akashif
Hi
Last night for some unknown reason my pc power supply stopped working (evga supernova 1300 g2) I replaced the power supply, but now my 1080 ti ftw3 G led is red other LEDs are green
As soon as I power on the PC , Card has a red G LED
I have tried uninstalling precision x and install again with no outcome Just a side note when fitst time I installed precession x about 1 month back it asked me to update the firmware which I did
So now I am really worried that issue in power supply has damaged my card
Can someone please suggest
Thank you Ali
Re: 1080 ti ftw3 G LED is red
2018/03/06 09:56:30
Try this... #1 Shutdown your pc. #2 Unplug psu from wall. #3 Press and hold case power on button for 30 seconds. #4 Plug psu back into wall & start the system.
chrisdglong
- Ribbons : 7
2018/03/06 10:18:30
Change the LED colors, all of them to red. Shut down the PC. Change them all to the colors you want them... Worth a try anyway.
akashif
2018/03/06 12:20:37
Sajin Try this... #1 Shutdown your pc. #2 Unplug psu from wall. #3 Press and hold case power on button for 30 seconds. #4 Plug psu back into wall & start the system.
I tried that, but did not work,... still the G LED is blinking as RED, GREEN.... RED, GREEN.... RED, GREEN....RED, GREEN.... Other LEDs are stable Green chrisdglong Change the LED colors, all of them to red. Shut down the PC. Change them all to the colors you want them... Worth a try anyway.
Precision X, is unable to detect the card At all :-( any more suggestions ? Thank You
2018/03/06 12:24:08
Does using the secondary vbios produce the same issue?
akashif
2018/03/06 12:37:13
Sajin Does using the secondary vbios produce the same issue?
I have no idea what you just said. i am not that technical, a little explanation will be more helpful. Thank You
2018/03/06 12:39:09
To the left of the dual 8-pin power inputs on the card there is a vbios switch you can move to use the secondary vbios. Note: You'll need to do post #2 again after moving the vbios switch to the other position.
akashif
2018/03/06 12:44:10
Sajin To the left of the dual 8-pin power inputs on the card there is a vbios switch you can move to use the secondary vbios. Note: You'll need to do post #2 again after moving the vbios switch to the other position.
I found the switch, It says Normal OC Current position of switch is Normal. So you want me to change the switch to OC and Shutdown the System , remove power, press power On for 30 sec and then power in. Right ? Thank You
2018/03/06 12:44:27
akashif
2018/03/06 12:52:21
Did that, changed switch to OC, and powered off as recommended. but still same, the G LED is still blinking as RED, GREEN.. and when i start Precision X, it says "No supported hardware detected!" AM i Dead ?
2018/03/06 12:53:54
MarcSam
2018/03/06 13:05:19
Hi there, check this out: https://youtu.be/KNDxfuTq-xwThe guy having this problem solved it by completely performing a blank install of PrecisionX and nVidia drivers.
akashif
2018/03/08 08:42:55
MarcSam Hi there, check this out: The guy having this problem solved it by completely performing a blank install of PrecisionX and nVidia drivers.
Yes, i Tried that, but no use, PC is not detecting the card at all, no GPU in device manager, also when i try to install drivers, it says there is no compatible hardware. Thank You Ali
AHowes
- Ribbons : 27
2018/03/08 09:54:09
All I can think is to make sure the card is fully seated in the pci-e slot. Sometimes you get hung up on the i/o plate were it won't fully push in and the card will be on a slight angle.
akashif
2018/03/09 03:58:24
AHowes All I can think is to make sure the card is fully seated in the pci-e slot. Sometimes you get hung up on the i/o plate were it won't fully push in and the card will be on a slight angle.
Yes, I have made this sure, Card is properly installed in motherboard. UPDATE: I will be sending my card to EVGA. and so far i could not understand their shipment protocol. i am trying to understand the email they sent me. Thank You Ali
MarcSam
2018/03/09 10:43:47
If you need any help don't hesitate to tell us and we'll be glad to help you ;)
2018/03/09 11:38:57
akashif
https://www.evga.com/howtorma/
christian101308
2018/06/08 11:03:18
Up for this. I am having the same problem too. Please help...
- Ribbons : 135
2018/06/08 12:21:26
christian101308 Up for this. I am having the same problem too. Please help...
If you're having the same problem, then follow the same steps as outlined in the thread.
rgar123
2018/06/19 20:06:47
i'm having the same issues as the other folks on this thread. Has anyone come up with a solution besides returning to EVGA?
Breakthecycle2
2018/09/07 14:24:58
I know this is an old thread, but I just had this problem all of a sudden too. In my case one of the cards' power cables was not sitting right. Once I pushed it back in, it was fine.
nogaard777
2020/01/01 19:49:01
Not to raise a dead thread but in case anyone else runs into the issue and searches for it... This seems to be a problem unique to the FTW. I just bought a used one off ebay to use in a new PC I was building my kids. Same problem. Flashing 1st LED. It's not drivers. It won't even post. That's far earlier in the startup cycle than drivers are even considered. Did a ton of reading up on others with the problem before I accept it's not something stupid I overlooked and return it. This card has a vastly different VRM layout than Evga's own 1080ti SC2 sister and I think it's something in that unique system that is particularly finicky about power. Wouldn't post in the new system on a 800w PSU, pulled and moved to my personal machine with an evga 850w that currently had a 1080ti Superclocked in it. Still wouldn't post. Returned it, told the seller what was going on and he swears it's running fine in his machine with a 1000w psu when he got it back. Sounds like in evga's attempt to overbuild this card it got cursed with some kind of instability without the absolute best PSU supporting it. Or my seller was just trying to scam me.
