evga gtx 680 classified led lights
madmike66685
2012/09/21 13:05:54 (permalink)
hi all,
i am starting to get annoyed with the bright led light on this gpu is it possible to turn them off?
maximus v extreme, 3770k i7 @ 5ghz, custom loop water cooling, g skill 2133mhz 16gb,cosmos 2 case, ax1200 psu, xonar phoebus sound card, 2 x vertex 4 256gb ssd (raid 0), 500gb wd hdd, evga geforce gtx 680 4gb classified
18 Replies Related Threads
    sjp770
    Re:evga gtx 680 classified led lights 2012/10/05 02:18:52 (permalink)
    Seconded! Anyone?
    I'm assuming they will be brilliant for when i hook up the waterblock...
    i7-3930K @ 4.6GHz, ASUS Rampage IV Formula, EVGA GTX 680 Classified 4GB HydroCopper, Corsair Vengance 16Gb 1600Mhz DDR3,  Intel 520 series 240Gb SSD, Corsair NFORCE3 120Gb SSD, 3x Dell 24" Portrait Surround , Corsair AX1200i PSU, HWLabs GTX 560 100% inside a Corsair 800D
    masterpmi
    Re:evga gtx 680 classified led lights 2012/10/05 06:55:34 (permalink)
    search the forum.
    this has been in several threads, No way to turn off. People were putting tape on them, etc to cover up.
      EVGA AFFILIATE CODE:   B7VT8RML4L
    Tombi
    Re:evga gtx 680 classified led lights 2012/10/05 07:05:30 (permalink)
    I hope EVGA will response to this thread.
    I think there would be any way to turn them off - perhaps over BIOS modding?
    EVGA, please tell us how to turn them off, otherwise please tell me (over PM or otherwise) how to mod the BIOS (or send me a already modded bios) to turn them off - I will then tell the community about it (yes, yes.. warranty void ...).
    Or are these LED's hardware controlled and there is no way to control them over BIOS?
    PhazeDelta1
    Re:evga gtx 680 classified led lights 2012/10/05 09:07:23 (permalink)
    There is no way to turn the off.  Put black electrical tape over them like the rest of us have done.
    Cloudz00x
    Re:evga gtx 680 classified led lights 2012/10/05 09:11:21 (permalink)
    madmike66685
    hi all,
    Or... you can do the cool thing. Convert your system to Water-Cooling. Buy Hydro Coppers then personally Mod the Color to a color of your liking. Which I'm doing, the red on the hydro coppers don't match my theme. Gonna change then to white.
    Jdiaosi
    Re:evga gtx 680 classified led lights 2012/10/05 14:04:05 (permalink)
    u can change to water block
    sjp770
    Re:evga gtx 680 classified led lights 2012/10/08 04:57:07 (permalink)
    A water block is on the cards, but i cant see why they would have gone for such an in your face brightness for those LEDs? Maybe there was supposed to be a nicer cover..
    Can EVGA confirm the LEDs are unable to be turned off? Then we can all get on with our Electrical tape dodgyness.. :(
    Angrychair420
    Re:evga gtx 680 classified led lights 2012/10/28 22:21:46 (permalink)
    I'm working on something to cover it up and look great / use the light ina better way.  Currently experimenting with lexan and electrical tape to make an illuminated EVGA logo
    EVGA_JacobF
    • Ribbons : 26
    Re:evga gtx 680 classified led lights 2012/10/28 23:07:01 (permalink)
    Unfortunately there is no way to disable it, you can use electrical tape to cover it though.
    nathancnc
    Re:evga gtx 680 classified led lights 2012/10/29 05:32:27 (permalink)
    Personally I would not use electrical tape on my gpu, because electrical tape will leave a "residue" which I would want on an expensive part like the 680 classy.
    Get some black painter's tape, it leaves no residue behind, ever.
    letsthrowfries
    Re:evga gtx 680 classified led lights 2012/10/29 06:17:25 (permalink)
    They got black gaffer's tape on amazon, I used liquid electrical tape though.
    sjp770
    Re:evga gtx 680 classified led lights 2012/10/29 12:18:54 (permalink)
    I went out and grabbed the only nice solution from EVGA, a lovely waterblock!
    AzN-SoLjA
    • Ribbons : 14
    Re:evga gtx 680 classified led lights 2012/10/29 12:33:41 (permalink)
    black sharpie! lol but seriously get a block :)
    | EVGA Z68 FTW | EVGA GTX 780 Ti SC 3GB | EVGA GTX 1080 Ti FTW3 | Custom EK Water Loop | Red Harbinger Cross Desk
    | Creative Inspire T6160 5.1 & X-Fi Fatal1ty 7.1 Champ | Razer Marauder & Spectre & Tiamat 7.1 | Affiliate Code: 3MHCIBME48 | Associate Code: 08HWLPJXE0O5MPM
    pathfndr
    Re:evga gtx 680 classified led lights 2012/11/01 01:17:33 (permalink)
    I put about 3 layers of blue painter's tape over mine to match the blue LED's in the case. Looks perfect. Might as well use what you're handed and make lemonaide. :)
    Intel  i7 3770K OC'd 4.5, Asus P8Z77 V-Pro, G-Skill Ripjaws Z 2133,
    EVGA 680 Classified, Corsair TX750,Samsung 830 256Gb SSD, WD Black 1Tb,
    Corsair H80, Corsair 800D case, 27" Samsung Syncmaster, 21" Samsung TV/Monitor
    Corsair K90 Keyboard, Razer Naga Epic and Mamba 2012
    sjp770
    Re:evga gtx 680 classified led lights 2012/11/09 23:01:46 (permalink)
    An update:
    The waterblock doesn't cover those damn annoying LEDS!!
    electrical tape it is..
    acey_c
    Re:evga gtx 680 classified led lights 2013/02/07 10:41:21 (permalink)
    5 LED right? 1 just died on me.. from left 1 2 3 4 5 ,, the number 4 is not lighting up.. EVGA what happen to my classified?
    acey_c
    Re:evga gtx 680 classified led lights 2013/02/08 04:33:53 (permalink)
    ??? err no reply for LED not lighting up? EVGA?
    Gomiboy
    Re:evga gtx 680 classified led lights 2013/02/08 04:40:53 (permalink)
    acey_c
    Source:
    http://forums.evga.com...?m=1840834&mpage=1
    EVGA_JacobF
    The LED's near the EVBot connector show voltage going to GPU, PEX and MEM. If any one of them goes out then for some reason voltage stopped flowing to that portion of the card.
