https://www.techpowerup.com/320835/be-quiet-unveils-silent-wings-pro-4-white-and-silent-wings-4-white-fans be quiet!, the German manufacturer for premium PC components, proudly introduces the Silent Wings Pro 4 White and Silent Wings 4 White fan series. These radiant white high-end fans are built for maximum performance in cases, on heat sinks, and on radiators, delivering not just great airflow but also impressive static pressure. The fans feature unique exchangeable mounting corners to easily adapt the fans to different situations. With the Silent Wings Pro 4 White, be quiet! has turbocharged its fans to reach extremely high rotational speeds yet offering consumers a choice to configure these fans for low noise, a noise/performance balanced mode, or maximum performance.
With the Silent Wings 4 White series, be quiet! has focused on improving static pressure, which is of vital importance when mounting fans to heat sinks or liquid cooled radiators. The fans feature a low tip clearance of 1.0 mm and a funnel-shaped air outlet, dispersing the air over a greater area and resulting in a drastic improvement in static pressure. This makes the Silent Wings 4 White series a top choice for heat sinks or radiators, while keeping its noise levels impressively low. Silent Wings 4 White comes with two different mounting corners that are tool-free and easy to exchange: vibration-free rubber push-pin corners and traditional hard-plastic screw-type corners.
The fans come in two sizes (120 mm/140 mm) and two different models: PWM, and PWM high-speed. The PWM models are best suited as case fans with their maximum speeds of 1600 rpm (120 mm) and 1100 rpm (140 mm), while the PWM high-speed versions are specifically tailored to heat sinks and radiators thanks to their higher speeds of 2500 rpm and 1900 rpm respectively. All Silent Wings 4 White fans rely on a proven combination of a 6-pole fan motor with three phases and fluid-dynamic bearings for a long lifespan of 300,000 hours.
Going Pro for maximum performance
For consumers who really want no holds barred, be quiet! is introducing Silent Wings Pro 4 White. While these fans offer the same features as the Silent Wings 4 White, the rotational speed has been turbocharged to 3000 rpm for the 120 mm version, and 2400 rpm for the 140 mm version. A speed switch on the back makes it easy for customers who don't want to deal with PWM fan curves to set the maximum speed based on their preferred usage: Medium for silence-optimized operation, High Speed for a noise/performance-balanced mode, and Ultra High Speed for maximum performance. Silent Wings Pro 4 White includes one additional corner type, specifically created for radiators. These radiator corners form a tight fit on the fan to prevent air leakage and to ensure maximum static pressure. The fans also feature a high-grade white mesh sleeve cable and easy-to-use motherboard connector.
All Silent Wings Pro 4 White and Silent Wings 4 White models will be available in retail from April 9.
Hopefully the pricing is competitive.
