Answered1080 Hybrid running hot
Nautilus_802D
2017/02/07 13:10:24 (permalink)
Hello guys :)
My new 1080 hybrid gets REALLY hot when I run DOOM on full settings on everything on my X34 monitor.
On 100% load I get 71 celsius. Is this normal?
It`s in a NZXT 340 Elite cabinet with a NZXT Kraken X62
I've changed the fan to an EK Vardar F120 after watching Jayztwocents ugrade on it on Youtube.
Do you guys experience something similar?
the_Scarlet_one
formerly Scarlet-tech
  • Ribbons : 79
Re: 1080 Hybrid running hot 2017/02/07 13:18:39 (permalink) ☼ Best Answerby Nautilus_802D 2017/02/07 13:23:54
That is not normal for a hybrid. It should be quite a bit lower.
Have you checked to see if the radiator is hot or if the pump is operating properly? Radiator is pretty easy, just feel the exhaust coming out.
For the pump, feel the hoses to see if you can feel a light vibration from the motor running. You can also try to gently squeeze the tubes to see if the pump makes a little more noise from the added resistance.
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/07 13:26:39 (permalink)
It is pushing out pretty hot air from the exhaust. I've not felt the radiator it self. The intake/outtake for the hoses are on the top and not the bottom of the radiator. The radiator itself is ABOVE the GPU. But having the hoses on top, could that be the reason for this temperatures? At low load it goes back to a stable 31 degrees. All this is viewed through cam software.
PS: It is not set in push/pull. Only pull.
Re: 1080 Hybrid running hot 2017/02/07 13:28:43 (permalink)
Yep, something isn't right at all. Your temps should be around 50c at full load.
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/07 13:30:38 (permalink)
Maybe I should put the stock fan back on and test.
the_Scarlet_one
  • Ribbons : 79
Re: 1080 Hybrid running hot 2017/02/07 13:34:55 (permalink)
I doubt the fan is the issue, as long as it is running.  Try turning the radiator over, so that is can keep any air bubbles away from the hoses.  With the hoses at the bottom, and air should rise and remove the risk of an air bubble in the pump.
Does the pump make much noise?
  • Ribbons : 123
Re: 1080 Hybrid running hot 2017/02/07 13:45:30 (permalink)
Turn the radiator   +1
NZXT S340 Elite case ?
Do you have two intake fans in the front blowing In ?
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/07 13:55:26 (permalink)
Yes I do. The two 140mm NZXT fans that are on the NZXT Kraken X62
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/07 14:07:51 (permalink)
OK Guys. I feel REALLY stupid here. I just re-attached the original EVGA-fan to the front of the rad just to test. It is now running steady 50 on 100% load.
Now I'm running EK Vardar F120 in pull and the original EVGA-fan in push on the rad. It is steady 50/sub 50.
  • Ribbons : 123
Re: 1080 Hybrid running hot 2017/02/07 15:15:30 (permalink)
If your case did not have more CFM of air pushing in than out - your case could have been under negative pressure
So two 140mm fans on Kraken radiator in front of case blow in
One  140 or 120 ? mm in back of case blows Out
Hybrid rad blows out
Which direction does the fan on top of case blow In or Out ?
I like my Vardar F4-120 & F3-140 fans; they are quiet and move a ton of air with good pressure
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/08 00:36:59 (permalink)
Thanks for the reply Cool GTX
This is WAS my setup:
2x 140mm SP fans on the Kraken X62 blowing INTO the cabinet.
1x 140mm NZXT AER-fan on the top of case blowing OUT.
1x 120mm EK Vardar F1-120mm in pull (blows out of the back port) set at 1300rpm
PS: This was the setup that ended in a 70c hot card.
This IS my setup:
1x 120mm EK Vardar F1-120mm (1300rpm) in pull and original EVGA fan in push on the radiator (100% speed) (blows out of the back port)
PS: This was the setup that ended in a max 50c hot card.
I know that I probably should use two identical fans, and I´m currently working on finding a pair of good lookin´fans as this is a bit of an
aesthetical build and the Vardars shure are ugly (gray and black).
The Vardars came into the picture after watching Jayztwocents on Youtube. But he used Speedfan and that looks way to advanced for me.
I´m comfortable with the fans running 100% all the time as I´m using headset :)
post edited by Nautilus_802D - 2017/02/08 00:47:10
Vlada011
  • Ribbons : 11
Re: 1080 Hybrid running hot 2017/02/08 02:33:49 (permalink) ☄ Helpfulby Nautilus_802D 2017/02/08 02:40:05
http://www.evga.com
http://www.intel.com
http://www.nvidia.com
https://watercool.de
http://www.lian-li.com
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/08 02:40:46 (permalink)
Vlada011
Did you check ML fans from CORSAIR, they push a lot of air and spin fast, 400-2400 RPM.
Thank you very much Vlada011.
This is very helpfull :) They looked very nice too.
Vlada011
  • Ribbons : 11
Re: 1080 Hybrid running hot 2017/02/08 07:21:02 (permalink)
I would bought them immediately only I'm not sure what I need 120 or 140mm because radiator.
They look good and Hybrid + EVGA CLC280 with CORSAIR ML fans will cooldown hardware excellent.
http://www.evga.com
  • Ribbons : 123
Re: 1080 Hybrid running hot 2017/02/08 07:52:12 (permalink)
EK Vardar F4-120ER (2200 rpm) can be bought in All White and have 4-pin PWM for speed control 25%-100%
chap34
Re: 1080 Hybrid running hot 2017/02/08 11:33:24 (permalink)
Nautilus_802D
This IS my setup:
So the only thing you changed was making it push/pull instead of pull and it dropped 20c?!
