1070ti Cooler is QUIETER than 1080ti cooler
Notwist
Wednesday, December 20, 2017 5:38 PM (permalink)
Heads up for EVGA, after owning both a 1080ti FTW, a Kingpin, and now a 1070ti, I don't notice any of the fan harmonics issues on the 1070ti.
Maybe switch back to that design next gen? ;D
16 Replies Related Threads
    demon09
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Wednesday, December 20, 2017 7:17 PM (permalink)
    The 1070ti also a 2.5slot unless I am confused?
    arestavo
    • Ribbons : 77
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Wednesday, December 20, 2017 7:18 PM (permalink)
    And this is at the same RPM? I ask because the 1070 Ti, being a smaller die with a lower TDP, doesn't tax a cooler like the 1080 Ti does. I know this because I came from a 1080 to a 1080 Ti, and the cooling required to maintain the same temperature is much greater.
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Wednesday, December 20, 2017 8:13 PM (permalink)
    demon09
    Only this one is 2.5.
    quadlatte
    • Ribbons : 56
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Wednesday, December 20, 2017 8:21 PM (permalink)
    put that 1070ti cooler on a 1080ti and see the difference, my guess is its not going to give them same results
                                                 Heatware: http://heatware.com/eval.php?id=72498
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Wednesday, December 20, 2017 9:35 PM (permalink)
    SC model is standard 2 slot width.
    Not sure on the FTW as I won't buy one due to the dual power connector setup.
    Now that vorsholk has stopped his abuse, I'm returning to folding.
     I no longer MOO due to abuses by certain "whales" in the Gridcoin community - so I now work the Distributed.net project directly again.
    Reksai
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, December 21, 2017 9:22 AM (permalink)
    I think EVGA missed an opportunity not to have a 2.5 slot Ti. I like EVGA for it's customer service but after receiving my Ti, I'm disappointed in the performance. There's no reason to have a smaller heatsink, because of the heat generated by the Ti. I guess the niche group of people who have an iTX, or go SLI will have plenty of choices.
    demon09
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, December 21, 2017 4:38 PM (permalink)
    Reksai
    to be fair some of the large coolers are actually worse in the noise to cooling department then evga's 1080ti ftw but they might have been able to gain a little
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, December 21, 2017 5:37 PM (permalink)
    1070 ti and 1080 are very similar on stats and power consumption - the BIG difference is GDDR 5 vs GDDR 5x.
    180 watt TDP on "base" models in either case.
     AFAIK there isn't ANY model of the 1080 with a TDP of 250 watts, though there is one MSI Armor model at 240 - and even pushing that card HARD it doesn't manage to actually PULL 240 at stock voltage, more like 220-225.
     I don't see any POINT to wasting a 2.5 slot cooler on either - I've been unable to get my EVGA SC 1070 ti cards up past about 65 PERIOD even when I was testing them at max TDP on about 65% fan (afterburner custom fan profile) and I don't remember anything but the Zotac Mini 1080 model getting much higher unless the ambient temp was HOT (95+ F).
     1080 ti on the other hand pulls almost 50% MORE power by default (250 watts on "base" models), a 2.5 slot cooler on THOSE makes a ton of sense for gaming or cards that are being pushed hard.
    Notwist
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, December 21, 2017 8:11 PM (permalink)
    I’m referring primarily to the noise harmonics on the 1070ti FTW2 being improved compared to the 1080ti models. There used to be high pitched whines around 30% speed that are not present in the 1070ti.
    Plus...I personally love the look of that design. The 1080ti cards are ok, but the 1080/1070 design was awesome :)
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Saturday, December 23, 2017 10:16 PM (permalink)
    30% fan.
    I can't remember the last time I had a card running at 30% fan.
     That seems very very LOW to me.
     Could be 'cause I hate letting cards get HOT and shortening their lifetime....
    Notwist
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Monday, December 25, 2017 1:47 AM (permalink)
    QuintLeo
    30% fan.
    If my card needed to run at over 80% fan speed for many many games released 5 years ago I would be worried
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Monday, December 25, 2017 4:58 PM (permalink)
    Who said anything about over 80% fan?
    Most of my cards run in the 50-60% fan range, except on machines in my "computer room" in the summer where I have to bump a few of them up to 70-80% (depending on the card, the old R9 290 blower models always want more).
    That's on a MUCH heavier load than gaming ever consistantly puts on a GPU, running various compute workloads.
     Aorus 1080 ti in my gaming machine is currently at 58% (and 58C, on my normal custom fan profile in Afterburner), but it's doing some cryptocoin mining in a room that is at about 84F right now while I do stuff other than gaming on the machine.
    jdw715
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, January 04, 2018 2:20 AM (permalink)
    QuintLeo
    What's the issue with dual power?
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Thursday, January 04, 2018 4:29 AM (permalink)
    On multi-card rigs, it is a lot harder to come up with enough power connectors for the 2-connector 1070 ti models than the single 8-pin models.
    gambl0r
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Sunday, January 07, 2018 9:17 PM (permalink)
    Is there a single pin 1070ti model?
    QuintLeo
    Re: 1070ti Cooler is QUIETER than 1080ti cooler Monday, January 08, 2018 6:39 PM (permalink)
    There are quite a few 1070 ti models that have a single 8-pin power connector.
    EVGA SC, ASUS Turbo (blower model), Zotac Mini, among others.
