess i shouldn't mess with those offsets . Any suggestion , help is appreciated :) , My room temp is around 33 - 35 degree so is this normal to have like 75 - 82 degree temps with it having Fan profile default not aggressive and all game settings Maxed out . Sorry if i asked any stupid questions , i don't have much knowledge in OC stuff so any help would be awesome .
post edited by Blackshadow007 - Wednesday, July 26, 2017 6:28 PM
Re: 1080Ti FTW3 Fan control help Wednesday, July 26, 2017 7:43 PM (permalink)
Blackshadow007
Of course, but you'll most likely upgrade to a different card before the fan dies.
post edited by Sajin - Wednesday, July 26, 2017 8:39 PM
CriticalHit_NL
  • Ribbons : 17
Re: 1080Ti FTW3 Fan control help Wednesday, July 26, 2017 7:59 PM (permalink) ☄ Helpfulby Blackshadow007 Wednesday, July 26, 2017 8:49 PM
Blackshadow007
Yeah but luckily the fan is working and following the fan curve, even if the slider is not updated correctly, you can press the little 'M' beneath if you want to see it update correctly.
Blackshadow007
EVGA is using as one of the very few brands dual-ball bearing fans that have a much longer longevity, they are also much less affected by temperature and just have a much lower general risk for failure.
The fans won't really be harmed much if you run them at high speeds, even for years, while sleeve bearing or rifle-bearing alternatives which are cheaper used by other brands often run dry (oil) or wear out after a year or 2-3 at high speeds.
And sleeve bearing is also not suited for horizontal positioning, as seen in most PC's.
Yes the dual-ball bearing fans can be a bit noisier, especially at higher speeds, though this noise may reduce overtime, while sleeve bearing and rifle bearing may become noisier overtime.
I wouldn't be worried about this, the likelyness for the fans on the EVGA card to die on you before the card becomes obsolete is very low.
If you want some peace of mind you can always purchase extra warranty for the videocard, so you can extend the warranty term to 5 years or 10 years.
This can only be done within a limited period of time:
All Extended Warranty purchases are non-refundable. The option to purchase will be available at the time of registration if registration is completed within 90 days of purchase. If you decline at the time of registration, the option to purchase the Extended Warranty will be available up to 90 days from the original date of purchase.
https://www.evga.com/support/warranty/extended.asp
Also don't forget to register your card on EVGA.com within 30 days of purchase for the normal 3 years warranty.
Blackshadow007
The boost clockspeed of 1949Mhz is perfectly normal under load conditions for the 1080Ti FTW3, this is also well beyond the guaranteed boost clockspeed of 1683Mhz.
Keep in mind that the clock speed can be held back by temperature and powerlimits, Pascal cards are more sensitive to temperature to previous generation cards.
See: http://www.anandtech.com/show/10325/the-nvidia-geforce-gtx-1080-and-1070-founders-edition-review/15
So even if the powerlimit is not reached, a higher temperature may reduce the boost clockspeed further.
In my case on the FTW3, I get 1949Mhz stable in games with 117% powertarget and below 70°C temperatures.
The top boost clockspeed for me is about 1974/1999Mhz out of the box with lower load and temperature, this varies per card a little most likely.
I get a stable boost clockspeed of about 1961Mhz when below 60°C and 117% powertarget.
Blackshadow007
With such ambient temperatures it is not strange to see such operating temperatures, but personally I wouldn't let it get much warmer than 75°C if possible.
The default fan profile don't kick in the fans when idle and is more geared towards silent operation, this comes from the Master bios.
The Slave bios has a more agressive fan curve and never lets the fans spin down when idle. (I think it's the same as agressive in Precision XOC).
Also the Slave bios allows a power target of 127%.
Using a higher powertarget does not cause any harm to the videocard, but it allows it to draw more power than the default 280W TDP limit, but keep in mind the PSU must handle this extra load.
It may make the experience a little bit smoother and consistent, but also can cause a little more heat.
For overclocking I can't help, but I would say it's not necessary when the card reaches 1949Mhz out of the box already, it's already performing great.
i7 3930K 4.4Ghz - EVGA 1080Ti FTW3 - 32GB Corsair Dominator DDR3-1866 - Asus Sabertooth X79 - Samsung 840 Pro 256GB - Samsung 860 Pro 2TB - 3x HGST 7K4000 Deskstar 4TB - 3x HGST Ultrastar He10 8TB - Corsair AX1200i - Asus PG279Q + BenQ BL2411 - Razer Viper Mini/SBF98 - Logitech Z906 & G35 - Windows 10 Professional
Blackshadow007
Re: 1080Ti FTW3 Fan control help Wednesday, July 26, 2017 8:49 PM (permalink)
CriticalHit_NL
Blackshadow007
Blackshadow007
Blackshadow007
See:
Blackshadow007
Thanks for your detail help .. most of my inquiries you already answer , This is why i choose EVGA so damn active community and support :) well i am already 10 years warranty holder . The moment i received card in hand i did register it on EVGA site and immediately purchased extended warranty without 2nd thought :P . Now i have Powerful PSU [ Seasonic Platinum 860XP ] i guess that's enough to take the extra load for this card . So basically if i keep enable Aggressive fan profile the fans will always spin in somewhat speed according to temp but if i dont set it to aggressive then fans will not spin until enough temp reached . Also its good to hear about the longevity matter , Thanks
Blackshadow007
Cool :)
CriticalHit_NL
  • Ribbons : 17
Re: 1080Ti FTW3 Fan control help Wednesday, July 26, 2017 9:13 PM (permalink)
Your welcome and enjoy your card!
And yes the PSU is completely fine for this card, here are the powerdraw limits per bios if powertarget is maxed out:
Master bios (default): 330.0W
Slave bios (secondary): 358.0W
Blackshadow007
Re: 1080Ti FTW3 Fan control help Thursday, July 27, 2017 10:50 AM (permalink)
CriticalHit_NL
Thanks for the info :) Appreciate your help .
cmp2993
Re: 1080Ti FTW3 Fan control help Friday, July 28, 2017 4:14 AM (permalink)
I'm in the same boat as Blackshadow, new owner of 1080 Ti FTW3. I found this information very useful in knowing more about the card, thank you!
I need to register my card now that you reminded me! If the extended warranty isn't too expensive I may consider that as well.
Blackshadow007
Re: 1080Ti FTW3 Fan control help Friday, July 28, 2017 4:54 AM (permalink)
cmp2993
Yes do that , extended warranty only 40 EUR or so for 10 years total [ 3 + 7 Years ] and i think that's worth of the investment having this High end card protected for enough time also this will give you good value when you resell too , 2nd owner will get good warranty time frame too i guess and you will get good price too for it .
cmp2993
Re: 1080Ti FTW3 Fan control help Sunday, July 30, 2017 3:56 AM (permalink)
Blackshadow007
I might only do the 5 year warranty. The notes on the extended warranty page says the extended warranty is non-transferable! The second owner will not receive your leftover time from the extended warranty. That's pretty lame, I wish it could be transferred. It really would increase the resell value.
Blackshadow007
Re: 1080Ti FTW3 Fan control help Sunday, July 30, 2017 5:17 AM (permalink)
cmp2993
Blackshadow007
Yes i just checked it , but anyways still a lot worth of investment for just 42 Euro having 7 years protection is more than enough and since it is a beast card and it should give us enjoyment long long time . I guess we can easily achieve high end gaming more than 5 years with this 1080ti's power .