Dr.Death
  • Ribbons : 9
Re: 1080 Hybrid running hot 2017/02/08 12:19:13 (permalink)
I found any blocking of the radiator   will increase temps [don't take much to see it start to climb ]    the more open air  the better    not to say its the best way  but this worked the best for my card  and gave a 7c drop in max over the last coolest placement I used    -
http://imgur.com/UbwqG6X
just be sure the hose orientation   is the same or just correct   leave the radiator unmounted and set out side the case  with no obstructions   to test
I cleaned out my case one day and forgot about the radiator  and it was face down   and I noticed it was getting like 65c    I was like '' what the !!!! ''    lol...   then realized what I had done   set it back up sop it could ';'breath ''  and right back to normal   [25c idle  46c max pounding on it ]
anyway if you try that  and still  getting up in temps   then you may have another issue or just a lemon   [guys ran in to things as  this  with the 900 series as well  ]
Nautilus_802D
Re: 1080 Hybrid running hot 2017/02/08 12:24:10 (permalink)
chap34
Nautilus_802D
This IS my setup:
Yes! I kid you not! The EK Vardar F1-120 was running in 1300rpm PULL. THEN I attached the included EVGA-fan that came with the card and presto, it fell 20c. I know it´s crazy but the radiator was hot! 70c!!
chap34
Re: 1080 Hybrid running hot 2017/02/08 12:30:28 (permalink)
Dr.Death
I'm pretty sure for enclosed radiators like the Hybrids they recommend the pump to be higher than the fan, so that wouldn't really work here :\
Dr.Death
  • Ribbons : 9
Re: 1080 Hybrid running hot 2017/02/08 13:26:36 (permalink)
by who ?? evga that aint got a clue  how any of it works ?? does the radiator in your car work that way  ?  no it like as I showed  that pretty well goes for most everything that uses one   in life
http://forums.evga.com/New-980-ti-hybrid-radiator-fan-constantly-on-full-speed-m2453739.aspx
you see from just that they don't have a clue  they promote and sell
and maybe that's why your here with issues and I am not trying to answer   LOl........  my  hybrid been operating well over a year with out any issue and cool as can be just as I showed
''Yes! I kid you not! The EK Vardar F1-120 was running in 1300rpm PULL. THEN I attached the included EVGA-fan that came with the card and presto, it fell 20c. I know it´s crazy but the radiator was hot! 70c!!''
when you swapped the fand did you check if they had the same ''CFM ''ratings  ??    if the evga fan pushes say 60 cfm and  your replacement fan only does  30 cfm   its not going to remove as much heat   at any rated RPM's
post edited by Dr.Death - 2017/02/08 13:29:44
chap34
Re: 1080 Hybrid running hot 2017/02/08 13:58:26 (permalink)
[link=http://www.asetek.com/press-room/media/videos/2013/how-to-quiet-a-noisy-asetek-liquid-cooling-pump/]http://www.asetek.com/pre...k-liquid-cooling-pump/[/link]
Plus the hybrid hoses are right next to each other, I'm not sure how you got yours to mount like that, I suppose you could mount it sideways and I'm sure it would run better like that, I just dont see how its feasible in most cases. Either way, the guy has a cooler GPU now!
Dr.Death
  • Ribbons : 9
Re: 1080 Hybrid running hot 2017/02/08 14:43:10 (permalink)
''I just dont see how its feasible in most cases. Either''    well then maybe you should of bought a air card  if a hybrid is too smart for you to deal with ??
you just don't realize how much stress you put on the pump  pushing that liquid up hill and around corners     and then have the output  blocked by any liquid   being mounted at the bottom    you can see my way  it all works hand in hand and efficiently  and minimal  work or stress on the pump unit
take a water hose  hang it from a tree limb   fill it with water and try to blow it out  with a guy having his thumb covering the end  ??     that's pretty hard to do and your lungs will hurt bad trying to
same hose  level   end open and the water easily blows out    with a lot less effort    then  like my way the weight of the liquid helps push down and back in to the pump  so that's also less work the pump has to do
then heat and air rises   so with that its not being pulled back in tto the system as well   ita all going to the top  out of the way
its just common sense  physics
but to each his own   and I tried may other configurations with mine     and nothing worked as well  as I got in that  illustration  I gave   and did not think any of them would of any way  but had to experiment with it  and prove
all I can do is show that  and its up top them to give it a try   each and every card  has its own personality   and you g0t to try things and see whats best for your system overall
good luck  and enjoy
abroomy92
Re: 1080 Hybrid running hot 2020/04/19 09:54:29 (permalink)
Good evening,
I've had my GTX 1080 FTW Hybrid, coming up to two years this may. Unfortunately I've encountered a similar problem when I load any game my card randomly sores in temp to 80/95c. Obviously I close down any application when this happens. I've stripped my machine down and cleansed all the components. Then reset and rolled back software, firmware and drivers. This didn't help at all, however what did help is making sure the cooling pipes are tight and pushed against GPU. I found my problem lies within the pipeline / waterflow. I've logged a ticket with EVGA today to get some advice, I shouldn't have to apply pressure to my piping for it to work normally. It's not even two years old yet, plus it's well maintained and not OCd or K boosted. Hopefully EVGA will help me out...
#23
  • Ribbons : 135
Re: 1080 Hybrid running hot 2020/04/19 11:02:14 (permalink)
abroomy92
Good evening,
What has probably happened is the TIM has dried out, or when your cooler was installed at the factory, it was not torqued correctly and the heat sink is not firmly tightened against the GPU die. You can, if you've replaced the TIM on a CPU, repair your GPU by replacing the TIM between the cooler and the die without voiding your warranty. On the other hand if your GPU is still under warranty (it should be if you have had it less than three years) you might may wish to replace it.
#24
