evga water cooling kit question
matthmaroo
2014/01/24 20:28:53 (permalink)
does anyone know the dimensions of the rad?
2 Replies Related Threads
    kmc234
    Re: evga water cooling kit question 2014/01/28 13:43:04 (permalink)
    240 mm it seems.  Custom, fits exactly on top of their Hadron Hydro case which is made for it.  2 x 120 mm fans.
    Acorn248
    Re: evga water cooling kit question 2014/02/08 00:40:11 (permalink)
    The holes are the same on the other side.  But note the fans bolt directly to the case, not the radiator.  There is a small gap in between.  If you want to do after market fans, DO THEM FIRST. To get aftermarket in there after the loop is near impossible.
